Intake Manifold
Old Aug 26, 2018 | 06:02 AM
Loucobalt's Avatar
Intake Manifold
Members, just picked up an intake manifold for my '69 350 at a local swap meet. After checking the casting # (390327) it looks like it was made for a '66 330 (4V).
wanted to know if it will fit my engine & that the runner design/flow would be the same as a period correct manifold (4V). Not worried about choke set up as I have a Qjet w/
electric choke going on it.
Thank !
Old Aug 26, 2018 | 06:23 AM
Thank !
Ports and fitment are the same. The only possible issue is that the 390327 intake only has one sensor port in the water crossover; the correct 398663 intake has two - the second was used for the thermal vacuum switch controlling vacuum advance in some applications.
Old Aug 26, 2018 | 07:06 AM
Loucobalt's Avatar
Joe, the intake that's on car now is an Eddy 3711 & the dizzy has been swapped for an
hei unit. Would those things have any bearing on needing the (2) sensors @ manifold ?
Just wanted to go back to a somewhat period correct cast intake.
Thanks !
Old Aug 26, 2018 | 07:20 AM
Thanks !
The distributor has nothing to do with the need for the second port. Olds used a TVS on some cars to switch from ported to manifold vacuum if the engine started to overheat. If you are using straight manifold vacuum for the advance anyway, that's a moot point.
I question your desire to change the manifold, however. The HEI isn't "period correct" either. And frankly, if your goal is to just hide the late model E-brock intake, I'd simply grind off the logo, sandblast to eliminate the grinder marks, and paint the aluminum intake engine color.
Sep 15, 2019 04:30 PM
Mytime
Aug 4, 2018 09:10 PM
krauser65
Dec 10, 2013 10:29 AM
tgilligan
May 18, 2013 08:32 PM
Homestar
Apr 4, 2011 05:05 AM
