My Daughter to my 70S for a small drive
Old Jun 10, 2018 | 06:05 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Found this on #2.
The other push rod was shoved down. I used a magnet and pulled it out the other push rod, no end. Pulling the intake next.
Old Jun 10, 2018 | 07:48 PM
Yellowstatue's Avatar
Oops.
Old Jun 11, 2018 | 05:08 AM
Hopefully the carnage is nothing serious.
Old Jun 11, 2018 | 05:21 AM
I plan on pulling the intake tonight. I do have one spare lifter and I am going back to stock rocker arms as well.
Old Jun 11, 2018 | 05:11 PM
Pulled the intake, removed #2 lifters and rotated by hand. The lobes aren't flat and the lifters look good on both ends. I will put back together this week. I am going back to stock rocker arms for now.
Old Jun 13, 2018 | 09:47 PM
Well, all back together and runs and sounds the best it has since going together with the new heads and cam. I hear 0 valve ticks just an exhaust leak at the cracked header tube. Of course I had to switch one rocker out and one bridge to get proper preload on all the valves. Also still no lock up despite direct wiring, either it was blocked off or converted. It could also be the torque converter itself.
Old Jun 14, 2018 | 08:54 PM
coppercutlass's Avatar
Chevy budget Olds powered
where these the 1.7 rockers ???
Old Jun 15, 2018 | 06:09 AM
Yes 1.72 SBF rockers.
Old Jun 15, 2018 | 08:37 AM
Isnt there clearance issues with the 1.72 rockers where the heads have to get clearanced ? I ran into issues getring proper geometry with the ford rockers the correct length was hitting and that was with a 1.6 i endes uo running thw ahortest pushrod i could. Pattern was a little off center but thin and didnt move.
Old Jun 15, 2018 | 06:54 PM
I probably should have checked closer. The other set of #6 heads were close but the push rods just cleared.
mazey
Oct 10, 2017 03:21 PM
boese1978
Mar 8, 2016 03:49 PM
jbates
Jan 13, 2016 07:25 AM
ggriffin1960
Feb 5, 2012 07:20 PM
rayfrausto
Jul 28, 2011 08:39 PM
