View Full Version : Small Blocks
Pages : 1 [2] 3 4 5
  1. Street - not Strip Build
  2. What's The Diff?
  3. Edelbrock 1406 carb and fuel economy
  4. 2.25" exhaust limitations?
  5. '84 cutlass 307 w/high idle
  6. small block push rods
  7. ignition timing
  8. How to tell if my 350 was originally a 4bbl?
  9. Carb question.
  10. 350 Upgrade
  11. overheat question
  12. carb problem
  13. SBO 350 compression??
  14. fan clutch
  15. new and need some help
  16. kickdown cable location
  17. retarding cam timing on 307
  18. no oil to top end
  19. Head question
  20. 330 V8 headers
  21. pulley measurement
  22. 260 Intake swap?
  23. reving an Olds 350
  24. 350 rocket help
  25. #8 heads...what to do?
  26. Backfire through the intake.
  27. 1972 350 rocket
  28. cam for my 350's 2.25" exhaust?
  29. 70 Olds 350 Redline
  30. A/c Help!!!!
  31. #6 heads
  32. not shifting gears with new carb and manifold!
  33. Head Numbers
  34. Hardened Seats
  35. overheating problem...flex fan was recommended...opinions..
  36. W-X exhaust manifolds on a small block.
  37. Alternate heads for a 260?
  38. Tips & opinions for a possible 403 swap, good idea?
  39. thoughts on this book...
  40. Retarded Timing
  41. Flywheel Interchange
  42. Wants to stall when put in drive!
  43. LOCKTITE: Friend or Foe?
  44. BLUE SMOKE (long thread w/lotta detail)
  45. slow starter
  46. 69 350 Timing Chain Questions
  47. Oldsmobile Engine Identifaction Needed
  48. 305 "H" motors.
  49. Cutlass Supreme headers?
  50. No bottom end torque
  51. 3A heads
  52. 64 olds 330
  53. 1977 350 rebuild
  54. 1972 350 exhaust manifolds
  55. A real challenge - Block ID issue
  56. 350 Questions
  57. Some Loss on low end?
  58. Seattle Area
  59. 1970 CUTLASS, BACKFIRING 350 ENGINE
  60. Oil Galley Bolts
  61. #1 piston
  62. 350 running lean
  63. '69 350 oil filler tube removal
  64. 350 or 455
  65. 350 olds vacuum
  66. $1500 dollar budget to rebuild a olds 350
  67. 1970 cutlass motor 350ci
  68. oil filter housing for a 330 ci
  69. carb ?'s
  70. Whats the stock HP rating for a '72 350?
  71. VIN derivative stamping
  72. Rebuilding a 350 for street
  73. valve covers are bbo and sbo the same?
  74. oai engine parts ??
  75. Correct timing for HEI
  76. Need help with my 79 350
  77. What headers
  78. 350 spark plug gap
  79. Vacuum diagram
  80. 69 head identification
  81. tailpipe smoke
  82. Need help with a leaky fuel pump
  83. Stroking out a 350 olds
  84. 5.7 diesel
  85. Got a spare 330
  86. Engine casting #'s
  87. Rebuliding an olds 350
  88. 330 balancer?
  89. serpentine belt system
  90. 307 Intake on my 71 350?
  91. small block parts bolts compatability?
  92. Alternator Belt blues
  93. 3x2 324
  94. colored greens
  95. 71 Cutlass Supreme with 260?
  96. painting my 350 Rocket
  97. rough idle
  98. hello again !
  99. headers or exhaust manifold
  100. Hedman headers
  101. How useful is this manifold ?
  102. edelbrock manifold on stock 350?
  103. t-stat or rad cap???
  104. air cleaner questions ???
  105. 350 heads
  106. 455 heads on 350?
  107. Parts ID
  108. w-350 Intake or Edelbrock Intake
  109. BUICK Motors in Oldsmobiles.
  110. Which carb ?
  111. Timing tabs anyone ?
  112. Timing and Spark Plug Gap for 350
  113. Engine Misses-Don't know what is wrong
  114. Covering holes on heads
  115. cam/carb for mid-13s?
  116. Engine casting numbers
  117. where to find headers for a 74 Omega
  118. Engine Knocking
  119. 307 start problem
  120. 403 info please
  121. Painting the engine block
  122. what motor due i have
  123. rebuilding engine in 84 cutlass supreme
  124. 86 442 Timing tab.
  125. Red line on a 68 350
  126. Replacing valve cover gaskets
  127. antifreeze question
  128. Motor & Trans for sale
  129. New heads for my 86 442 plz?
  130. Blue Smoke From Exhaust Pipe
  131. Edelbrock Intake ID
  132. 75 Cutlass 350 headers?
  133. what year is my 350?
  134. Choke problems?
  135. cylinder heads
  136. crossmember
  137. 403 ?
  138. Performance options
  139. Problem ? ring end gap
  140. crossmember 77-442
  141. Block off plate?
  142. flush engine?
  143. WIRING DIAGRAM?
  144. Coolant loss with our 350
  145. 350 Valvetrain Question
  146. Carb/torque Converter Tech Question for a 350
  147. Exhaust, The Final Tech Question
  148. radiator stop leak
  149. Will Olds 350 exhaust manifolds work on a 403?
  150. 400 vs. 403
  151. engine mounts 303 350 swap
  152. 79 olds 350 buildup
  153. valve size
  154. Braided hoses question
  155. Olds to Chevy
  156. 350 Small Block Upgrade Help
  157. Edlebrock performer package
  158. Oil Filter
  159. Small block AC delete pulley?
  160. Froze last night.
  161. 3A vs 5A heads on 79 350
  162. Help - rear seal / crank
  163. freeze plugs?
  164. Starting a new 350 build this weekend.
  165. Heater blows hot air. Sometimes.
  166. Some engine questions...
  167. Compression ratio????
  168. 350 REBUILD
  169. Need 1985 vaccum diagram...
  170. Should I upgrade my 350?
  171. exhaust manifolds explained?
  172. Compression Ratio?
  173. Valve covers-what do you think ?
  174. ac delete on 72 olds cutlass vert
  175. olds 394 help
  176. 70 cutlass dist/vacuum control
  177. mandrel bent crossover pipe
  178. Leaky oil pressure sending unit
  179. olds 307 chevy 350 swap
  180. 71 cutlass
  181. Which Spark plugs ?
  182. 330 carburator and intake help
  183. 64 f85 intake help
  184. 71 olds 350 question
  185. CHEVROLET VORTEX CYLINDER HEADS
  186. Dual exhausts for 1964 394 engine
  187. 350 olds to 455
  188. Manifold Exhaust
  189. how much hp
  190. Some1 W/ a 307 Y Do me a favor?
  191. Which Small Block Olds is Better
  192. 750cfm double pumper on an olds 350 ?
  193. HP gains!
  194. My '56 324: Is the oil pump working??
  195. 350 or 403 ???
  196. bought 77 Cutlass-have engine questions
  197. REBUILT KITS
  198. Interchange on 350 - 403???
  199. which valve covers to get ? moroso or edelbrock
  200. '69 Olds 350 engine
  201. Starting issue
  202. how do i know if my engine is stock:S
  203. headers
  204. 1970 cutlass supreme rebuild need help!
  205. Did I order the wrong part?
  206. 307 heads on 350? bump compression up?
  207. Rocket 88 Holiday Sedan
  208. 350 rebuild
  209. Engine Question
  210. cam question
  211. Newbie: Engine Code on 88
  212. matching numbers how can you tell??
  213. radiator hose
  214. Finally going home
  215. Headers 324
  216. Pulling a 330
  217. How to tell if I have the original engine?
  218. Olds Mechanic needed
  219. front cover for 350
  220. Engine Heads (71 Cutlass Sup Convt)
  221. Spark plug condition
  222. 71 cutlass intake
  223. Restoration in 30 days
  224. 1977 Delta 88 Royale 'Indy Pace Car Replica'
  225. intake/carb question
  226. dipstick too small
  227. 350 HP info
  228. swapping motors
  229. #8 heads......doorstops?
  230. Engine struggling noise
  231. Total noobie wants more power,
  232. Quite a bit of smoke from the valve cover
  233. CAR WONT RUN FOR LONG
  234. wheel question
  235. warning
  236. Carb problem?
  237. 403 Alternator/PS brackets diagram
  238. Young Owner Just Curious
  239. Carb question
  240. carbs fits a 350 2brl?
  241. whats wrong in the picture
  242. 403 or 350? Which one?
  243. 330 250hp? 400 cid ?
  244. '68 350 Hp and Torque mods
  245. The Pictures I promised, and more !
  246. Valve covers
  247. new to olds motor
  248. 74 cutlass vacuum diagram
  249. Compression Ratio
  250. Pushrod not seating properly??
