71 350 Performer Intake fit?
Old Nov 3, 2024 | 07:03 PM
GARDO71's Avatar
I’m rebuilding my 1971 350 Cutlass motor. Purchased a used Edelbrock performer intake. The mating surface is flat but when I did a dry fit the front and back sealing area is not even. I plan to use gasket maker there instead of rubber seal. Do I have a bigger problem with the manifold and do you see a problem with using gasket maker in the opening?
Old Nov 4, 2024 | 07:04 PM
The critical sealing surface is at the heads. So long as those are both parallel to the head intake surfaces, the mate to the block doesn't matter. Use enough RTV to ensure the gap is filled when you set the manifold down.
arodenhiser
Nov 30, 2012 06:25 AM
dallasite21
Dec 6, 2011 03:00 PM
rkk69olds
May 3, 2011 05:00 PM
montyman71
Jan 19, 2011 07:14 AM
Kidcutty
Mar 25, 2010 09:29 PM
