Olds 307 Idling Fast and dieseling issue.
Old Sep 23, 2024 | 06:35 PM
Offcolorpepper's Avatar
I just rebuilt my CCC Quadrajet on my 1984 98, and now it's idling Extremely fast. (I don't have an RPM gauge or tool) The engine runs amazing, no shakes or stutters, but the second it gets put into Neutral or park, it revs up and idles really high. I've gone through everything I can think of. Messed with both idle screws but they haven't changed anything,(All screws except for those are in factory positions. I don't see or hear any vacuum leaks, and all parts on the carb seem to be running how they should. I assume the Dieseling is caused by the high idle as well, but the car has sat since 94, so I know there's carbon build up stuck in there.
Any help woukd be greatly appreciated, thank you.
Old Sep 23, 2024 | 07:19 PM
Sugar Bear's Avatar
Is the choke blade opening completely when it is warm?
Old Sep 24, 2024 | 05:29 AM
Yes, when the car is warmed up the flaps fully open
Old Sep 24, 2024 | 05:35 AM
You won't be able to tune your CCC Quadrajet without a factory service manual and tach/dwell meter. I think @joe_padavano posted CCC tuning pages in the past. Hopefully he contributes to the thread soon.
Old Sep 24, 2024 | 06:54 AM
Sugar Bear's Avatar
Check that the high idle cam on the right side of the carb between the choke thermostat housing and the carb mid-section is dropping down to the lowest step when the choke blade is fully open.
Old Sep 24, 2024 | 10:31 AM
The only way to adjust the idle mixture screws is using either a scan tool or a dwellmeter to read the duty cycle of the mixture control solenoid. The idle speed can be affected by three things - the fast idle screw on the choke linkage, the curb idle screw, or the Idle Load Compensator. If you don't have a factory Chassis Service Manual, get one. The computer-controlled carb on these cars MUST be adjusted following the factory procedure exactly.
Old Sep 25, 2024 | 07:55 AM
Update
So it turns out the secondary throttle flaps on the bottom of the carb were not on just right
they were stuck open
Old Sep 25, 2024 | 09:03 AM
Glad you found the problem.
jondoom
Sep 7, 2024 01:25 PM
Byron
May 23, 2023 02:53 PM
cutsupreme72
May 16, 2014 06:28 PM
AZ455
Nov 3, 2011 06:24 AM
coltsneckbob
Aug 21, 2010 04:34 PM
