84 LeSabre with a 307, racing idle. Where to start?
I've recently noticed the idle on my Olds equipped LeSabre is racing when in park, since the car has no tach it's hard to say what it's going up to but it's clearly louder than one would expect at idle. I'm not even sure what carb GM put on these cars from the factory. I know it's a Rochester(?) but what model? What are some things I should look at to see why it's racing. I don't know if trying to adjust the idle on the carb would solve anything since it's probably some type of vacuum source causing the issue?
I've also started to look at EFI systems to get rid of all the emissions and vacuum lines GM decided to add to these cars. If I was to go with a Holley Sniper EFI, which style carb mount would I need?
You will need an adapter or the Quadrajet Sniper. The Sniper 2 with an adapter may be the best bet. The bolt on EFI have issues as well, some no issues, otherwise many. A custom tuned non computer Qjet and regular HEI distributor, most cheap ones are decent now, is also an option.
