What year for my 330ci ?
Old Jan 4, 2025 | 11:12 AM
Elroots33's Avatar
Hello,
Could you tell me what 330ci I got and how can I do to know exactly its year of production ?
The code found on the front of the right hand cylinder head is T606607.
T for the year, either 1964 or 1965 but I didn't find exactly if it's 64 or 65 because I don't know if it's a 230hp (8.75:1) or a 250hp (9:1)
Thanks for your help !
Old Jan 4, 2025 | 11:16 AM
2blu442's Avatar
If it has a large #1 cast by the #1 and #8 spark plugs its a 1964. If #2 then 1965, #3 is 1966 and #4 is 1967. That's the easiest way to tell as long as the heads are original to the engine.
Old Jan 4, 2025 | 11:18 AM
2blu442's Avatar
Here is an old thread with photos of what I'm describing.
​​​​​​https://classicoldsmobile.com/forums...hipping-90568/
Old Jan 5, 2025 | 12:52 AM
Olds started using the #2 heads very late in the 1964 model year.
Intake casting numbers will also help identify the model year.
Old Jan 5, 2025 | 09:54 AM
Elroots33's Avatar
Could you give me some more precisions about where may I look on the intake manifold ?
And where I can find informations when I got these casting numbers ?
Old Jan 5, 2025 | 10:00 AM
Elroots33's Avatar
Do you know what months of the end of 1964 are concerned by the application of the #2 ?
Old Jan 5, 2025 | 10:14 AM
The casting number on 330 intakes is usually located on the runner behind the carb. Post a photo.
Old Jan 5, 2025 | 10:49 AM
Old Jan 5, 2025 | 11:16 AM
Elroots33's Avatar
Thanks a lot Joe, but, when I know this number, where can I find correspondences with the year ?
Old Jan 5, 2025 | 11:42 AM
I have a list. Again, post a photo of the number.
Old Jan 5, 2025 | 12:41 PM
Sugar Bear's Avatar
Model year '64 would have the lower radiator hose on the left side of the car. '65 on up would be on the right side.
Old Jan 5, 2025 | 03:20 PM
Elroots33's Avatar
Mine is on the right, so, '65 on !
Old Jan 6, 2025 | 10:02 AM
Elroots33's Avatar
Here is my intake manifold and its number !
Old Jan 6, 2025 | 10:05 AM
Elroots33's Avatar
And the big "2" on the cylinder heads !
Old Jan 6, 2025 | 10:11 AM
Both heads and intake are 1965. Your #2 heads have the unique 3/8" rocker studs and matching rocker pivots. Those are one-year-only.
Old Jan 6, 2025 | 10:18 AM
Elroots33's Avatar
Thumbs up
Thanks a lot, guys !
Old Jan 6, 2025 | 11:14 AM
Sugar Bear's Avatar
That is a two barrel intake. Could that be high compression or low compression, or low compression only?
Old Jan 7, 2025 | 10:29 AM
Elroots33's Avatar
That is the question !
Old Jan 7, 2025 | 11:15 AM
The only 330 2bbl motor offered in the 1965 A-body Oldsmobiles was the RPO L65 motor with 250 HP and 9.0:1 CR. The Jetstar 88 that year came standard with a 10.25:1 CR 2bbl version of the 330 that was rated at 260HP. The L65 was optional in the J88.
Old Jan 7, 2025 | 11:26 AM
Sugar Bear's Avatar
Thanks Joe, Did compression ratios or horsepower ratings vary for export?
Old Jan 7, 2025 | 11:33 AM
Good question. I'm showing 9.0:1 as the lowest CR for domestic production, but I'll have to dig up the export numbers.
RAG
Sep 7, 2015 09:10 AM
therobski
Cars Wanted
Oct 28, 2014 06:25 PM
1k442
Feb 2, 2012 10:45 AM
f3chuck
Cars Wanted
Dec 11, 2008 12:00 PM
monzaz
Oct 16, 2008 01:18 PM
