64 Cutlass 330 4v engine rear seal
Hi, did the 64 330 motor have a rope rear seal? (engine is original never touched since bought in 64)
Now since I'm changing out the oil pan without pulling the engine (have more than enough room)
Figured I might as well replace Rear Seal wondering do they make a Neoprene Seal for a 64 330 ? Instead of a rope
alsmith787
alsmith787
Yes it was a rope seal. If it is really dry consider leaving it alone. If you didn't already do so, having the oil pan off makes replacing the timing chain easier. Look deep inside the oil screen pickup for debris while the pan is off.
