455 Rear Main Seal
As for changing the seal with the engine in the car , its a real challenge. The transmission would need removal. One of the motor mounts would need to be loosend to remove the oil pan. Probably best to replace the seal with the engine out of the car. But thats my opinion on how to do it.
Have used the Ford seal at least 4 times. To do it right, the crank should be polished good. The last one I put in, while having the crank turned, I also had the Kneals removed. I have also installed as is and had no problem.
