Exhaust Valve Spring Part No. - 7a Heads
Old Jan 27, 2024 | 03:42 PM
Tom Canfield's Avatar
Hello Everyone,
Today I found a broken exhaust spring on my 350 that has 7a heads (subscript 'a', so 1972 I believe). The spring has a damper inside it, as well as a valve rotator.
I am trying to find the correct stock replacement spring, but everyone I find is listed as 1964-1971, so I am not sure if is it same...
Does anyone here have access to a resource that could tell me what the correct part number is for a stock exhaust valve spring?
Thank you!
Old Jan 27, 2024 | 07:12 PM
Here’s a listing. I don’t know the dimensions to ensure this is what you’re looking for.
https://www.rockauto.com/en/catalog/...ve+spring,5792
Old Jan 28, 2024 | 06:12 AM
Originally Posted by Tom Canfield
Hello Everyone,
Thank you!
The factory part number in the January 1972 parts book is different for 1972 vs 1971-down. OEM part number for the exhaust valve spring with damper is 411225, which is also shown as correct for both valves on the 1972 455 motors. Having said that, the May 1980 parts book shows 411225 as superseding pretty much every spring on earlier engines. There are several NOS 411225 springs on ebay, and the application years are all over the map. Ignore that and just search by part number.
Old Jan 28, 2024 | 07:28 AM
Oh perfect, I was hoping that was the case. Thank you for the info! Much appreciated!
Old Jan 30, 2024 | 10:59 AM
BillK's Avatar
Tom,
If you cant find an oem one you can use an Eloy 160-1006 Your machine shop should be able to get it for you.
Old Feb 5, 2024 | 11:16 AM
68post's Avatar
I would replace all the springs, dampeners, seals, and locks. Springs break from fatigue. We replace springs on garage doors nearly everyday and the side that didn't break is just as "used" as the broken one and on the short list of lifespan !
71OldscutlassS
Aug 11, 2024 07:11 AM
pmathews
Apr 1, 2023 02:37 PM
2blu442
Jun 1, 2018 06:58 AM
Seff
Aug 19, 2011 06:11 PM
cts-v
Feb 28, 2009 09:05 AM
