Diameter? -> Valve Spring Shims (Inserts)
Old May 2, 2021 | 01:47 PM
pmathews's Avatar
Question Diameter? -> Valve Spring Shims (Inserts)
Hey guys, I've been searching all over the forums and internet for the dimensions for valve spring shims (a.k.a inserts), and could use a little help.
From an old Elgin catalog, I am looking at part number VSA303HP -> OD = 1.480", ID = .703", Thickness = .060"
Is that the correct OD and ID? I am running stock Olds 330 #4 heads.
Thanks!
Old May 4, 2021 | 06:49 AM
Run to Rund's Avatar
The valve springs are 1.43" OD. Measure the diameter of the factory cups for max OD, and the diameter of the guide bosses for ID. I recommend hardened spring shims or "locators" from Comp Cams, etc. as the spring dampeners cut into soft shims.
Old May 5, 2021 | 11:46 AM
pmathews's Avatar
Thanks for the measurements, I think the 1.48" ones should work (.050 larger OD), but I was also trying to get the ID dimensions without removing a valve spring from the engine. Worst case, I can do that, but was hoping that someone had a part number or maybe an ID measurement of the guide boss?
Old May 5, 2021 | 01:43 PM
Bernard Mondello's Avatar
We have these spring shims in stock @ $1.50 each shim!
These are heat treated 1.480 X.705 .060 thickness...
Thank you,
You can contact us at Bernard Mondello Racing Enterprises to order... 1- 951-371-1432
bernardmondelloracing.com
Old Apr 1, 2023 | 02:37 PM
Jeff Stout's Avatar
Shim under springs. 3x .060 thick shim will do the trick.
foo
Jun 12, 2017 04:45 PM
L77F85
Dec 25, 2013 10:12 AM
Railguy
Nov 9, 2013 03:27 PM
Seff
Aug 19, 2011 06:11 PM
projectheaven
Jul 22, 2008 07:54 PM
