Olds 403 Help
Old Nov 20, 2024 | 08:22 AM
79Lucille's Avatar
Olds 403 Help
Hey everyone, I'm new around here but I'm looking at trying to get some power in my 403 that's in my 79 Formula without breaking the bank. If anyone has a good place to start my list, that would be greatly appreciated.
Old Nov 20, 2024 | 10:11 AM
69CSHC's Avatar
True dual exhaust in conjuction with swapping the factory 2.41 rear to a 3.42 rear.
It will feel like a completely different car.
Old Nov 20, 2024 | 12:13 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
X2 on the dual exhaust and better rear gear. A little higher stall torque converter will also help launch off the line. If you don't like 3000 rpm highway speeds, a TH2004R is also a best of both worlds. Bolts right in place of your TH350 but will need mild modifications to live with a stock 403. The 2.74 first gear, minimum 1900 stall converter and .68 overdrive gear make for much more fun driving.
Old Nov 20, 2024 | 07:30 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Welcome. Nice bird.
Along with the above mentioned mods consider super tuning what you have before throwing parts at it.
But first make sure all safety items are up to the task. Tires older then 10 should be replaced. Rubber brake and fuel lines should be replaced. Chassis components should be inspected and replaced as needed.
Look for any vacuum leaks due to aged hoses, loose throttle shafts on the carb etc...
Service the entire car...Replace/flush ALL fluids...yes... brake, power steering, trans, rear dif...et al. Use the correct replacement fluids. Not one size fits all garbage.
Tune the 3 ignition timing events...base timing, vacuum and centrifugal advance.
Give it as much base timing as it will tolerate. Ignore the factory suggested setting.
Use good ignition wires say Taylor spiral cores and NGK plugs.
Adjust the air fuel mix to achieve the highest vacuum signal possible.
Next study up on how to "super tune" a Rochester Quadrajet...if its still there.
Make sure the carb is fully opening you depress the gas pedal.
Use ethanol free higher octane gas.
Verify the fuel and air filters are clean.
Reduce the heat under the carb by installing an insulation/isolation gasket and fully or partially block off the heat riser crossover.
Rebuild vs replacing worn parts. Especially if the parts are original. Steer clear of big box chineasium parts houses parts. Source USA made when ever possible. Find a good Pontiac restoration supplier.
Old Nov 21, 2024 | 06:17 AM
79Lucille's Avatar
Thank you everyone for the information so far! I have learned so much in the past 24 hours!
Old Nov 21, 2024 | 11:30 PM
brownbomber77's Avatar
If it's currently running and driving, leave it except basic tune up stuff (Carb, wires, plugs, distributor, timing chain). You're in California so what are your restrictions on exhaust? If you can put headers on it that's an easy 15hp. A rear gear change would make a night and day difference in the car and won't have to worry about anything emissions related. 3.23 or 3.42.
Using an Edelbrock performer or a 307 A4 intake manifold would take off 25lb from the front end. I see you don't have the shaker hood so you could use a Performer RPM.
If you're willing to spend more ($2k or so) for another probably 50hp, keep reading.
Cylinder heads, 330 have the smallest chambers but once again goes into if you must have the EGR tubes. If you don't have to worry about that, #3, #4, #5, #6, #7 or #7a bolt on with the head bolt holes drilled to 17/32 and should bump your compression to ~8.5:1 instead of 7.9. Replace the valves with 2.07.1.68.
Swap in a better camshaft. I think Mark's (CutlassEFI) favorite is an Erson TQ40?
Old Nov 22, 2024 | 05:06 AM
79Lucille's Avatar
I've currently got it registered on historic plates in MD, so no inspections. I've been reading many good things about Edelbrock's intake manifold along with the many options for heads. I've just been having trouble finding a set of 7A's in the area. Thank you for the help!
Old Nov 22, 2024 | 12:32 PM
Sugar Bear's Avatar
Start with a leak down or compression test to determine engine condition, check the timing chain for excess slack and check for a nylon cam gear.
Old Nov 22, 2024 | 10:32 PM
You'll have to ream out early 350 head bolt holes to work with 403's 1/2" head bolts but a competent machine shop can do that. 77-later 350 have 1/2" head bolts but your only option with those are #8s which are smog heads and realistically no better than the 4As you have.
#8 heads are still a 7/16 bolt hole. The solid main blocks go all the way up to '76.
Old Nov 22, 2024 | 10:38 PM
Why do you need 7A heads specifically? 5, 6, 7, and 7A (69-72) heads are nearly identical and generally the same price and availability.
Can use #3, or #4 330 heads as well and have a little bit smaller combustion chambers.
Any factory head worth installing will require head bolt holes to be drilled to 17/32 as well as the dowel pin hole opened to 5/16 (?) if I remember correctly.
Additionally, any parts store replacement head gasket is .024" thicker than the factory. Recommend cutting whatever cylinder head you use around that much to make up the difference so you don't lose any compression.
Old Nov 25, 2024 | 06:41 AM
79Lucille's Avatar
I've just read the most about those in particular, but I'll read up more on the other heads. All of this information excites me, thank you!
Old Nov 25, 2024 | 06:43 AM
79Lucille's Avatar
Open up the exhaust and go a little deeper gear if you can and you'll be surprised what that smogged fury 403 can do. A good non-EGR intake that will accept your current QuadraJet will help too.
I like the idea of a California boy having interest in performance cars 😈.
DK how the NA leave policy works, but connect with Joe Padavano on here to find out when the Capitol City Rockets in NoVA meet. There's also National Capital Area Pontiac Oakland Club chapter in the DC area. Either of those groups might be helpful.
Thank you! I'll have to connect with him, it is nice having the weekends to drive around and do what I can to my Firebird before it's time to go back.
Old Nov 26, 2024 | 05:51 PM
71ramrod's Avatar
7a heads have hardened valve seats (allegedly) otherwise they’re all similar from 4-7. Compression is going to be weak link. It will limit your cam choices and overall performance. So heads should be first on the list. I wouldn’t waste any time on the Quadrajet or any Edlebrock. Go for a Holley and you’ll have the adjustability you’ll need to keep it running right. You might get 10hp from a true dual exhaust but without the heads to let the exhaust out you aren’t getting full potential of the exhaust. You could easily get 30hp from heads and a cam.
Old Nov 26, 2024 | 07:16 PM
Sugar Bear's Avatar
Learned this from JoeP, the hardened seats are induction hardened at the factory vs. a hardened insert and that grinding the valve seat removes the induction hardened surface so your right back where you started. At that point hardened inserts are needed.
Someone that knows correct me if I'm wrong on this.
Old Nov 27, 2024 | 05:08 AM
True on both accounts but consider how long it takes to sink a valve. I've never actually seen a sunk valve in an Oldsmobile in the couple hundred I've disassembled in the last 20 years. Limited experience, sure, but as little as these cars are driven, you'll be fine without steel insert or hardened seats.
Old Nov 27, 2024 | 07:40 AM
Sugar Bear's Avatar
Thanks for the confirmation bb77...was trying to guide the OP to not go on a long search for heads with factory hardened seats such as 7a's when there are other good options available.
DR_DAN
Aug 18, 2024 04:24 PM
GIDave
Jan 3, 2024 05:33 AM
illumined
Nov 16, 2023 06:47 AM
88hurstolds
Feb 22, 2016 02:53 PM
kenny
Oct 1, 2009 04:58 PM
