Cam Recommendation for stock '68 L74 4 bbl Motor
Old Sep 18, 2024 | 10:05 PM
adpostel's Avatar
Since there are so many better grind cams out these days, what is a good recommendation for a '68 350 Hi-Compression Motor with the #5 Heads. Assuming everything is stock and just getting freshened up but wanting to go with a better grind than stock. It is an original 4 bbl with Hedman headers and dual exhaust. My limited research shows that motor to be a 10:1 - 10.5:1 motor which should yield some pretty decent HP for a weekend driver. Running a TH350 w/ a mild stall converter and haven't checked the gears yet, but would want 3:08 or similar gears in the end... Thanks
Old Sep 18, 2024 | 10:21 PM
Have the heads been off, and aftermarket head gaskets installed? Asking because the factory claimed 10.25:1 compression ratio, but in reality it was just under 10:1. This was with the factory steel shim head gaskets that are 0.017” thick. Using thicker aftermarket gaskets in the 0.040” thick range will reduce the compression a bit more.
So with that said, upper 9.xx:1 compression ratio is likely.
Old Sep 18, 2024 | 11:43 PM
adpostel's Avatar
Yes, heads are off and will likely just be cleaned up and reinstalled. I am aware of the thicker head gaskets and it affecting the CR, but all things considered, this was likely one of the best years, as far as combination and HP rating of the Oldsmobile 350... That being said...
1) Are there any other options for head gaskets besides the Fel-Pro?
2) What would be a "better" cam than stock for this combination? Stock pistons, stock heads, stock rods, stock valves... May get a cam, lifter, spring combination if available... Just wanted to get the opinion of more experienced Oldsmobile enthusiast...
Old Sep 19, 2024 | 05:33 AM
cutlassefi's Avatar
Yes, Cometics which come in .027 thick if desired.
Cam choice will depend on the rest of the combo, as well as your wants and needs.
I offer various grinds for various combinations once you’ve finalized your combo.
Old Sep 19, 2024 | 06:14 PM
adpostel's Avatar
Oh Lort!!! Today was a fiasco! I’ll be contacting you early next week… Thank you
Via3d
Oct 16, 2018 07:24 PM
Almond900
Aug 26, 2016 08:09 PM
Qwik71442
Nov 28, 2015 02:26 PM
Jannebill
Jan 25, 2013 12:56 PM
olds382
Nov 11, 2008 11:47 AM
