Cam recommendation for new motor
Old Aug 24, 2016 | 04:46 AM
Almond900's Avatar
I am looking for some cam recommendations for my new motor, 70 455 block .030 over, silvo-lite 1631-030 pistons, 4bbl cast iron intake, w&z exhuast manifolds and C heads with hardened seats and air bumps removed, so basically pretty much stock I guess, currently I have stock converter, th350 and 2:73 open, I'm hoping next year to go to 3:23 or 3:42 and 2000 stall, but the trans and rear just are not in the budget now. I just drive the car on the street, not at the track. Looking for a recommendation on a good cam to run that is fairly reasonable, the budget is pretty tight now seeing this is motor #2 for the year
Old Aug 24, 2016 | 04:57 AM
svnt442's Avatar
The trans, converter and gear will play a big difference in how the car runs with a particular cam. So as long as you can deal with some "sluggishness" for now until you get all of that sorted out then you should be fine.
Something like this would probably be what you are looking for with your end plans.
http://www.pbm-erson.com/Catalog/Ers...t_E/ERSE540222
Old Aug 24, 2016 | 05:37 AM
wr1970's Avatar
Not a bad choice for what the op has.
Old Aug 24, 2016 | 04:39 PM
george landis's Avatar
cam
Is the Erson TQ40 really 220/280 @ .050? Seems high on the exhaust?
Old Aug 24, 2016 | 05:24 PM
Firewalker's Avatar
Isky 264-MEGA HYDRAULIC
It has a 108 LSA and about 215 duration at .050
or
http://highperformanceolds.com/phpbb...php?f=3&t=5201
Common cam from many sources and may even be found at Rock Auto for under $40. Depends on what you want.
Old Aug 24, 2016 | 10:13 PM
svnt442's Avatar
No, it's 228 @ .050. It's a misprint that needs to be addressed.
Old Aug 25, 2016 | 08:18 AM
70cutty's Avatar
Beer Connoisseur
Mark (cutlassefi) is a cam guru, he has helped many with their cam selection.
Old Aug 26, 2016 | 07:44 PM
Almond900's Avatar
What would be better, 108 lobe separation or 110 lobe separation? I like torque, and if I'm understanding correctly, the 108 would give me more torque
Old Aug 26, 2016 | 07:57 PM
Firewalker's Avatar
Right you are, but as you narrow the LSA you increase the overlap, and so will lose some vacuum, so to keep the overlap from growing you decrease the duration slightly, but that give you even more torque. And if you have a 2000 stall converter and lower compression, with a high geared rear, that should do the trick and give you more torque where you actually need it.
Old Aug 26, 2016 | 08:00 PM
Almond900's Avatar
The converter and gears will be next year, i'll finish out the year with stock converter and 2:73's is a Howard's cam decent? I found 1 online with almost the same specs as the erson cam only Howard's is 108 and erson is 110
Old Aug 26, 2016 | 08:09 PM
Firewalker's Avatar
I would guess it should be fine as long as you keep the duration numbers short. You may or may not change out the gears and converter next year. Things work out that way many times.
Now, if you do want to you might consider changing to a 700r4 next year, with only about a 2000-2200 and something stall.
tru-blue 442
Mar 30, 2022 09:53 AM
kevdog442
Sep 19, 2015 05:50 PM
Cman7713
May 18, 2015 06:37 AM
tomngary
May 11, 2013 05:29 PM
442garage
Oct 20, 2008 10:25 AM
