I been chasing a vacuum problem on my 1984 olds 98 that I swapped a ‘72 350 rocket into. When u press the brakes the car dies. I pulled the brake booster vac line off with the car running and when the line is open the car runs a lot better and if I put my thumb over the hole and plug the line it runs bad again. Is this a normal phenomenon or does this indicate the booster is bad or does this indicate there’s a problem somewhere else in the vacuum circuit
if I put it in gear and hold the brakes and tap the throttle a couple times it still wants to die tho
Typically, with the line disconnected and open there’s a massive vacuum leak which should affect the engine operation. Plugging the line with your thumb should make the engine run better. Since the engine runs better with the vacuum leak, there apparently is an issue with the carburetor air/fuel mixture. Letting more air in through the vacuum leak causes the air/fuel mixture to be better than without the vacuum leak. That’s about all I can say from the information presented.
If an open vacuum line causes it to run better most likely it's running way too rich. Either disengaging the choke doesn't fully take it off choke or there's some adjustment problem causing not enough air for the amount of fuel. That's my take anyway, not an expert.
It doesn’t make sense to me either I’ve taken every vacuum line and put smoke to them. Unplugged them all and capped em. Sprayed around the carb and intake with carb cleaner and still can’t figure out where I’m losing vacuum. Is it possible for a Holley carb to leak vacuum internally?
The swapped/installed Olds 350 Rocket has an Olds iron intake manifold or something different? You have the proper Holley square bore>spread bore adapter & correct gasket?
But you said the engine runs fine with that hose open, which is a huge vacuum leak, and the engine stalls when you plug it, which is no vacuum leak.
yeah that is true but it doesn’t make sense cause either way w the line plugged or plugged into the booster or open if u put it in gear and hold the brake and hit the throttle a couple times it dies
I can drive the car if I press the gas and the brake at the same time when I’m comin to a stop. Otherwise if I’m not on the brake it accelerates and runs like it should
Could be the power valve in your Holley carb has a blown diaphragm. When this happens it will be pig rich at idle. Has there been any backfires through the intake before it started running bad. A good backfire is what usually ruptures the diaphragm.
no backfires that I know of but I did buy this carb used off marketplace after I realized the 850 double pumper I bought was gonna be too much
I also noticed if I turn the steering wheel all the way to the lock the car wants to die too so that leads me to believe that it’s the extra load on the engine of the vacuum booster that’s killing the car and not a vacuum leak somewhere
I threw the 850 double pumper back up there for ***** and gigs and it no longer dies when u press the brake so it must be something else inside that other carb that’s causing the condition
