More vacuum questions 350 swapped olds 98
Old Sep 14, 2024 | 03:21 PM
deltsanddueces's Avatar
I been chasing a vacuum problem on my 1984 olds 98 that I swapped a ‘72 350 rocket into. When u press the brakes the car dies. I pulled the brake booster vac line off with the car running and when the line is open the car runs a lot better and if I put my thumb over the hole and plug the line it runs bad again. Is this a normal phenomenon or does this indicate the booster is bad or does this indicate there’s a problem somewhere else in the vacuum circuit
if I put it in gear and hold the brakes and tap the throttle a couple times it still wants to die tho
Old Sep 14, 2024 | 04:19 PM
Typically, with the line disconnected and open there’s a massive vacuum leak which should affect the engine operation. Plugging the line with your thumb should make the engine run better. Since the engine runs better with the vacuum leak, there apparently is an issue with the carburetor air/fuel mixture. Letting more air in through the vacuum leak causes the air/fuel mixture to be better than without the vacuum leak. That’s about all I can say from the information presented.
Old Sep 14, 2024 | 07:10 PM
illumined's Avatar
1978 Ninety Eight
If an open vacuum line causes it to run better most likely it's running way too rich. Either disengaging the choke doesn't fully take it off choke or there's some adjustment problem causing not enough air for the amount of fuel. That's my take anyway, not an expert.
Old Sep 15, 2024 | 03:01 PM
It doesn’t make sense to me either I’ve taken every vacuum line and put smoke to them. Unplugged them all and capped em. Sprayed around the carb and intake with carb cleaner and still can’t figure out where I’m losing vacuum. Is it possible for a Holley carb to leak vacuum internally?
Old Sep 15, 2024 | 03:18 PM
Why do you think there’s a vacuum leak? We’re saying the carb may be running too rich.
Old Sep 15, 2024 | 03:40 PM
because the car runs ok until u hit the brakes and use the vacuum up in the booster and then it dies
Old Sep 15, 2024 | 03:42 PM
The swapped/installed Olds 350 Rocket has an Olds iron intake manifold or something different? You have the proper Holley square bore>spread bore adapter & correct gasket?
Old Sep 15, 2024 | 05:16 PM
But you said the engine runs fine with that hose open, which is a huge vacuum leak, and the engine stalls when you plug it, which is no vacuum leak.
Old Sep 15, 2024 | 05:27 PM
yeah that is true but it doesn’t make sense cause either way w the line plugged or plugged into the booster or open if u put it in gear and hold the brake and hit the throttle a couple times it dies
I can drive the car if I press the gas and the brake at the same time when I’m comin to a stop. Otherwise if I’m not on the brake it accelerates and runs like it should
Old Sep 15, 2024 | 06:38 PM
You should have a rock steady vacuum between 17"Hg - 21"Hg for a stock 350cid. What is the vacuum reading @ idle (all vacuum hoses connected)?
The 1st test (upper LH side of chart) must be able to be passed flawlessly.
Post #7 answers?
Engine should pass this test flawlessly.
Vacuum gauge reading should be rock steady - no bouncing around - very steady.
Old Sep 15, 2024 | 07:00 PM
it’s a edelbrock intake w the correct gaskets
Old Sep 15, 2024 | 07:02 PM
Post #7 answers?
I need to get a vacuum guage
Old Sep 15, 2024 | 07:19 PM
There was a point in time where this car ran good with this exact configuration
Old Sep 15, 2024 | 07:35 PM
gs72's Avatar
72Cutlass S
Could be the power valve in your Holley carb has a blown diaphragm. When this happens it will be pig rich at idle. Has there been any backfires through the intake before it started running bad. A good backfire is what usually ruptures the diaphragm.
Old Sep 15, 2024 | 09:12 PM
no backfires that I know of but I did buy this carb used off marketplace after I realized the 850 double pumper I bought was gonna be too much
Old Sep 16, 2024 | 04:31 AM
Rather than guess....which Holley model is installed?
Old Sep 16, 2024 | 07:07 AM
it’s a 750 w/ vac secondaries
Old Sep 16, 2024 | 08:21 AM
You have a 4160? What is the Model Number? Why is this a difficult question?
Old Sep 16, 2024 | 09:37 AM
it’s not a hard question
ill have to look when I go home. I bought it used off fb marketplace so I don’t know the model
Old Sep 16, 2024 | 09:43 AM
Fair enough.
Old Sep 16, 2024 | 03:17 PM
Should be really simple to determine as the LIST number is right on the air horn.
Old Sep 16, 2024 | 03:32 PM
This is what I got
Old Sep 16, 2024 | 03:49 PM
https://www.carburetion.com/CarbNumb...Number=R3310-5
Model H4-4160
750 Vacuum Secondary
https://www.carburetion.com/_aspstuf...p?part1=125-65
Power Valve 125-65
Old Sep 16, 2024 | 05:21 PM
if I pull the power valve out of the carb how can I tell if it’s bad or not
Old Sep 16, 2024 | 05:35 PM
And, as Gary suggested, if the PV diaphragm is faulty, it will run pig rich.
Old Sep 18, 2024 | 06:50 PM
I changed the power valve in the carb and no dice
I also noticed if I turn the steering wheel all the way to the lock the car wants to die too so that leads me to believe that it’s the extra load on the engine of the vacuum booster that’s killing the car and not a vacuum leak somewhere
Old Sep 18, 2024 | 07:50 PM
I threw the 850 double pumper back up there for ***** and gigs and it no longer dies when u press the brake so it must be something else inside that other carb that’s causing the condition
deltsanddueces
Sep 12, 2024 10:35 AM
deltanephew
Jun 5, 2024 08:05 AM
WearnWrals
Vista Cruiser & Wagons
Feb 6, 2023 12:05 PM
Ekohler
Brakes/Hydraulic Systems
Dec 6, 2021 08:24 AM
ivmachine
Aug 28, 2018 09:09 PM
