Radiator Confusion
Old Feb 10, 2024 | 01:21 PM
smparr's Avatar
Radiator Confusion
I have a 1990 Oldsmobile Custom Cruiser with the Y code 307 V8. Everywhere I look replacement radiators list a rad with a heater return line connection. My return line goes to the water pump on the 307 and also on my 1970 98's 455. Almost every Olds V8 I can find pictures of online also goes to the water pump except some 75-77 350s. Why would every available radiator listed have a return line connection? With that said, how do you plug it if I can't find the correct one? The other irritating thing is they all have a driver's side rear-facing drain ****. I much prefer the passenger-side down-facing one on the OEM rad, less mess when draining.
I thought of recoring the original rad but the driver's side tank has a pinhole leak and recoring is as much as, if not more, than a new one. I'm not looking at plastic tank ones only copper/brass.
Any hints at making these work or personal experience would be great.
Steve
Old Feb 10, 2024 | 01:49 PM
Sugar Bear's Avatar
Steve, The hose fitting on the rad makes it fit more applications and would need to be capped. I never liked them either. Can your tank be soldered?
Old Feb 10, 2024 | 02:26 PM
smparr's Avatar
The pinhole faces the fender about halfway down the tank. I think it's been there awhile but so small I never noticed. I thought it was paint damage so I had painted the spot but it's green now, leaks super slow. I don't know any rad shops so I would have to hunt around. How long do solder repairs last?
Old Feb 10, 2024 | 02:32 PM
Vendors only stock the more common Caprice radiator because they don't want the added cost of warehousing a second, low-demand part number. Use a silicone cap on that heater port. The crappy rubber ones will crack within a year.
https://hpsperformanceproducts.com/p...ete-black-blue
Old Feb 10, 2024 | 03:22 PM
Sugar Bear's Avatar
A solder repair by a radiator shop should last a very long time.
Old Feb 10, 2024 | 03:43 PM
smparr's Avatar
I guess I need to find a shop in the area. Replacing it will be a last resort.
Phoenix8990
Mar 18, 2022 03:10 PM
euroman1959
Oct 12, 2017 09:32 PM
69442C
Jan 19, 2011 04:57 AM
Bottoms
Oct 12, 2010 11:25 AM
cutlass47
Tech Editor's Desk
Oct 7, 2008 06:29 AM
