403 Frame Pad Suggestions
Old May 26, 2024 | 09:35 PM
illumined's Avatar
1978 Ninety Eight
I've been able to find the motor mounts for it very readily, frame pads on the other hand not so much. What have people here done to find one, or can I get away with the rusty crusty set that I have now?
Old May 27, 2024 | 05:54 AM
Frame pads don't wear out, so they are not normal replacement items. The correct pads need to match the FRAME, not the engine. Then, the rubber mounts need to match those pads, NOT the block. What is this engine going into?
Old May 27, 2024 | 10:19 AM
illumined's Avatar
1978 Ninety Eight
A '78 98. It sounds like I don't need to do anything with it other than clean them off. I didn't know they aren't a normal wear item, it just seemed like if I was going to replace them, then now while everything is out is the best time.
Old May 27, 2024 | 10:23 AM
The frame pads are solid metal. They don't exactly wear out. If that car came from the factory with an Olds gasoline engine, don't touch the frame pads. Use 2328 style motor mounts.
Old May 27, 2024 | 11:21 AM
illumined's Avatar
1978 Ninety Eight
It did. Ok, that's very helpful, thank you.
DR_DAN
Jan 11, 2024 09:49 AM
crank shaft
Apr 2, 2022 10:51 AM
tkcutlass
Nov 27, 2021 05:37 AM
76Supreme350
Sep 13, 2011 03:31 PM
78 omega 468
Aug 21, 2010 06:54 AM
