64' Cutlass 330 4v drain plug
Old Jul 30, 2024 | 07:42 PM
alsmith787's Avatar
Have a question 1964 olds Cutlass 330 4v oil pan drain plug the recessed 8pt plug what is the correct gm part number#
Also what is the oil pressure switch with no gauges just lights on the dash correct part number
Alsmith787
Old Jul 30, 2024 | 07:55 PM
Sugar Bear's Avatar
577646
Old Jul 31, 2024 | 06:46 AM
harleyrules's Avatar
A standard 1/2 drive rachet works to remove the drain plug. I also have the socket/tool for it. I'll look for the part number when I return home in a week if you don't get it before then.
Old Jul 31, 2024 | 12:53 PM
1965CutlassGuy's Avatar
9 thats what I mean 11
Old Jul 31, 2024 | 03:52 PM
The oil pressure switch is commonly available if you don't care about 100% originality. This switch is normally closed and opens at a pressure between 4-7 psi. ACDELCO D8050 fits just about every Olds made from 1955 through 1988. Standard Motor Products PS12, Echlin OP6619, and Duralast PS24 are all equivalent.
Old Jul 31, 2024 | 04:01 PM
alsmith787's Avatar
64 olds Cutlass oil pressure switch
Thanks Joe that was fast! Again you come thru might as well ask do you have the acdelco water temp sensor for my 64 got to thinking might as well change it too oh by the way the care has those dash idiot lights No Gauges
Thanks Again
👍It the best👍
REO442
Mar 10, 2024 10:39 AM
alsmith787
Jul 26, 2021 06:10 AM
Napoleon Solo
Dec 11, 2014 08:57 PM
Sarum
Dec 10, 2013 04:56 PM
gearheads78
May 8, 2008 07:27 AM
