330 V8 Engine Sump Plug
Old Dec 7, 2013 | 09:57 PM
Sarum's Avatar
Hi from New Zealand! Well I got the oil and filter sorted but when I crawled under my recently purchased 1965 Cutlass Sports Coupe with the 330 V8 I found that the engines oil sump plug is like no other I have seen. It is round and has what I think of as sun like with many small triangles sticking out. The tool or socket fits into this internal shape to remove the sump plug. Any idea what it is and where I could obtain the socket/tool?
Old Dec 7, 2013 | 10:17 PM
Sugar Bear's Avatar
That type of plug was factory in that era and when you take it out be careful because alot of oil comes out fast. Have read that there was a factory tool for this although I have never actually seen one. Have used a 1/2" square drive ratchet or breaker bar without an extension or socket, just the 1/2" square into the plug with great success on this style plug.
Old Dec 7, 2013 | 11:49 PM
Sarum's Avatar
Excellent, I wouldn't have thought of trying that for a while or if at all. Thanks for that.
Old Dec 8, 2013 | 03:57 AM
+1.
I answered your question 2 hours and fifteen minutes before you posted it here.
Old Dec 8, 2013 | 07:04 AM
Octania's Avatar
https://classicoldsmobile.com/forums...l-pan-nut.html
I have one of those 8-pt tools, by Bonney I think, but can't find the photo of it.
Wait, there's me photo in post #25 in the link above!
It appears to be a double square tool. Note that the points are all 90 degrees.
There are other 8-pt designs with different angled points.
Old Dec 8, 2013 | 09:58 AM
A 1/2" square drive should work. Just be aware that most 1/2" extensions have rounded ends and corners that might cam out of the plug recess.
Old Dec 8, 2013 | 10:23 AM
Octania's Avatar
In that event, you may fabricate a tool from a short pc of 1/2" square stock and a 12-pt socket that fits it properly.
Old Dec 8, 2013 | 02:30 PM
Sarum's Avatar
Originally Posted by MDchanic
+1.
I haven't had the chance to try the 1/2" drive head idea but the plug on my car looks nothing like the one's that have been pictured. It has maybe 30-40 small points radiating out in a circular fashion. It may well be that the correct tool doesn't "fill" all of the triangular bits so I will have another go and try the 1/2" drive but I wonder why Old's would create something more complicated than it needs to be. O.K I can here the laughter already!
Old Dec 8, 2013 | 03:03 PM
Originally Posted by Sarum
... the plug on my car looks nothing like the one's that have been pictured. It has maybe 30-40 small points radiating out in a circular fashion.
that does not sound like the original plug, which should look like this:
Here's a better picture, showing how the hole is actually two intersecting ½" squares:
Post a picture - maybe yours was replaced later by something completely different.
Old Dec 9, 2013 | 07:04 AM
I bow to the god of Photoshop...
Old Dec 9, 2013 | 07:20 AM
Either I have too much free time, or I'm not doing the things I'm supposed tone doing...
Wonder which?
Thanks, Joe.
Old Dec 9, 2013 | 05:53 PM
oldsboyDino's Avatar
I have a Bonney A 650 socket that a friend got for me on the internet. Before that I was using a 14 mm Mac tool Hex socket.
Old Dec 10, 2013 | 04:53 PM
Sarum's Avatar
Old Dec 10, 2013 | 04:56 PM
Sarum's Avatar
Awesome use of modern technology on old technology! You were quite right, when I got back under the car in better light and the car jacked higher The sump plug is as you have shown and the 1/2 inch drive worked a treat. Thanks for your help.Cheers
Napoleon Solo
Dec 11, 2014 08:57 PM
ds00469
Jan 25, 2014 05:12 PM
crjeeper
Apr 19, 2011 06:34 PM
ChrisM
Nov 1, 2007 02:23 PM
ztim
Dec 22, 2006 10:20 PM
