403 cylinder head number not matching intake?
I've been cleaning off the engine and now that enough of the sludge and dirt has come off I can read some of the lettering around the block. For example I noticed the number 6 on the head near the spark plug is below number 3 on the intake manifold. I know the numbers on the manifold are the cylinder numbers, but are the big numbers on the head next to the spark plugs also cylinder numbers, or do they represent something else?
https://oldsjunction.classicoldsmobi...sfaq/ofhed.htm
Number 6 heads are from 1970 and have 64cc chambers as opposed to the nearly 80cc chambers on the original 403 heads. This is a common swap to raise compression. What is the actual casting number on that intake?
Sorry Joe, I’ve never seen a set of 5’s, 6’s, 7’s, or 7a’s any less than 68. I think the 64 is an NHRA spec number right?
Its on the right hand
69oldscutlass
May 25, 2023 02:25 PM
