403 cylinder head number not matching intake?
Old Jun 17, 2024 | 09:12 PM
illumined's Avatar
1978 Ninety Eight
I've been cleaning off the engine and now that enough of the sludge and dirt has come off I can read some of the lettering around the block. For example I noticed the number 6 on the head near the spark plug is below number 3 on the intake manifold. I know the numbers on the manifold are the cylinder numbers, but are the big numbers on the head next to the spark plugs also cylinder numbers, or do they represent something else?
Old Jun 18, 2024 | 03:53 AM
BillK's Avatar
Those numbers and letters actually identify the cylinder head casting :
https://oldsjunction.classicoldsmobi...sfaq/ofhed.htm
Old Jun 18, 2024 | 05:56 AM
Number 6 heads are from 1970 and have 64cc chambers as opposed to the nearly 80cc chambers on the original 403 heads. This is a common swap to raise compression. What is the actual casting number on that intake?
Old Jun 18, 2024 | 03:30 PM
cutlassefi's Avatar
Sorry Joe, I’ve never seen a set of 5’s, 6’s, 7’s, or 7a’s any less than 68. I think the 64 is an NHRA spec number right?
Old Jun 18, 2024 | 05:07 PM
illumined's Avatar
1978 Ninety Eight
4A, but there's another number that seems to represent something else, on this side it's a 6 while the other side it's a 5. Here's a picture of what im talking about.
Its on the right hand
Old Jun 18, 2024 | 05:38 PM
Correct. 64 is the NHRA stock blueprint number. As-cast tend to be 2-6 cc over that.
Old Jun 19, 2024 | 12:16 PM
illumined's Avatar
1978 Ninety Eight
So what does the 6 refer to on the head, the number to the right of the 4A cast number? Is that supposed to indicate cylinder number?
Old Jun 19, 2024 | 12:20 PM
4A is the head casting ID, which is original to the 403. The 6 is likely a mold number and unrelated to casting ID. Your block and heads are matching.
Old Jun 19, 2024 | 01:55 PM
illumined's Avatar
1978 Ninety Eight
Ok, good to know it's not pertaining to anything important. Thank you.
69oldscutlass
May 25, 2023 02:25 PM
Jackthur7
Apr 1, 2023 04:36 PM
Doctor's Olds
Jan 24, 2021 08:49 PM
5998DownUnder
Ninety-Eight
Aug 15, 2012 09:06 PM
snylften
May 13, 2010 11:59 AM
