Replacement rocker arms and pushrod loose
Old Sep 30, 2024 | 05:42 PM
illumined's Avatar
1978 Ninety Eight
After setting this aside for a time to focus on other things on the car I was finally able to circle around back to it. There was an issue with 2 cylinder's having their pushrods loose. As a precaution to make sure there was no rocker arm or pushrod nonsense going on in the future I elected to replace all of them with appropriate brand new pushrods and rockers. I went to replace one set, I checked before removing and the original wasn't loose at all, very firm. After putting the new lived up pushrods in and new SBI rocker arm, I torqued it to spec.....and it was loose. Did I not install this correctly? There's no way it's a lifter issue but I'm really at a loss to understand what went wrong......
Old Sep 30, 2024 | 05:54 PM
Lifters bleed down over time, causing the pushrod to be loose. Don't look for a problem where there isn't one.
Old Sep 30, 2024 | 06:01 PM
Sugar Bear's Avatar
Did you compare the new pushrod length to the old, were they exactly the same?
Old Sep 30, 2024 | 06:30 PM
illumined's Avatar
1978 Ninety Eight
It's hard to tell but they look the same. The replacements I got are Mehling MPR-307, they're supposed to be direct fit stock replacements for small block Oldsmobile V8s.
Old Sep 30, 2024 | 06:32 PM
illumined's Avatar
1978 Ninety Eight
Thank you, this is good to know I didn't mess anything up. The engine was primed before putting it back in but it hasn't been started in quite a while.
maitrepathelin
Dec 27, 2024 08:37 AM
user 7408240824
Apr 22, 2020 06:46 PM
gibbo69olds
Apr 24, 2008 12:29 PM
CLAUSAKOCH
Apr 21, 2008 03:20 PM
