Wrong water pump gasket?
Hi all,
I've had water pump leaks before under pressure after an install - but today - the thing leaks just when I fill it before engine start. I must have screwed something up pretty good. Did I use the wrong gasket? The kit came with three but I picked the one I thought fit best. The only other issue might be the pitting on the timing cover. Wasn't terrible but was definitely there. I didn't use any additional sealant, just the dry gasket.
Whatta ya think? Thanks!
I had a heck of a time when I did the 307 in my Wife's Riviera. Turned out that the AC Delco pump I got was made wrong and would not seal ??? Do you have your old pump and gasket to compare to ?
I always use Permatex Aviation Form a Gasket on that type of setup.
If this is a 350 w/ac it is 99% the wrong gasket. I ran into the same issue. They give 3 gaskets and they all appear to be the same however there is a slight difference in the one that is needed for ac cars. The one that I used is a Felpro 35065. I had the exact same issue as you, leak in the same spot prior to start up. Hope this helps!
