Water pump gasket
Old May 2, 2023 | 10:56 AM
Bfg's Avatar
Bfg
Water pump gasket
Is a gasket sealant required for a replacement water pump
Old May 2, 2023 | 01:15 PM
Technically, no. If the sealing surface is less than perfect a little sealer won’t hurt. I use a very thin layer just to hold the gasket in place. It’s kinda hard to maneuver the pump around the balancer, hold the gasket in place, and start the bolts with 2 hands. Having the gasket stuck to the pump is a big help.
Old May 2, 2023 | 03:49 PM
svnt442's Avatar
I will use the copper spray for gaskets like this. I'm not a fane of silicone with a gasket because it just tends to make a mess.
Old May 2, 2023 | 09:13 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Use the spray tack/glue on the water pump face. Then use a thin layer THIN LAYER on the engine side. You will thank me at the next pump removal.
I do the same with most gaskets including the valve covers. The gasket comes right off the bigger part...the engine and stays with the removed part making cleaning and reapplication much more professional.
rogiestone
Mar 22, 2020 03:34 PM
ReallyWildStuff
Non-Olds Engines
Feb 21, 2018 02:43 PM
1yesfan
Oct 7, 2015 07:58 AM
oldsonharmont
Jun 22, 2010 09:41 AM
