Cast Iron Ring Seating
Old Feb 7, 2024 | 03:53 PM
Jay_C's Avatar
Question Cast Iron Ring Seating
I have a fresh build 350 Olds, Flat tappet, Stock. Does anyone know the type of oil I should use for the seating process, I know Full synthetic is not good for it. Right now I have 10W-30 Conventional and a STP Engine oil treatment, though I am having second thoughts on that being in it. Thanks, John
Old Feb 7, 2024 | 04:32 PM
Nix the STP for the breakin. I use non-detergent straight 30w, perform the breakin and then change the oil and filter.
Old Feb 7, 2024 | 04:40 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Get actual break in oil, high ZDDP and designed for what you are doing.
Old Feb 7, 2024 | 05:11 PM
Jay_C's Avatar
When I first started it I used Sae 30 lucas break in oil, Should I just run that Its a high zinc or is there another brand that's better?
fleming442's Avatar
X2 on the specific break in oil
https://penngrade1.com/products/high-performance-oils/penngrade-1-break-in-oil-sae-30/
Old Feb 7, 2024 | 05:15 PM
Jay_C's Avatar
Old Feb 7, 2024 | 07:15 PM
Did you already perform the 20minute breakin procedure? If yes, then change the oil and filter using Valvoline VR1 10w30. Nothing extra is needed.
Old Feb 8, 2024 | 02:19 AM
Jay_C's Avatar
I already did the break in procedure and changed off of vr1 because the car still smokes
Old Feb 8, 2024 | 03:53 AM
BillK's Avatar
If the cylinder walls were properly machined the rings should almost be seated on the engine stand. Have you actually driven the car ? Putting a load on the engine will help finish the seating procedure. What rings did you use ?
Old Feb 8, 2024 | 05:16 AM
cutlassefi's Avatar
Also if the carb was rich during break in it will inhibit the process.
Engine needs to be loaded for proper break in.
And zinc is good for ring seal as well as cam longevity.
Old Feb 8, 2024 | 06:54 AM
Jay_C's Avatar
I haven’t gotten a chance to properly drive the car it’s been driven probably 5 miles and with idle time. I plan on it this weekend as I was waiting on a fuel pump
Old Feb 8, 2024 | 06:59 AM
Jay_C's Avatar
The rings were Hastings
Old Feb 8, 2024 | 08:18 AM
BillK's Avatar
Hasting rings are usually very quick to seat. Idle time is terrible on a new engine. Dont run it until you can drive it.
Old Feb 8, 2024 | 09:21 AM
Jay_C's Avatar
Alright thanks
Old Feb 8, 2024 | 10:35 AM
cutlassefi's Avatar
72 Post
Sep 11, 2021 05:32 PM
gbohr
Mar 7, 2019 11:45 AM
slade69
Apr 25, 2016 03:00 AM
Check6
Mar 11, 2014 07:33 AM
olds34dude
Sep 8, 2012 06:40 PM
