View Full Version : Parts Wanted
- 1972 Cutlass lower radiator shroud
- carone442
- Wanted 7040256 quadrajet carburetor
- Need bottom rear quarter panels from behind rear wheel to back of car. 70 Delta 98 LS
- '40s 8 cyl oil filter
- Oldsmobile Heritage Decals
- need 1977 delta 88 2 dr exterior trim piece
- WTB Rear Sheet Metal for 72 Cutlass Supreme
- wheels
- 1973 delta 88 drivers rear wheel opening molding needed
- Need one pair of NOS spiral rear shocks for a 70-442
- 1965, 98 convertible arm rest
- 1962 olds dynamic 88 heater motor sleeve
- Buick GS tips N 25
- 62 starfire gas tank
- gas tank straps 1967 delta 88
- Going to Albuquerque? Looking for?
- Looking For Used Headers For 68
- windshield wiper motor assembly
- Cast Iron 1970 442 Intake with the PCV Nipple
- 57 olds vent windows
- Manual steering box
- Wanted: 1965 Cutlass Body Parts
- gauges
- Headers
- Nos 70-72 convertible trunk lid
- WTB Boot rail
- 66 A body rear speaker and enclosure
- 1971 455 power steering brackets
- 1964-65-66 AUTO console hinge
- '67 425 alternator bracket w/ AC
- Black Inner Fenders
- 1964 dog dish/poverty hub cap
- Wanted - 1955 Fuel Tank
- 69-72 th350 kickdown cable clip
- 1965 Cutlass Center Hood Molding
- 68-69 A/C Duct
- WTB 1939 Horn Button
- 1967 Cutlass Parts Wanted
- Wanted: 1969 Cutlass convertible rear interior panels
- Bench seat headrest locks and chrome cover
- 1970 cruise control servo
- 455 crankshaft
- Fuse box accessory power lead
- Sheetmetal and trim for 1968 442 Convertible
- WANTED- Someone to pick up parts in Wichita on way to Nats
- Wanted: 1967 442 parts
- 71 supreme door panel parts
- 1972 cutlass supreme RH grille
- 1961 f85 rear brass brake block
- 62 dynamic 88 radiator core support bushings needed
- 1961 F85 stainless fender skirt pads
- 1970 Cutlass Front Bumper
- 1964 Olds 394 Thermostat
- 65 vista cruiser part search
- Bead moldings for 62 Starfire quarter panels
- Glove box light assemble - where to find?
- 1970 white interior
- right rear wheel well trim
- gas tank for a 1967 delta 88 conv front brake drums
- 1969 Hurst Olds Engine Parts
- '62 Starfire convertible boot cover trim
- WTB: 71-72 Brackets Coolant Recovery Tank
- Single bale/rectangular Master Cylinder Lids
- *Wanted - 1977 Delta 88 door glass
- Wanted ZN or ZN-72 Rad tag for 72 442
- WTB 70-72 Cutlass 442 Top Windshield Trim
- Wanted 65-69 4spd console top and gauge.
- 72 rear tailight housing (passenger)
- Aluminum Intake Wanted BBO
- 62 cutlass hood core support wanted
- 70 Supreme grills needed
- 455 Heads
- 1975 salon bucket seat hinge brackets
- Need '67 Cutlass fan switch for A/C car
- 67 Olds delta 88 custom wheel well molding
- 73 98 steering wheel
- Air intake temp sensor
- 69/70 NOS hood tongue S emblem
- Wanted 68 4V carb 7028250 for a 350
- 1970 Vacuum Tee for quadrajet
- SS1's 14" x 6" Wheels
- 4-Speed Console Base 65-69
- good used 215 or 198 Buick engine needed. source?
- WTB: Performer Intake for 455
- 4 speed console lever
- Wanted- 69 442 4 speed transmission hump
- Wanted: 1969 Cutlass radiator core support
- Edelbrock Valve covers
- WTB: Olds 350 4bbl intake manifold
- Looking for 68 hood hinges
- WTB Oil Level Indicator (Dipstick)
- 1972 CS Tail Light Lenses and Reverse Light Lenses
- WANTED: two 1965 442 exhaust pipes
- Want: 77-79 Olds 98 B (center) pillar plastic inside cover
- Wanted 14X7 steel wheels, ZIP 44256
- Aluminum dual-plane intake manifoldfor '73 455
- Need 63 Dynamic 88 parts , going to Albuquerque
- Exterior Molding - 1974 Delta 88 Royale Convertible
- 1970 442 TCS switch
- 1967 Cutlass Single Groove Power Steering Pulley
- Bracket that holds Parking Brake Switch
- 67 Cutlass Parking Brake Light Assembly
- 15x7 Super Stock Wheels (qty 5, bolt on caps)
- Wanted: 1967 442 power steering rear bracket
- '68 A-Body Rear window escutcheons
- 1968 Olds Cutlass Lower Antenna Spacer#398631 and Screw #9420508
- Ac defrost vent
- 1970 W-31 Harmonic Balancer?
- 67 steering column
- 73 delta 88 convertible qaurter panel
- 67 442 transmission filler tube
- tail light surrounds
- WTB - 1967 Cutlass A-Body non-AC kick panels
- 1968 442 convertible interior wanted
- Lifter
- Accelerator/Throttle cabel for 72 Cutlass 350 4 bbl/QJet
- side by side master window switch NEEDED
- Looking for a set of crome after market valve covers for my 324 rocket
- Super Stock Wheels
- 1979 Hurst/Olds fan shroud
- 70 cutlass/442 Nos RH hood moulding
- Magneto for 324
- Factory OAI ram air hood to put on my '72 Cutlass supreme
- Needle n haystack hurst shifter
- WTB 4 Body mount bushings - 72 Cutlass
- 1967 Olds 442 Rally Pac Fuse Block and Bulkhead
- 70 350 exhaust manifolds needed
- Good Day, My Fellow Olds Enthusiasts/ 71 Delta
- 1971 Black ashtray cover - Cutlass Supreme
- driver side quarter panel 1983 88
- 200r4 trans
- 1970 442 Master Cylinder (boosted brakes) - "EB" Stamp
- Wanted floor shift speedminder
- 71' A body radiator support
- WTB 1973/1974 double hump crossmember
- 1966 Oldsmobile Toronado
- Looking for 1978 cutlass Headlight bezel.(MINT)
- 1962 F85 Cutlass wiper parts needed
- 71 72 cutlass tail light housing
- need opera lamp cover from 79 Olds 98
- looking for 455 exhaust manifolds for 71 cutlass vert
- WTB. 1969 Cutlass supreme trim
- 1970 olds cutlass sheet metal
- 1967 442 400 ci engine and turbo 400
- Temperature Sending Unit
- SS III 15X7 4 Wanted
- Wanted 71-72 factory aoi hood
- 1970 Cutlass Eyebrows and Hockey Sticks
- Looking for mint tail lights
- Wanted 303 Valve Covers
- RH door. 70 Cutlass supreme.
- Split Bench with armrest
- 71 442 battery cable heat shield
- 71/72 Cutlass Fenders
- Buick 231 v6
- Need a NOS 1970 dual line fuel sending unit
- 69,70 Rear bell drums
- 330 exhaust manifold
- Hurst His 'N Hers Shifter Cable
- Ssiii
- 69 cutlass wiper motor and pump
- 1972 Cutlass Supreme Hood Hinges
- 67 Vista Cruiser third row seat
- WTB 3.42 Ring and Pinion for 71 10 Bolt AntiSpin
- 1972 Hood Lock
- 65 Cutlass hood center spear
- steering wheel 1972 cutlass
- 1968 Vista Cruiser Rear Bumper
- 1971 Cutlass bench seat with armrest seat belt bezel
- 69 window regulator
- WTB: 70-72 OAI Hood pin/brackets
- Raised Vista Cruiser Roof
- Restoring 1964 olds f85 dekuxe, beginner
- 1964-65-66 Cutlass 442 auto console glovebox door
- 1973 cutlass rally pack
- 215 V8 Bellhousing
- Window Switch
- Looking for a set of nos tailpipes
- WTB: 1970 black dashboard
- 69 RH Window Regulator
- 64 cutlass backup lights
- 1969 vista cruiser frame
- bullet mirrors 1975
- rear yoke olds 98, 1969 model
- 68-69 Supreme pot metal trim
- Need a nos Front emblem
- 69 442 4 speed reverse lockout
- 1969 Cutlass wagon tailgate window switch
- 1969 442
- Looking for standard chrome mirror
- rally gauges '70 cutlass
- '70 cutlass Center Dash Vent a/c
- 1965 cutlass rear bumper wanted
- 64 Cutlass
- notched valve cover
- WTB: 1967 full size A-pillar trim
- 67 Cutlass Rear
- carburator
- 1964 Olds 98 no Tilt turn signal cam
- Wtb SS-IV poly cast wheels
- 1971 Cutlass Black Interior
- Shift indicator for 64 Starfire console
- Exhaust manifold
- Looking for stock parts for 455 396021F
- Body parts for 1978 88 Royale
- '75 hood release cable
- Rear axle
- Wanted. 70-72 4 core radiator top plate
- Capacitor DR .5MF
- 1989 Ninety Eight Center wheel cap
- 62 Dynamic door beltline
- '83-'84 Hurst/Olds Front Air Dam Parts
- 69-69 vista cruiser tail light lenses!!
- 1970 442 door hinge bolt
- 1969 heads
- Missing part 64-65
- Still looking for a legit 7040255 carb
- 1971 oldmobile cutlass split bench seat With arm rest. Plastic backing
- 1973 Omega Coup
- Need Fasteners---Swapping Muncie in place of TH350
- 1972 Cutlass/442 convertible Doors and decklid - pick up at Homecoming
- Edelbrock 04B manifold
- door hinges for 66
- 1969 442 or Compatible - Heat Shroud, Riser Tube, Air Cleaner Adapter
- Tail lights
- 1964 Cutlass bottom trim
- 70 and 71 alternators
- Looking to trade 1972 Cutlass radiator support for 1971
- Convertible chassis Frame.
- 7040251 carb
- Turbo 400 Pan
- 1970 trunk release button needed
- 455 W/Z Manifolds
- Muncie M20 question
- Wanted, 1940s deluxe air filter
- 69 Cutlass blue floor mats
- Wanted: '32 Olds vacuum windshield wiper unit
- 68 4 speed console
- 70 442/Cutlass Right Side headlight plate
- Power Antenna 67 Cutlass 442
- 67 horn relay
- Legit 7040255 carb wanted
- looking for 390390 intake Manifold
- White exterior accent trim 73 delta 88
- 1971 Fr Bumper
- 65 Cutlass speaker grill
- 1971 Cutlass 455 A/C mounting bolts
- 1971-72 Cutlass core support
- 69 cutlass Console top plate or parts wanted
