Rear axle
Old May 22, 2017 | 05:48 PM
Russell Winkle's Avatar
Rear axle
Complete 12 bolt posi rear axle for a 70 442.
Or all internal parts as I do have the shell.
Old May 23, 2017 | 06:35 AM
ROCKETMAN269V's Avatar
12 bolt posi rear end
I have a complete, drum to drum, TYPE "O", 8.5", '67-'70, 4.10 posi rear end. I'm not sure if it is a '70 housing; however, it wouldn't be an oem gear with that ratio. It has a Richmond ring & pinion and an aftermarket posi carrier. You can email me to discuss: drolds1@bellsouth.net. Thanks, Bob.
Old May 23, 2017 | 12:29 PM
11971four4two's Avatar
MOTORHEAD
HEY
Welcome aboard
I did talk to Mister Kelso today
he has a few olds axles that you could buy
I do have a 3.08 ratio rear with SD code
#1000
Old May 25, 2017 | 10:25 PM
65B01Delta's Avatar
https://indianapolis.craigslist.org/pts/6137589159.html
1970 Oldsmobile 442 rearend rear end - $900 (Shelbyville)
I actually seen this at this Guys garage.....
1970 Olds Oldsmobile 442 rearend 12 bolt, 3.91 anti-spin. "TO" axle code "K11 date code". $900.00
Call Scott at 317 364 2580.
Old May 25, 2017 | 10:36 PM
MOTORHEAD
Animal
#391
you should go buy that???????????????????
Old May 26, 2017 | 07:07 PM
drolds2u's Avatar
1970 442 3.91 posi
i have one complete rear end, ocala fl , 12 bolt O-type 3.91 posi , where are you located
Old May 27, 2017 | 06:38 AM
65B01Delta's Avatar
You should call Scott, If I remember correctly he did mention something about having internal parts as well.....
HitTheHole
Drivetrain/Differentials
Feb 4, 2021 10:46 AM
twilightblue28A
Apr 9, 2016 07:13 AM
cutlasssupreme71
Feb 22, 2011 11:40 AM
dan1s
Sep 23, 2008 01:53 PM
<powers455>
Sep 13, 2007 09:11 PM
