View Full Version : Parts Wanted
- Wanted! 68 3 spoke garnet steering wheel
- 1959 Licence plate bracket
- 71 supreme drip rail
- Wanted 1970 Cutlass S door panel S’s
- 69 -72 Bucket seats for 71 olds cutlass in DFW area.
- Z SET of 4 please 14x7 bolt on cap rally wheels
- Wanted: 1962/63 Cutlass F85 4 speed car or parts. Looking for Bell housing, Flywheel,
- Rear seat belt buckle holder.
- starfire 65
- Headers
- 70 Vista cruiser interior rear window moldings
- Wanted: 68 - 69 Rally fuel gauge, just the metal housing
- 1971 Cutlass 442 Olive Green Steering Wheel
- 1967 Cutlass Front & 1966 Rear Bumper
- 69 Cutlass Doors
- Wanted 1111975 Distributor
- 1970 442 Front Fenders
- Looking for NOS Vista Cruiser LH tail light lens gasket
- Passengers door window ‘56
- 67 Cutlass Trim Clip Help!
- 71/72 Sport mirror passenger side, drivers side mirror base, screw, gaskets both side
- Quadrajet 7040250 or 7029250
- 72 Supreme HT rear window trim
- 1969 cutlass parts
- Need 66-67 Ralley Pack Oil Pressure Gauge
- Wanted UHV box Dead or Alive
- 1965 cutlass floor shift cables
- 66 442 interior door panels.
- 72 Cutlass Supreme Driver Side Vinyl top trim
- Factory Piston 69 Olds 350 (High Compression)
- 72 cutlass 350 right exhaust manifold
- 1970 EB Master cyl and Disc brake prop
- 65 side scoops
- WTB 1970 Igition cylinder part# 3981938
- 1976 Cutlass OAI Duct
- 67 Toronado trim piece needed
- Power steering and alternator brackets for 330
- 1973 cutlass supreme front bumper
- 1961 88 Dash pad
- steering wheel wanted
- 1968 front bumper brackets
- 1970 "Dog Dish" Oldsmobile Hub Caps
- 1970 Heavy Duty Cooling Fan and Fan Clutch
- A-body floor shift tilt column
- dual quads
- Looking for: 455ci flywheel cover, TH400 kick down switch and horns
- 73 or 74 Omega Door Chrome
- Junk/ rust 66 cutlass hood for a patch panel
- 1969 442 1108348 Starter
- '70 W-25 hood metal frame piece....
- 1976 dash
- M20 muncie
- STILL LOOKING for 76-77 2dr LEFT side wheel opening molding
- Cruise switch
- 66 442 Door Panel SS Trim Piece
- *Wanted - NOS 4 Speed Shift Boot
- 71 delta 88 axle shafts needed
- Rear and front bumper 65 olds dynamic 88
- Looking for the 2 faux wood top inserts for a 70-442 4 speed console
- Seeking 1971/1972 Oldsmobile Cutlass Hood
- 1977 Cutlass opera window trim
- '71/2 Cutlass Parts Needed
- Driver Quality SS1 Center Cap Needed
- Wtb 1965 cutlass tail light buckets
- 1966 delta parts
- 1954 Olds Holiday 98 2dr trim clips needed
- 1968 442 dash pad
- 66 delta 88 front spindals
- Manual Steering Box Pitman Arm
- 1111933 Distributor
- Convertible sun visor
- Help with carb search
- 1965 Cutlass Rear Tail light Pot Metal Surround Trims
- 76 toro odometer trip reset knob
- 62 starfire
- 1966 olds442/cutlass wiper switch
- Rear Bumper needed for 1968 Ninety-Eight
- 1970 "Oldsmobile" Script part no. 8723106
- WTB Oldsmobile Exterior Colors and Stripes Book
- 70-72 Vista tailgate interior door panel
- Wanted: Steering arms and upper rear arm 66 Cutlass
- 90' Full-Size Custom Cruiser proportioning valve wanted
- 70 442 Starter 1108389 WANTED
- Exhaust Manifold 74 cutlass 74
- 1967 cutlass trim, trunk springs, screws
- 1970 Vista Cruiser Tailgate Trim?
- 15" pop on center SSII rally wheel wanted
- Single 425 Rod.
- 67 cutlass front plate bracket
- alternator bracket
- Complete Cruise set-up for a '70 with a 350
- 62 starfire 394ci
- 1962 F85 Chrome Strip needed
- Need a radio. Is the dash the same on a 1967 Cutlass and Vista Cruiser??
- I need 1973 98 control arm bolts
- Steering box,column
- 1965 cutlass reverse lights wanted
- 1970 Cutlass RH fender filler panel
- 1970 cutlass relay
- 1969 442 Alternator
- 9.3 Posi
- 1956 Glass fuse retainer
- Wanted 394 thermostat housing
- 1969 442 Hood wanted
- Wanted: 67-72 Cutlass 442 floor shifter
- 71/72 Emission canister bracket
- NOS or rust free passenger fender wanted, 61-62 f-85
- Egine pulleys
- Wanted Radio Knobs.
- 1970---7040258
- 67 442 Hood
- Wanted nos floor shift 4 speed boot
- cutlass salon parts wanted 1975
- 394 air cleaner snorkle
- Looking For a Oldsmobile Dealer Plate
- OAI Base - Snorkel Only
- 1968 Q-Jet Carburetor #7028251
- Larry
- 1995 or 1996 Olds 98 regency parts wanted
- 61? - 64 Starfire /98 hubcap insert
- Msd 8566
- Fender brace
- WTB - 64/65 f-85 4 door sheet metal, trim, misc
- NOS 1965 Starfire Parts
- 1991 Custom Cruiser Rear Wiper Switch
- Wanted 1970 coupe trunk lid
- 1953 Oldsmobile Super 88 grill/bumper extention
- Alternator bracket
- fe3xgroundeffects WHEEL FLARES or equal
- Wanted 1970 12 bolt posi rear
- Wanted: 1967 442 Rear bumper
- 1964 Throttle Linkage Cutlass 442
- 200-r4 manual
- wanted 69 alternator back that is finned
- NOS 1970 Cutlass Trunk Script / Emblem
- NOS 1970 Rocket Emblem for Trunk
- 67 Cutlass Wheel
- Wanted FU radiator
- Manual to Power steering conversion
- 1970 Blue Bucket Seat Covers
- Looking for a Sidewinder Tach Mounting Bracket
- 1964 330 cu. in. Water Pump Cores
- 1955 Oldsmobile 88
- Help needed for information on 1975 cutlass supreme window assembly
- NOS 69 Cutlass/442/hurst rear marker bezels
- Front dash speaker for 70 Cutlass
- Looking for (4) 14x7 Steel Wheels - XT or IF
- Need a drivers side rear inner for a convertible 70 442/Cutlass
- Olds 350 Holley dominator
- Looking for 455 edelbrock performer intake
- 70-72 Radio and 8 track
- 15X7 X 4 3/4 Bolt pattern
- Wanted 64 Cutlass hood
- 67 Cutlass front license plate bracket
- Wanted F70x14 Bias Ply Tires
- 70-72 442 nos trunk script
- WTB: Olds 588 Posi Carrier
- 1965 98 right taillight housing
- 62 Starfire trim parts wanted
- 1966 Full Sized Olds Manual Transmission
- 1955 Olds Horn Contact Parts
- 15 inch Olds hubcaps
- Looking for 1957 olds wagon parts.
- 71 350 distributor/parts
- 1957 Shop / Repair Manual
- 67 cutlass /442
- Wanted: 1 15x7 SS III WHEEL
- 64 Oldsmobile Starfire battery tray
- Correct Fuel Pump for 70 W30
- 69 Cutlass S door panel emblems
- Olds 455 Crank
- Looking for ‘66 starfire parts
- 1961 Oldsmobile Starfire/Super 88 Tail Lights
- 72 cutlass jack "base only"
- A/C duct
- Wanted 66-67 Bench seat headrests
- 70-72 Cutlass S 442/Fastback full rear quarter panel
- Wanted: B85 post coupe molding 1970 442
- new guy needs help/parts for 1989 Custom Cruiser
- Distributor and Coil for Rallye 350
- WTB 64 cutlass left front turn signal lens
- 73 Cutlass Supreme lower center valance and rh grille
- SET of G body sport mirrors
- Wanted: 1957 Rear Seat back and bumpouts
- Oldsmobile Qjet cores wanted
- 1957 Olds Convertible Boot Retainer Clip
- Wanted: 1957 Deluxe steering wheel shroud
- Mondello performance products sticker
- l1965 cutlass 442 lower crankcase pulley
- Frame for a 64 cutlass convertible
- Non-a/c alt. bracket
- Wanted black 71 top boot
- 62 starfire 394ci
- 65 cutlass therunk gutter\ rear shelf and other parts needed
- NOS rear quarter panels
- 1967 330 2 bbl air cleaner assembly wing nut bezel
- 1963 olds Front bumpers and fender
- Seeking to purchase 15×8 wheels for '72 Olds Cut Supreme
- 70-72 Black center console lid.
- WTB 1971 - 442 Grills
- 71 sport mirrors
- 1964 f85
- wanted 62 olds dynamic 88 front bumper
- 1940 Olds Coupe Vent Window Regulator
- 1967 cutlass factory headrests
- Wanted: NOS 1970 Cutlass right grille
- 1970 350 number 6 heads
- Looking for 1970 442 Grille (NOS) - RH only
- 1970 Only Cutlass AM/FM Radio
- Wanted. Eaton LSD and 3.42 ring and pinion
- Looking for Sienna colored interior parts 70-72
- 1971/72 Cutlass S Hood Louvers
- 1969 442 / Cutlass hood lock support
- 1967 Oldsmobile cutlass 442 lower Tail light assembly pair
- 1967 w30 air cleaner
- Clock delete 68-72 cutlass/442
- WTB 72' Cutlass Supreme Door Chrome
- Vista Cruiser dual action rear bumper needed
- 1970 white seatcover
- 76/77 supreme rear quarters
- Blue knob window cranks
- wanted, Thorton Exhaust Manifolds
- Wanted, Edelbrock 7111
- Bumpers
- cutlass supreme 1974 front seat belt
- 67 cutlass tail light bezel
- wheels
- Wanted: nice 70-77 sport wheel horn cap
- Body Parts for my 1970 Olds Cutlass Supreme Convertible
- Rear bumper for 61 Cutlass
- 1957 backup light housings
- 64-69 4 speed console parts needed
- 1972 cutlass black bench seat
- Need 64-69 Console Door hinge only
- 64-69 Console door hinge needed.
- 1966 Cutlass Supreme Door
- center link jetstar 88
- 76 toro door lock switch
- Water pump for 68 442 HD cooling AC and automatic...part #230900
- 69 A-body original door opening windlace
- wanted 70 442 coupe trunk lid
- UHV Ignition Amplifier Bottom Cover
- 64 65 66 Cutlass 442 steering wheel
- Wanted: 1970 Console harness
- 1967 442 hood
- 1964-1965 Cutlass Air Cleaner
- Power Steering Bracket & Pulley
- 394 exhaust manifold GM587793LH wanted
- 1100879 37A Alternator
- '70 442 parts
