View Full Version : Parts Wanted
- 398704
- 1972 cutlass fenders
- 73 olds 98 rear floor mats in Cranberry red
- '65 A-Body Right Outside Mirror
- power bench seat parts WANTED
- WTB Z bar (cross shaft, equalizer) for 1966
- 66 442 4 Speed Tunnel Hump
- Quarter Panels for a 1972 Delta 88 Needed!!
- 1964 olds f85
- WTB: 69 442 Front Sway Bar
- WTB W31 heads
- 68 Cutlass neutral safety switch
- 1964 cutlass headliner
- Wheel opening chrome moldings
- TH 400 dipstick and tube needed
- 64 F-85 post car-( maybe65) passenger door window channel
- Z bar (cross shaft, equalizer) for 1964 1965 1966
- sbo engine parts
- Steering wheel 1965
- 1975 Olds Omega
- WTB 2711 edelbrock intake
- floor shift outer column-on steering shaft-64 F-85
- Long shot..red inner fenders
- Looking for Edelbrock in the boise area
- 1967 400 E Block engine
- 1961/62/63 Cutlass center console (auto or manual))
- 1965 olds 442
- 1973 oldsmobile 98 rear bumper & front bumper bars
- 1967 98 tail light lenses
- Parts for an '87 442
- 69 98 rear bumper
- Need a seat belt
- wanted: 1974 Delta 88 convertible panels
- A-body 70-72 Trunk floor drop off extensions
- 1974 Delta 88 Tail Light Lens/Tail Lights
- 1970 Cutlass Remote Mirror Adjustment Knob
- drivers side ashtray wanted
- Misc 455 bolts needed
- 1969 Cutlass Front L & R Fenders
- 68-70 O-type left axle
- 1968 Cutlass LEFT Hood Hinge
- 1956 Super 88 need steering wheel
- cheap headers for the 'mega
- sbo intake wanted
- 68 442 convertible power window regulator
- Need a horn for 66 cutlass
- 1967 olds 442 dashpad
- 1970 442 spoiler
- Brake Master Cylinder Rebuild Kit
- Replacement Raditor for 1964 Cutlass Convertible
- rear wheel fender trim.
- 70 442 4-speed 7040253 carb needed
- 66 automatic console courtesy light
- 1970 442 Air Cleaner Base
- Radio....71 Cutlass....
- 1979 3 speed floor shifter
- 1957 (1958?) Olds odometer wanted
- 455 piston
- Switch Pitch TH400 wanted
- 1965 442 Side Scoops wanted
- 1973 Cutlass
- Wanted: TH350/400 in good working condition
- Power Steering pump pulley JM
- 69 Cutlass Door
- 1954 Rear Seat centre armrest
- Need Raear Driver side Axle - Olds 1964 98
- Anybody parting a 68-72 vista?
- 1968 cutlass s parts wanted
- D heads wanted
- 67 Cutlass Supreme 442 , H. C.
- Looking for 1970 W-31 intake manifold
- Bucket Seat track slider 1965 442
- Wanted rally pac 1967 442
- 70 442 coupe parts needed
- T350 or t400 main case- for test fitting
- 66 delta 88 bumper jack
- 74 Cutlass Window track Stabilizer Guide
- 68 442 convert rear 1/4, trunk lid needed.
- wheel well trim and molding for top of 1/4,s door. 1970 cutlass
- 1953 Oldsmobile super 88 trim rings and rear seat
- 1962 olds starfire parts needed
- New info Olds W/P pulley
- Vert chassis
- 69 cutlass vert drivers door or the pair
- Upper clutch push rod 1964,1965,1966
- W25 Hood
- Centre armrest
- WTB steering column parts on lower end
- 1956 speedometer
- battery tray, 1964 88
- Body part 1968 442
- Oldsmobile F85 1961 station wagon
- WANTED: 1965 Starfire RH HEADLIGHT parts
- 1980 Starfire (monza) parts
- 65 F-85 sunvisors
- Chrome headliner bows
- 72 442 Drivers and Passenger Side Defroster Hose
- WTB Front Deluxe Seat Belts
- 66 Dash Knobs
- Fender
- 66-70 Toronado Center Air Duct
- 1969 D heads, intake
- water pump pulley
- 70 442 grill wanted. Will pay top value for nice one
- Looking for 86 cutlass parts and 72 olds 350 parts
- 1987 Rear driver's side tail light lense
- Vista Cruiser Chrome Glass wanted
- Looking for a 1970 Ram Air Hood
- Inner Fender and Tilt Column
- WTB radiator core support for '72 cutlass
- Wanted: 1986 Olds Regency Opera light Pillars
- Looking for 1964 98 Drive Shaft
- 1970-72 Cutlass Supreme Trunk Lid
- junk 14" wheels and tires for rolling chassis
- 72 NOS fender
- 72 Cutlass Supreme Trunk pan
- WTB - replacement NOS transmission Pan ST-300
- WTB lower aluminum rocker trim for 64 Cutlass F85
- WTB 1964 Cutlass F85 Bumper Jack
- W manifold wanted
- WTB - 69ish Underdash housing
- WTB '70 Deluxe Belts
- ash trays and bezel 65 cutlass
- '73 Delta 88 convertible door lights
- 1974 Delta 88 Tail light
- carrier bearing
- Fuel tank for 1962 f85
- 14" X 7" XT Code Wheels
- Ram Air Hood
- 66 442 Mirror and Visor Mounts
- Power bench seat cables
- Rear bumper 62 olds f-85
- 66 toronado telesopic column
- Manual Disk Brake Master EB Code wanted
- 65 cutlass trunk letters wanted
- 65 442 Air cleaner for Lansing guy
- 1970 specific dual gate parts needed
- 72 442 4 speed shifter
- 1972 - 1976 Delta 88 Rear Quarter Skins Needed
- Brake Drums1965 starfire
- 72 oldsmobile cutlass supreme seat belts & radio needed
- needed 72 supreme parts
- '65 Cutlass Convertible Frame
- 67 throttle Linkage
- 69 Red Wells...needed for resto project
- damaged 68/69 fenders
- 3A heads needed
- 1986 cutlass salon
- valve cover bolts and throttle/kickdown cable bracket
- 69 Passenger Side Mirror Question
- 1969 442 exterior trim
- 67 Air Cleaner
- 69 centre counsel parts
- 54-55 dog dish caps wanted
- Power Antenna Repair Specialist or replacement?
- Plastic install strips
- Chrome Trim Piece 64 Cutlass
- needed 72 supreme deck lid
- 1969 H/O engine,trans, any parts
- front floor
- 1968 Dog Dish / Poverty Caps
- rear transmission yoke
- A Really Odd Part I'm Looking For -Upper Ball Joint Diust Boots
- TH350 trans pan
- What is this bumper piece called? And where do I find one?
- 72 Delta 88 Dash light Lens's
- 66 starfire parts/ links.
- Accessary brackets for A/C, P/S & Alternator
- hood louvers
- 1967 delmont 88 trim
- Bolts,bolts, bolts
- LOOKING for: 7040258
- 74' Omega filler pannel, rear marker light bezel
- 74' Omega window guide channel
- carb question
- Gauging Availability: 330 flexplate
- 1968 Olds 98 steering wheel
- 1969 Rally Pack
- Needed for 77 Cutlass, front clip
- Throttle cable clip
- Decklid for '68 hardtop
- how much to pay for a 200r4 core
- 1969 cutlass hood louvers
- 1970 CS Inner front fender wells?
- 1970 442
- Looking for a 455 Valley Oil Baffle
- Parts for 79 Cutlass
- 68 console w/ automatic shifter needed
- Muncie M20
- water pump pulley
- please help
- Vista Roof Glass driver side
- jack
- OEM Disc Brakes
- 1940 straigt 8 engine
- 68/69 442 convertible visors please :)
- Q-jet for '77 403
- 1965 425 4GC carb 7025255
- Even More "Last Parts" Needed For 70 W30 Resto
- wated, rear carpet mats(black)
- Arm rest chrome backing plate...71 Cutlass
- Vacuum trunk release, 66 442
- 455 dipstick tube
- 71 cutlass bucket seat trim bracket
- gold floor mats from 1969-70 cutlass also green
- Throttle bellcrank rod to carb
- manual cutlass
- 1970 Cutlass core support wanted
- Need 70 442 posi rearend drum to drum
- '68-69 H/O dual gate top plate
- Oldsmobile embossed valve covers
- 1954 Oldsmobile 98 4Door sedan windshield
- 3500stall
- Chrome GM Performance Parts Oldsmobile Air Cleaner
- Looking for a running 455
- 66 Delta 88 425 a/c engine brackets
- !970 CS Convert trunk lid
- 1970 Cutlass Green Interior Pieces
- 14x6 wheels
- MI man seeks 84 H/O wheels?
- 1983/84 Hurst Olds w/Maple Red interior
- Wanted under hood courtesy light '73 Delta
- wanted 67 delmont ac heater parts
- rear differential
- 62 olds window channel
- 64 Cutlass parts wanted
- 1961 Starfire backup light bezel and mounting hardware
- 71-72 Toronado
- NOS harmonic balance
- KH power sterring pully
- Hurst Shifter Nylon Bushing
- Last Parts Needed For 70 442 Resto
- WANTED: Dry '71 or '72 Vista Cruiser!
- '57-'58 Courtesy light housing switch wanted
- A/C-Heater Blower Motor tube-69 442
- 1967 442 Hood or Aftermarket
- 1965 Starfire frame to bumper brackets front and rear
- Rear window to trunk panel for 72 Cutlass Supreme 2 dr coupe
- Lug nut seats or oversize lug nuts wanted
- 65 F-85 DS fender
- Wanted, bucket seat adjustment rails 1966-68
- 71 windshield molding
- Wanted 76 olds 98 trunk bezel
- G-body door jamb
- 1968 Delmont 88 driver side turn signal wanted outer lense with philip screws.
- WTB: Vacuum Tank - 1970 442 Conv.
- 1070 Cutlass S/442 Parts wanted!!
- 455 4bbl intake
- '76/'77 Rear Bumper
- 1972 Supreme parts
