PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Blue Steering Wheel
  2. Speaker Dust Cover Fabric
  3. Seatbelts
  4. 1970 Oldsmobile 442 Carburetor
  5. 64-69 4-spd Console Top Plate
  6. Pulley KM
  7. Wanted 66 cutlass 442 glove box door
  8. WTB 65-66 330 2 barrel pushrods
  9. '66 442 Pulleys
  10. Door Clip Non-AC Car Upper Vent
  11. 672 posi carrier
  12. '64 F85 center console AT
  13. Looking for 1974 Cutlass Parts (chrome, trim, etc.)
  14. Tic toc tac
  15. Convert top parts 72 Delta
  16. Blue Ash Tray Door
  17. Cutlass 72 Inspection cover
  18. Need 1965 Cutlass driver side Rear Window Vertical Hockey Stick Molding
  19. 1964-66 A body tilt column
  20. Window Glass for '75 442
  21. Cylinder Head Bolts on a 324
  22. 1950 Olds Fender Skirts wanted
  23. 1970 Cutlass am/fm radio
  24. 1970 Non-AC Duct Work
  25. WTB: '70 cutlass s driver door and hinges
  26. 1971 Sutlass Supreme Front Grills
  27. 66 400cid Connecting rods
  28. 1954-1956
  29. 71-72 Cutlass Convertible Inner Quarter Panel
  30. I need an aluminum intake for 455 .
  31. 1977 Olds 98 passenger sun visor
  32. Dash Pad
  33. 67 Cutlass Supreme door
  34. Need a trunk lid for 71 Olds Cutlass S ASAP
  35. 64 Starfire speedometer cable to bypass cruise control
  36. 1972 442 V Code Door Jamb Windlace
  37. windows
  38. 1970 442 Holiday Coupe Hardtop
  39. Antenna Mast & Base
  40. NOS R side chrome "hockey stick" for 1970 Cutlass/442
  41. Distributor Shaft "148"
  42. 71-73 88 0r 98 front side marker, cornering light sockets & harness
  43. 72 cutlass ac vent
  44. 1972 Cutlass Supreme Vinyl Top Trim
  45. 71 Cutlass Convertible.
  46. !957 Oldsmobile 2 door front seat parts
  47. NOS interior window cranks
  48. Wanted : 70 only mint decklid.. for 34487
  49. Need 70 passenger side sport mirror
  50. 53 88 Holiday Coupe parts
  51. 1970 Hurst Dual Gate Neutral Safety Switch
  52. 65 F85 Club Coupe Parts
  53. 69 H/O pulleys
  54. 1969 442 Quarter panel trim
  55. Rocket Racing intake
  56. 70-442 cruise vacuum lines
  57. Parts needed 1975-1977 Cutlass Supreme
  58. 1976-77 Cutlass S front bumper
  59. Help with finding Carb Linkage
  60. Looking for 68 442 (2) spark plug wire loom bracket's holdersets
  61. 1964 98 Oldsmobile Fender Emblem
  62. need this small AC hose bracket-63 Starfire pictured
  63. snap on caps, 15" trim rings
  64. 1970 oldsmobile W brochure
  65. 37 Olds
  66. quarter window parts for 65 holiday hardtop 442
  67. 68 Cutlass S Convertible no AC Dash pad
  68. 1966/67 inner fenderwells and rear frame section
  69. Looking for NOS Rear 1/4s for 70 442
  70. WTB Power Antenna Mast, 64 D88
  71. 67 Muncie 4 speed back up switch
  72. 90 degree speedometer adapter
  73. 66-78 Cutlass Bucket Seats
  74. Where can I get one of these?🤔
  75. 69-70 F-85 Wire Hub Caps 402495 N95 Option
  76. 1957 Olds 88 Hood
  77. 1970 442 grills
  78. 66 straight automatic column shift lever.
  79. Single F Head ?? anybody ?
  80. ss
  81. NOS Brake Pad 3858199
  82. 1968 442 lower hood release paddle type, not the steel rod
  83. 1969 Radio Mtg Brackets
  84. Looking For F-Heads 295 Julian Date Code
  85. WANTED: 14x7 Wheel near DFW for Spare Tire
  86. 15 x7 x3 trim rings
  87. Tail light housing bezel 1957 Oldsmobile Super 88
  88. 63 394 PCV hose wanted 4 bbl
  89. 1108387 Starter
  90. Looking for 1970 W & Z exhaust manifolds
  91. Windshield trim screw
  92. ISO Ga head
  93. 15 x 8 SSII wheels
  94. Carburetor 72 W-30
  95. Donor filler, '70 442
  96. Door chrome for a 1965 Vista Cruiser
  97. 66-67 400 piston
  98. Carburetor t-fitting
  99. NOS 1966-1972 Oldsmobile Floor Mats
  100. 71 72 Hood Striker Reinforcement
  101. 1977 Cutlass S front bumper
  102. 73-74 oldsmobile omega engine frame mounts
  103. 67 C/S Holiday Coupe: Rockers Needed
  104. Decals for SS1’s
  105. 1968 4-Speed Console
  106. 64 dynamic 88 frame
  107. nos 9796919 trim rings
  108. Wanted Oldsmobile W30 Starter 1108389
  109. Wanted: Mechanical Digit Dash Clock
  110. Wanted: SP2P Intake
  111. Window Channel Kit '65 Vista Cruiser
  112. 1971 Cutlass Drivers side grill/grille insert
  113. Headlight Assemblies LH & RH
  114. 394 project
  115. Disc brake spindles 69-72 cutlass
  116. 68 Cutlass Vert Dash Light
  117. Road Draft Tube
  118. Oldsmobile cutlass salon 1974 mirror side view
  119. 1967 convertible cutlass top frame rack
  120. Portland Oregon
  121. Frame pads for 350 Olds SB to '64 A-body
  122. Wanted : Floor mount Headlight switch
  123. Crankshaft Pulley 2or 3 groove for 1956
  124. 1972 Dash Clock
  125. Need wiper motor for '63 F-85
  126. Black plastic fender well
  127. 68 Vista Cruiser Front Door Panels
  128. Air cleaner assembly dented or factory? Help!
  129. 1951 Steel wheels with clips!
  130. Crank pulley for 1966 442 w/ac
  131. V-6 Air Cleaner
  132. 67 400
  133. 71 cutlass dash panel wanted
  134. 1111977 W-30 4 Speed Distributor
  135. headlight relay
  136. 1968 oldsmobile cutlass supreme or 442 Hood
  137. 56 324 engine (or at least block)
  138. Need one 65 valve cover
  139. Basic stock valve covers
  140. Power steering brackets
  141. Tall valve covers
  142. under dash switch bracket
  143. Convertible top switch needed GM#405535
  144. WTB Seat for a 36 Olds coupe
  145. spindle nut match
  146. 69 rally pac wiring
  147. 67 C casting heads
  148. 48 flat head eight engine needed
  149. '65 Seat help...
  150. 65 cutlass trim
  151. Dash Studs 68-72 Cutlass
  152. Need a Wing Nut
  153. 71 442 W30 4speed no a/c water pump
  154. Inner Door parts needed
  155. Looking for 67 Cutlass Hood Latch Pin same hood
  156. Olds engine frame mounts for square body GM truck
  157. 65 Full Size P rear end housing wanted
  158. Column shift linkage rebuild kit - 1973 Olds Omega 3-speed Saginaw
  159. 72 Convertible top switch needed
  160. Wanted to Buy-1965 olds Delta Power Steering Pump
  161. Q-jet needed numbers do not matter
  162. Please help!
  163. help for a 1954 Oldsmobile rocket with a 324 rocket in it
  164. help for a 1954 Oldsmobile rocket with a 324 rocket in it
  165. 65 Jetstar Starfire Heater outlet Duct
  166. 71 4 speed console
  167. 70 442 Carb
  168. WANTED: 1968-69 442 carb
  169. Wanted: Set of SSI 14X7 rims for 70 442
  170. 68-72 Power Seat fully restored
  171. 1966-1967 Rally Pac dial
  172. 69 442 hardtop A Pillar padded cover - LH
  173. Wtb: Cruise control switch button for my '69 4-4-2
  174. 66 cutlass rear body panel.
  175. WTB: 1968-1972 disc brake parts..
  176. 330 intake manifold.
  177. 1971 442 distributor
  178. 71 442 water pump #407536
  179. 1968 horns
  180. air cleaner
  181. Turn signal lever ninety eight 1977
  182. Insert for Shift Lever with Tilt '70
  183. 1967 442 Hood.
  184. 1968 Ninety Eight 15 Inch Hubcaps
  185. 1979 dual gate
  186. 1970 1971 1972 Quarter Window Outside Weatherstripping
  187. Lower ac panel
  188. Repair kit fuel pump Holley 12-836
  189. 68 Cutlass Wiper Motor/pump
  190. 68-69 automatic top plate
  191. 1965 f-85 post door hardware
  192. Wanted - Column Shift Indicator Clip
  193. Looking for Tall Chrome BBO Valve Covers
  194. Wanted: NOS SSI Center Caps
  195. Wanted: Quadrajet Power Piston
  196. 1967-72 Big block 4 speed engine
  197. 68 Cutlass Transmission Gear shift rod
  198. 1970 350 4bbl carburetor
  199. Wanted Floor Shift Tilt Column for 72
  200. 70 Cutlass Supreme wheelwell trim
  201. WTB 70 442 Convertible Pass Door & Fender
  202. Vavle covers
  203. Need Lwr air deflector '75 Cutlass
  204. 69 Cutlass S
  205. Need a rearend for 70 cutlass
  206. JE pulley wanted
  207. ISO..NOS starfire power antena mast
  208. Need a headlight bucket for 55 Olds
  209. 71/72 Vapor Canister Bracket
  210. 1970 Cutlass convertible doors
  211. 69-72 floor shift tilt column
  212. 69-72 Bucket Seat Just One
  213. Looking for rear mats for a 76 olds 98
  214. Look for a fuel tank for 1971 old 98 LS
  215. 69 442 choke coil
  216. 1968 Olds 98 lower panel molding.
  217. Power Door Lock Solenoids
  218. valve covers
  219. Jack hook 406925
  220. Chrome ssII Wheels
  221. 68 Cutlass Parking Brake Assembly
  222. 1967 Cutlass 442 Door Hinges
  223. 74 delta 88 impact strips
  224. 1968 delta 88
  225. 1953 Olds 88 front lip pieces
  226. 1967 442 manual trans Air Cleaner
  227. Need 350 olds.
  228. 71 Delta 88 rubber bumper side trim
  229. 73 442 parking lamp lenses
  230. 71 Delta 88 12 bolt Posi
  231. 71 Delta 88 Flood lamp lens
  232. Wanted 1966 vista cruiser parts
  233. Needed 67 Clutch Fork Pivot Grease Cup
  234. 66 442 4 speed console plastic
  235. 72 Supreme LH ( Driver Side ) NOS quarter panel
  236. HELP I need a 1967 olds Delmont Convertible trunk lid
  237. Rally Pack Gauge, Oil, Temp, Batt
  238. 1968 delta steering colum bearing.
  239. Wanted 1973407 nos distributor vacuum
  240. 1967 Cutlass Need Dashboard
  241. Blue floor mats
  242. Wanted 65 Cutlass door knob lock
  243. 1966 442 Grille
  244. Twilight Sentinel Dash Sticker/ Dash parts
  245. 1959 Oldsmobile Super 88 trunk lid And latch
  246. 69 cutlass Bucket seats
  247. 66-67 cutlass parts car
  248. 1956 88 Blower motor wheel/fan
  249. 70 cutlass convert rear window stops
  250. Wanted 14x7 NOS Wheel Trim Rings
