PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Front drum to disc brake conversion kit for 68 Cutlass Supreme
  2. 15" OEM wheels 65-66 A body
  3. 66-67 chrome lug nuts
  4. WTB: 68 Cutlass Supreme front drum w/ hub
  5. 14 x 7 wheels
  6. Heads radiatior and rubber mat
  7. 72 cutlass convertable
  8. NEED! '60 Radiator.
  9. 72 Cutlass 2 Dr. Hardtop Dash
  10. 72 A/C Blower Housing Box
  11. lower rear window plastic trim
  12. 71-72 Front Bumper Support Braces
  13. 1969 Cutlass / 442 parts wanted
  14. wanted 67 cutlass bucket seats trunk 442 trim floor shift column ( ohio )
  15. Black Dashboard for a 70
  16. 1970 14" trim rings
  17. WTB 1965 -1967 oil fill tube
  18. 1979 H/O grilles, interior or parts car.
  19. Wanted: 455 with 4 speed - VA
  20. Center console brackets
  21. 1970 Olds Cutlass 4 Speed Console wanted
  22. 71 Cutlass Coupe Interior
  23. 68 442 Fuel Gauge
  24. 69 14 by 6 trim rings
  25. 68-72 Bucket Seat Inner Tracks
  26. 70 Holiday Coupe Trunk lid
  27. 1970 Olds 442 Distributor Part #1111979
  28. Parts for my '68 442 Convertible
  29. 1970 -1972 SSI Wheels
  30. 1972 drivers side marker light
  31. I am looking for a 1967 cutlass parking brake assembly
  32. 1983 and 84 Hurst Olds VIN9 Emissions Stuff
  33. 91-93 Olds ninety eight wanted
  34. OAI air cleaner
  35. 70-72 Disc Parts Needed
  36. 1970-72 Decent to Nice Fenders wanted in Indianapolis
  37. 1983 Eighty-Eight Dash Pad
  38. Needed for a 70 Cutlass/442
  39. Wanted 1962 Olds 98 radio face plate
  40. Rally wheel center cap emblem
  41. 1967 Olds 442 Intake Manifold 400 big block
  42. 64 cutlass
  43. 1970 Cutlass Convertible Seat Belts w/shoulder belts
  44. WTB 7040257 or 7040253
  45. 69-70 blue shoulder belt covers
  46. 71 72 sport mirrors
  47. Wanted Posi rear end
  48. 72 vista roof glass
  49. 65 Dynamic Side Moulding
  50. Wanted: 1966-67 400 engine
  51. '70 Olds Distributor 1111982
  52. 72 rear bumper with exhaust cut outs
  53. WTB - 68-72 Rear Sway Bar - BMR, UMI, OEM
  54. Looking for Intact Dash radio opening Cutlass 71-72
  55. 69 442 backdrive linkage
  56. '68 442 WTB - 4spd Bkup Light Switch
  57. 72 Cutlass S Blue Interior
  58. 1-425 piston high compression
  59. 70 bullet mirrors
  60. 69 442 hood tooth
  61. 303 Rocket
  62. 1961 dynamic 88 Windshield wiper motor
  63. 71-72 8.5" 10-bolt rears
  64. Looking for a back seat
  65. 70 vista parts
  66. Need 1 Main Cap Bolt for 400 E Block
  67. WTB: 1972 Blue Standard Steering Wheel
  68. Looking for 1977 olds 88 header panel
  69. 67 442 hood
  70. Tailights needed for 1969 Toronado
  71. Need 70-442/Cutlass convertible rear black trim panels
  72. Wanted SBO Heads
  73. WTB choke stove and heater pipe base to manifold
  74. WTB 71-72 flat hood "no louvers"
  75. Need an oil dipstick for an 87 442
  76. 1954 Olds head light bezel and hood letters wanted
  77. 350 Heads Wanted in Colorado
  78. 1970 Ninety-Eight front nose panel
  79. Still looking for cable mounting bracket
  80. 12 bolt Che*y bare housing or complete rear
  81. need a 350 oil filter adapter and pickup screen please
  82. 1971 Olds Delta 88-Royale Convertible Top Relay
  83. Driveshaft
  84. 76 delta 88
  85. 15" wire hubcap
  86. #5 or #6 heads
  87. '70 442 Power Trunkd Release
  88. 69 tilt column
  89. 64 jetstar 88 steering column
  90. 70 cultlass blue seat backs
  91. 76-77 cutlass quarter panel
  92. 1953 factory AC fender vents+plastic tubes
  93. 72 442 Brake Cast Combination Valve
  94. TH 400 Trans
  95. 1970-72 cutlass console parts needed
  96. interior panels
  97. I need a 1970 jo trans
  98. 1970 jo trans needed
  99. WANTED: 1971 Cutlass Glove Compartment Lamp & Wiring
  100. 1977 olds cutlass
  101. Rally pac fuel gauge for 71 442
  102. 68-72 Convertible Top
  103. 69 Cutlass Passenger door panel
  104. Seeking: Secondary Tone Knob for 8 Track Player
  105. 78 cutlass Taillight
  106. 1970 98 parts needed.
  107. 70 Cutlass Convertible top switch and bezel
  108. chrome hood hinges
  109. 56 Super 88--I Need A Horn
  110. Power bucket seat parts needed. 4 way
  111. 70 S Parts Needed Have Paypal Ready to Go!!
  112. Wanted 70-72 pass door
  113. Radio am/fm 72 cutlass
  114. 72 Cutlass console parts
  115. radio
  116. Thermostat Housing for a 1956 88
  117. Power Piston assembly
  118. WANTED: 1970 442 4speed carb
  119. 65 vista cruiser parts needed
  120. One or two 14" wheels
  121. 11" clutch plate
  122. Wanted wtb 1967 olds cutlass bucket seats ( ohio
  123. 66 power brake vacuum hose bracket & power steering pump reservior
  124. 1972 Cutlass Wheel Well Molding
  125. 455 to TH400 Dust Cover
  126. 68 442 w30
  127. 1964. 442 center console
  128. 72 cutlass hood release mechanism
  129. Rear window defogger relay
  130. 58 371 Block
  131. 66 400 engine flexplate
  132. 78-80 Cutlass/Hurst Olds Interior Parts
  133. 1970 OG turbo 400 trans, air cleaner, SS1 rim
  134. Chrome Oil Pan
  135. (72 Cutlass) Looking for misc interior parts, don't have to be perfect!
  136. 1964 442 air cleaner
  137. 1966 cutlass firewall heater delete plate
  138. 1969 m-21
  139. Convertible windows
  140. 1965 Oldsmobile Starfire trunk letter
  141. WTB: 1970 F85 non vented dash pad
  142. Frame needed for 1965 Dynamic 88
  143. Wanted: 1971 Cutlass console
  144. Tri-Power manifold
  145. 1963 Oldsmobile full size fuel pump glass bowl!
  146. 1967 Cutlass Supreme front license plate bracket
  147. 1966 cutlass parts wanted
  148. 70 fender moldings, eyebrows, used/nos
  149. 1976 Olds 98 white turn signals
  150. Service cover for rear window 68 442
  151. 1971 WP casting #407586
  152. Toronado Door Lock Ferrule
  153. 72 Cutlass Seat Belt Warning light assy
  154. 1968 Cutlass S Glove box door in Blue
  155. 68 442 convertible seats wanted
  156. Wanted 1971 442 drivers side door.
  157. 1963 Olds f85/ ctls 4 spd. flywheel WANTED
  158. 1965 vista cruiser parts wanted
  159. Need 66 442 Hood
  160. 69 cutlass s 15 inch ss1 rims
  161. Dash Delete Plate 66-67 F85 Cutlass 442
  162. 1970 Delta 88 2 door
  163. Wanted: 5.1" water pump for 1972 350 W/Air
  164. passenger 68 a body bucket
  165. 68-69 OAI stuff
  166. 1966 cutlass parking lamp lenses/turn signal lenses
  167. 1969 W-30 parts
  168. Rocker trim
  169. need a LF fender
  170. bumper guard rudders or inserts
  171. Radiator top plate for '68 442…..
  172. 1982 Olds 98 Regency Brougham
  173. Oil Dip stick
  174. 1968/1969 W30 Heads plus
  175. 1967 cutlass trans kickdown switch on carb linkage
  176. 70 442 tail light lense wanted, just one
  177. 69 Rally combo gauge
  178. 72 cutlass convertible door spacers
  179. WTB, choke heater tube, trunk letters etc
  180. 1973 Cutlass S Quarter Panel
  181. Gm fender bottom for l/s 71 72 fender
  182. 69-70 cruise control lever
  183. '69 Cutlass transmission & shifter parts
  184. 70 Parking Light Housings
  185. wanted
  186. Throttle Linkage Plastic Roller
  187. Need 65 442 Throttle Linkage firewall to carb
  188. Need 1970 442 passenger side front fender
  189. Dome light cover '61 dynamic 88
  190. '57 back-up light housing
  191. 1970 442 or Cutlass Fenders
  192. 81-84 olds 307 exhaust manifolds
  193. Oil Galley Plugs - front of 400 motor
  194. 1961 Oldsmobile dynamic 88 Thompson lower ball joints.
  195. need 64-65 F-85 parts
  196. B85 Belt molding 72 supreme and bumper guards
  197. 1970 W31 ram air hood
  198. '70 OLDS 442 Power Trunk Release Switch
  199. 72 notchback molding
  200. 292 B-R Coil
  201. 'N' crankshaft
  202. WTD 1962 Olds reciever drier - NOS / used
  203. 82 Olds 98 Wire Wheels
  204. Runabouts To Rockets
  205. wanted: door hinge
  206. wanted power door locks
  207. WANTED WANTED ..66 olds 98 tail light
  208. Trim
  209. Condenser Insulators
  210. 1967 cutlass parts
  211. G body Hood Trim
  212. 1981 Oldsmobile 98 park lights
  213. A/C Hose Needed!
  214. 71 442 Parts needed.
  215. WTB Boxed Lower Control Arms UMI or BMR
  216. air conditioning system for 68-72 olds models
  217. 79H/O emblem
  218. '68 442 - 4spd Console
  219. 80s 15x7 chrome wheels
  220. Blue 1968 Cutlass S Glove box
  221. 67 Sport Coupe Doors
  222. Head bolt & dipstick tube.
  223. seat chrome
  224. 1957 Olds Back-up light assembles
  225. WTD: P.S. 1400 PSI valve
  226. Needed: 1955 or 56 Hydra-Matic transmission
  227. 1968 Cutlass door panels
  228. TH350 Transmission
  229. nos side markers, tail lights for 70 442
  230. 72 cutlass convertible need some parts
  231. gasket set for 350
  232. Non air 69-72 kick panels
  233. 73-77 cutlass opera window trim
  234. 1969 Cutlass/442 Antenna
  235. Looking for 1955 olds 88 Body to Fender Braces
  236. Trunklid Wanted for 1970 Cutlass Rallye
  237. rear bumper x cutouts and guards
  238. 72 rear bumper with cutouts ands guards
  239. Wanted 1970 Fenders and Drivers Door
  240. Jack Hold Down Bracket
  241. Wanted: 70-72 parts
  242. 71 water pump core w/A/C
  243. Temperature control knobs
  244. Where are the buckets!!!!!
  245. Fan Shroud- V8 Omega
  246. rear bumper assemblie 1955 0lds
  247. long shot/cragar ss
  248. Looking for 71 cutlass 350 intake
  249. looking for 68 4 sp tilt column for 442
  250. Warning when looking for used parts
