69 14 by 6 trim rings
heres a pic 4 trim rings $50 shipped or if you want 14x7 rims trim rings 3 ctr caps $100 plus ship from mass 2 ctr caps a 20 footers 1 is avg driver w<5 pits,
heres a pic w a matching pair of trim rings on a 14x6 and 14x7
Lol I just ran out to check, the left is a 14x6 the right rim is a 14x7 both have a 3" trim ring on them.
I wonder if there are two versions of the 14x6 wasn't one able to clear disc brakes ? I am not that familiar w them but the two in the pic are 14x6 and 14x7.
Nbd I will put them in the classifieds, but I would be interested to know if there are 2" trim rings that go right to the d ring like those.
Just a heads-up regarding trim rings for 6" wheels and trim rings for 7" wheels of that era. First, for model year 1969, the A body used the 6" rim. Second, the pictures above are 7" rims. For 7" rims, the opening for the tire valve stem is closed - a "race track" sort of shape. And lastly, the valve stem opening on trim rings for 6" rims is open - a "U" sort of shape. I've attached pictures of a trim ring for the 6" rim of that era for comparison.
Randy C.
Randy C.
Randy
Good info thanks
Do you know was there more than 1 version of the 6" rim, or did the smaller depth trim ring not extend all the way to the d rings?
The side by side pic shows a 14-6 and a 14-7 rim it's stamped on each Rim so I know there is no mistake there. Maybe the 14-6 is a later date rim ?
Good info thanks
Randy C.
Randy C.
Randy, I think those are correct '68 rings and are very hard to find. I know there are repops like that (attached), but are shiny and are correct for '69 as far as I can tell.
