69 14 by 6 trim rings
Old Jan 30, 2014 | 08:18 PM
dnmfranco's Avatar
wanted four 69 14 by 6 trim rings ty Dean
Old Jan 30, 2014 | 08:21 PM
RetroRanger's Avatar
72 Olds CS
are the x6 and x7 different depths ? I had some x6 and x7 nexts to each other and thought they were the same ?
Old Jan 30, 2014 | 08:22 PM
dnmfranco's Avatar
wow could be I never put them up to each other.
my 69 convert were missing when I got it
Old Jan 30, 2014 | 08:31 PM
72 Olds CS
ive got 4 no better than average drver condition $50 shipped to CT LMK
Old Jan 30, 2014 | 08:55 PM
dnmfranco's Avatar
Okay can you send me one pic of them all the price is fine ty for this
Old Jan 31, 2014 | 08:57 AM
72 Olds CS
heres a pic 4 trim rings $50 shipped or if you want 14x7 rims trim rings 3 ctr caps $100 plus ship from mass 2 ctr caps a 20 footers 1 is avg driver w<5 pits,
heres a pic w a matching pair of trim rings on a 14x6 and 14x7
Old Jan 31, 2014 | 09:02 AM
dnmfranco's Avatar
14 by 6 trim rings are 2 inches wide per another member on here.
Don't think those will work unless I am mistaken they look like 14 by 7
Dean
Old Jan 31, 2014 | 09:14 AM
72 Olds CS
Lol I just ran out to check, the left is a 14x6 the right rim is a 14x7 both have a 3" trim ring on them.
I wonder if there are two versions of the 14x6 wasn't one able to clear disc brakes ? I am not that familiar w them but the two in the pic are 14x6 and 14x7.
Nbd I will put them in the classifieds, but I would be interested to know if there are 2" trim rings that go right to the d ring like those.
Old Jan 31, 2014 | 09:35 AM
dnmfranco's Avatar
See I am not well versed on the 14 by 6 trim rings and or the disc brake rims .
Yeah put them on and see
Old Jan 31, 2014 | 03:24 PM
rcorrigan5's Avatar
Randy C.
Just a heads-up regarding trim rings for 6" wheels and trim rings for 7" wheels of that era. First, for model year 1969, the A body used the 6" rim. Second, the pictures above are 7" rims. For 7" rims, the opening for the tire valve stem is closed - a "race track" sort of shape. And lastly, the valve stem opening on trim rings for 6" rims is open - a "U" sort of shape. I've attached pictures of a trim ring for the 6" rim of that era for comparison.
Randy C.
Old Jan 31, 2014 | 08:18 PM
dnmfranco's Avatar
reference
thanks for the pics that was helpful
Old Feb 1, 2014 | 09:46 AM
72 Olds CS
Randy
Good info thanks
Do you know was there more than 1 version of the 6" rim, or did the smaller depth trim ring not extend all the way to the d rings?
The side by side pic shows a 14-6 and a 14-7 rim it's stamped on each Rim so I know there is no mistake there. Maybe the 14-6 is a later date rim ?
Old Feb 1, 2014 | 10:12 AM
wmachine's Avatar
Trying to remember member
Randy C.
Correct. For '68-'69, the first thing to look for is the "open ended" hole. The rings are much shallower. '68s have more of a brushed finish and the '69s are shiny (polished). The seems to be a second type (still shiny) used in '69 too with the the outer rim part being a bit different as are the clips, I believe.
Randy, I think those are correct '68 rings and are very hard to find. I know there are repops like that (attached), but are shiny and are correct for '69 as far as I can tell.
Old Feb 1, 2014 | 12:03 PM
dnmfranco's Avatar
Kurt all 69s came w 14 by 6 except ho's correct?
Ty dean
Old Feb 1, 2014 | 02:07 PM
wmachine's Avatar
Ty dean
Yes. '68 and '69 SSII are the same 14 x 6 wheel, they went to 14 x 7 in '70. In '68 the rim around the openings was painted silver and in '69 they started the stainless bezel trim.
Old Feb 1, 2014 | 03:02 PM
dnmfranco's Avatar
Okay Ty
Old Feb 1, 2014 | 04:17 PM
oldspackrat's Avatar
I have one trim ring like that, I'll have to find it & get a pix or two.
Old Feb 3, 2014 | 06:44 PM
dnmfranco's Avatar
okay need 4
Old Feb 3, 2014 | 07:33 PM
Here is the one, not sure what year it is for. The pix were taken a few weeks ago & I'll have to look at it again to check for damage.
Old Feb 3, 2014 | 07:44 PM
dnmfranco's Avatar
they should def have opening hole for valve stems and be 2 inches wide. That looks to be one in your pic.
If you have 4 good driver ones count me in
oldsnut1
Feb 21, 2008 05:19 AM
boese1978
Feb 16, 2008 06:46 AM
KL Mallender
Jun 26, 2007 12:57 PM
D. Yaros
Nov 19, 2006 02:19 PM
