PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88
  1. Horn Button
  2. 425 or 455 and/or trans in or near ohio wanted
  3. 1966 442 decklid moulding
  4. 71 442 Grills Wanted
  5. 1964 olds starfire parts wanted
  6. 1964 starfire interior parts
  7. Courtesy Light Cover
  8. 1971 Cutlass Supreme Parts Needed
  9. 67 del mont 88
  10. 67 del mont 88
  11. 67 olds delmont 88
  12. 67 del mont 88
  13. Lightning Rods trans bracket
  14. Wanted: Distributor
  15. convertible part
  16. Rocker Mouldings
  17. trim parts needed
  18. 1970 455 alternator brackets
  19. 1970 455 alternator brackets
  20. 73 DELTA 88 ROYALE CONVERT.
  21. Radio plate Dynamic 88
  22. 1970 12 bolt rear or housing wanted - clean
  23. 10 bolt 3.08 ring and pinion
  24. Moldings Wanted
  25. Pass-side mirror for 1971-76 88/98
  26. 77 cutlass supreme scoop
  27. wanted 12 bolt car possi & 373 gears
  28. 73 omega part needed
  29. Digital Clock or Florescent Clock
  30. looking for a 5 speed Hurst shifter
  31. lowering springs kit
  32. Vista Cruiser Parts Needed
  33. MT front drag tires
  34. 68 Fender Molding & water pump
  35. WANTED: Complete Backseat Frame for '64 Cutlass SC
  36. Looking for a 1968 400
  37. aluminum olds valve covers
  38. Still looking
  39. WANTED: 67 Dipstick (400, 67)
  40. Need Gas tank
  41. WANTED: C heads #394548
  42. WANTED: Return line fitting/line on p/s
  43. 62 Starfire, 88 or 98
  44. 67 Cutlass Bench Seat Needed NJ
  45. '77-80 Center Caps
  46. 65 442
  47. Wanted - OW transmission
  48. roller lifter retainer
  49. 1973 cutlass supreme
  50. 68 400 oil filter housing
  51. Anyone from Wyoming or Utah? Need parts
  52. 69 442 post coupe seatbelts
  53. Looking for 72 fan shroud
  54. WANT TO BUY - SEATS 1973 DELTA 88 CONVERTIBLE (1972-1975)
  55. 455 and auto
  56. Need trim pieces for '50 88
  57. 65 Cutlass door panels wanted, must be nice!
  58. Need a couple parts for a 71
  59. Need trunk emblem see pic
  60. looking for a nice rear spoiler for 1974 cutlass 442
  61. 1966 4-4-2 Fender Wanted
  62. 1975 cutlass supreme door
  63. 67 C/S Side veiw mirror and Trunk Strip
  64. 67 Cutlass Conv parade boot clips
  65. another guy needing 56 olds parts too...
  66. 54 olds 324 dual action fuel pump
  67. Side Scoops 1965 442
  68. 69 Cutlass Mirrors
  69. does anyone have a good cheap 4 inch grider
  70. 400 E block, Flywheel- Crank ?
  71. 1973 CUTLASS SUPREME
  72. wanted 1968 cutlass am/fm
  73. Wanted polished 3711
  74. 70 442 carb
  75. Wanted,,trunk lock emblem for a 73 olds 98
  76. Wanted: 1967 Cutlass Convertible inside rearview mirror support
  77. 1973 Dual snorkel air cleaner
  78. wanted hurst shifter
  79. Wanted 69 Cutlass front clip
  80. Wanted: 4v air cleaner pan to fit my '71
  81. 71-72 Sport Mirrors needed
  82. lookn for 67 olds delta
  83. parts for 1970 442
  84. '95 C/S Convert Parts!
  85. 73 Glove box switch
  86. wtb..snap on center caps for SSIII
  87. 73 Heater A/C Control Assembly
  88. 72 cutlass fender wanted
  89. Need Distributor Hold-Down Clamp
  90. seat belts needed
  91. Harmonic balancer needed
  92. 1978 olds delta 88 coupe chrom-trim rearwindow
  93. 69 Cutlass parking light holder
  94. 455 motor
  95. Early 64 330 rocker arm wanted
  96. 72' 350 timing tab
  97. Looking for 394 goodies..intake and exhaust manifolds.
  98. Alternator brackets for 330 V-8
  99. Late 1964 or 1965 330 heads needed....
  100. 1970 442 Jack, spare tie down
  101. need parts 71 cutlass convertible
  102. 56 Olds windshield
  103. roof for 1973 cutlass supreme
  104. 1962 Jetfire badges,side stainless+turbo unit
  105. Vinyl Top Stainless steel trim for a 72 supreme needed
  106. 1973 cutty
  107. 1973 olds 98 parts wanted
  108. 1956 oldsmobile parts wanted
  109. Good place in MD to find 425 or 455 Engine
  110. 1971 delta 88 seat parts
  111. '68 400 bent oil fill tube-URGENT
  112. 72 cutlass supreme parts
  113. door lock motors
  114. eng wanted '70 455 ...
  115. Newbie: Recently got 1972 ninety eight
  116. 73 delta 88 parts
  117. WTB....68 400 motor or 455
  118. 75 door panels
  119. wanted: 67 rear defogger switch
  120. '67 Rally Pac clock adjust knob.
  121. 67 delmont 88 parts needed
  122. 61 F85 Interior Door Panel
  123. 67 442 Gas Tank Release Vent
  124. 403 Power Steering Pump with brackets
  125. Sport Steering wheel mounting pieces
  126. 1972 442 BLACK DOOR PULL STRAPS
  127. Looking for Steering Wheel
  128. AM/FM RADIO FOR 1971 CUTLASS S
  129. Help in need of a roof
  130. 64 65 Starfire front fender top trim
  131. Need 1973 olds 98 parts
  132. newbie from ny
  133. 4GC CARB FOR 65 442 WITH A/C
  134. lookin for some 1973 olds 98 headlight bezels
  135. WANTED: Frt Brake Line brackets 67
  136. WANTED: UPPER CONTROL ARMS 67 Cutlass
  137. looking for a nice turbo 400
  138. Wanted: 1963 Starfire Power Brake Booster
  139. WTB: '68 442 alternator bracket--AC car
  140. NOS 67 Cutlass Headlight Assy
  141. 1965 cutlass front turn signal assemblies
  142. Distributor Wanted
  143. '66 Delta differential yoke
  144. need Qjet for 68 455
  145. 1966 Cutlass Intermediate Harness
  146. '64 Vista Cruiser wish list
  147. 1964 B-Body fuel sending unit
  148. WTB: 67 Cutlass parts,hubcaps,trunkstrip,mirror
  149. Need mouldings but from where?
  150. Alternator bracket needed for my 350 rocket.
  151. Wanted: Non-A/C Pullies
  152. Fan shroud 73 CS
  153. weatherstripping for 85 delta 88 4 dor
  154. TRUNK FLOOR
  155. Still need front RH inner fender well
  156. need drive shaft for my '57 sdn
  157. 87 Toro need front end parts
  158. Air cleaner for 69
  159. Need Rear Bumper for 1964 Starfire
  160. 1969 or 70 delta 88 parts
  161. Inner Fender Splash Shields - 62 Starfire
  162. Need 350 Rocket Dipstick and tube
  163. 62 A/C compressor vibration isolators
  164. rear tail panel
  165. 1970 Cutlass Supreme Conv rear side glass
  166. WTB 1970 Cutlass front hood molding
  167. original air cleaner body for '65 442
  168. Good Place to buy hood for 68 cutlass
  169. 65-76 455 Oil Pan
  170. WTB-Aftermarket Intake Manifold
  171. 67 conv. rear view mirror bracket
  172. all brkts and pullies
  173. Need a driveshaft for my '57 Super 88 sd
  174. REVEAL MOULDINGS
  175. 1954 Olds trim
  176. need a rear jetstar 88 bumper
  177. wanted: 3 groove water pump pulley for 65 425
  178. TH 400 Trans
  179. WTB....68 hood release lever and brake part
  180. 1972 TH 400 Trans or comprable MI/Ind/Ohio
  181. Wanted
  182. Wanted
  183. if parts needed for delta (convertable parts) craigslist detroit michigan
  184. 15 X 7 SS II
  185. Deluxe belt/Retractor--69
  186. '65 cutlass power steering parts wanted
  187. 71 Fender
  188. Convertible top parts needed
  189. 1957-1960 371 / 394 flywheel wanted
  190. 1969 Cutlass Jack
  191. Another newbie 56 a-c condenser anyone ?
  192. 1964 Super 88 script
  193. rear sway bar 72'
  194. WTB-15x7" Steel Rims!
  195. GLASS
  196. looking for m20 or m22 tranny
  197. 1995 98 part needed
  198. Need Flywheel Dust Cover
  199. 1965 Oldsmobile Rear Bumper
  200. Alternator 1100855 1969 Olds "Needed"
  201. Anyone parting out a '49-'51?
  202. Source for 303/324 mounts? Motor/trans
  203. parts needed for 69 & 70 '88 convertibles
  204. 70 442 waterpump and carb
  205. need 7040250 carb
  206. WTB Delta Royale factory floor mats
  207. Fuel pump eccentric
  208. STONE SHIELDS
  209. Fan shround '73 Cutlass.
  210. 66 Toronado Hub Assembly
  211. 1971 Olds 88/98, 60/40 seat
  212. '71 442 Bumper Jack Base
  213. parts wanted for 1970 delta 88
  214. Still looking for 324 or 303 manifold...
  215. 1970 OAI hood
  216. choke for 67 Qjet
  217. 350 Block
  218. New guy needs 1967 442 RT rear quarter molding.
  219. interior
  220. Hood crossmember and hinges 4 '50 88
  221. 303/324 Intake & ditributor needed
  222. 70 delta 88
  223. '68 Delmont Ragtop frame
  224. ignition switch bezel for 66 cutlass
  225. performer 350 intake wanted
  226. 1955 speedo wanted.
  227. '39 Steering Knuckle Support
  228. interior pieces
  229. need some more parts
  230. Radio Knobs
  231. WTB - '85 442 Grille
  232. 1959 olds 98 headliner parts
  233. A/C vent duct work
  234. Cutlass/442 weatherstrip channel
  235. 1966 Cutlass Instrument Bezel
  236. 65 CUTLASS REVEAL MOULDINGS
  237. 1965 400 ENGINE NEEDED
  238. OAI
  239. trunk lid for 68 convertible
  240. WTB....68 442 parts
  241. Wanted 2bbl Rochester bowl
  242. Another newbie
  243. black carpet scraps
  244. Hello All - Seeking #5 Heads also
  245. 76 olds carb
  246. CHROME STUFF NEEDED!!!
  247. WTB...engine mount brackets for 68 442
  248. 1968 olds delmont convertable
  249. Crank Pully
  250. Tailight lense insert '70 442 ...
