- saddle ash tray door 1972 cutlass S
- 66 442 open element air cleaner
- 1961-1962 88/98 Steering Wheel Needed
- Looking for Black Carpet - 1972 Cutlass S, Console Car
- need 70 heater cover
- 1972 Cutlass 442 Radio
- 66 442 Grille Bar
- WTB 68-69 passenger side fender
- G-body rear control arms
- '72 Supreme lower passenger quarter
- Wanted 1957 oldsmobile rear bumper bar
- Radiator overflow tank for 74 Cutlass.
- 350 D/DX Block
- Flywheel cover
- 68 442 hood
- Wanted original 70 cutlass trunk mat
- 455 block needed
- NOS front bumper 71 -72 Cutlas 442
- 68 Cutlass 442parts
- wanted air cleaner housing
- 1969 Cutlass Supreme - Front Left Spindle
- 1971 442/Cutlass Firewall Stamps Wanted
- Tail light screws for 72 Cutlass 442
- 69 442 floor mats-Blue
- Distributor Part #1112034
- Tail lights for a 67 Olds 98
- Ram Air cleaner 69 cutlass
- Missing exterior trim
- 2 Ga. Battery Cable
- Fiberglass peices and wire harness 70 442
- 73-74 455 Intake 412332
- need chrome-plated valve covers for 1962 Starfire
- Window
- 76 Cutlass Salon rear window trim wanted
- WTB:68-72 Bucket seat lower side skirt plastics
- Need Either 406768 Or 409759 Camshaft
- 1965 442 sedan trim pieces
- 68 cutlass deck lid coupe
- 71-72 cutlass black floor mats
- Bench Seat for '71
- J-Heads (yes J Heads)
- Looking for '51/'52 88 hood/trunk letters
- *wanted* orig. black trunk mat for 68-72 442
- Need 1966 442 Trunk Molding
- Water Pump for 1962 F85
- 1954 Glove Box Catch Plate
- Dashboard clock to fit 72 Delta 88
- 4 BBL Intake for 350 olds motor
- 87 442 parts wanted
- rocker arm bridge and valve spring
- 71 Toronado rear bumper
- 7041257 early 71 date code wanted
- 1967 Driveline
- 1967 Cutlass Bumpers F&B
- 1979 Cutlass Gear Selector Handle (Console)
- sport wheel accessories
- 68 442 convertible looking for a 442 motor any ideas for other motors?
- alternator bracket
- Toro 4th Gen Seat Covers
- `65 Olds (Vista Cruiser) Front End BUMPER Rubber wanted
- 1966-1967 floor shift instument cluster bezel
- WTB: 59-64 Olds/Pontiac Posi 31 spline
- 69 Cutlass Convertible
- 70-72 Blue Rubber Floor Mats
- Right hand fender close out above head light
- 394 part
- 1967 Oldsmobile Cutlass Supreme 442 H / C
- 1964 Jetstar 1 thermostat housing.
- WTB: 72 Cutlass passenger seat belt
- 1937 oldsmobile coupe taillights wanted
- WANTED - Four Cheap 17in Wheels with 5 Lug 4.75 Bolt Pattern
- 1965 Starfire frame to bumper bracket
- back up /reverse lights 1967
- 70 Cutlass Differential Cover and Rear UCA
- a/c vacuum reservoir
- 1957 oldsmobile mobile super 88
- 1975 Cutlass Salon 2 door coupe seats
- Vista Cruiser 65 Rear End Bumper WANTED
- Looking for 407486 Water pump for 71 w30
- 1965 cutlass roof trim
- Wanted: '63 Olds 215 4 barrel heads
- '70 Olds 442 455 Dipstick Tube
- 1970 Cutlass S Green Interior Pieces/Floor Mats
- 1974 H/O 455 intake, carb and air cleaner
- Want a motor
- '70 Olds 442 Tilt Wheel Column Part
- 74 442 grills and emblems
- 1961 Starfire parts wanted
- Original 1967 442 Radiator
- Saddle or Tan or Brown Horn Pad
- 62 starfire under dash vent cover
- 62 starfire power vent window motors
- OAI spring bracket needed for air cleaner hold down
- WTB: pair of 1969 backup lights for 442 or F-85
- omega seatbelts wanted 1973
- 1970 exhaust manifold 455
- Stock Dipstick & Tube Needed
- Edelbrock Performer Intake 455
- 1971 Door Handle Mechanism - Long Shaft
- f85 13"steel wheel
- 1967 442 Red Front Deluxe Seat Belts
- looking for quarter panel for my 66 dynamic
- 1966 oldsmobile 98 convertible front radiator support
- windshield wiper assy.
- Rear End needed.
- trunk mat wanted
- 69 AC/Heat & Console Parts
- 1969 Dash
- 70-72 olds cutlass console parts needed
- 455 Battery Tray Schims
- Weatherstrip Vista Cruiser 1965 F-85 wanted
- 71-72 442 Grilles and Ram Air Hood Latches
- 1966 F-85 square seat buttons wanted!
- G-body Bell housing and other parts for manual swap
- WTB: Throttle linkage 65 Cutlass/442
- im back and need a few parts from you guys
- 72 cutlass drivers fender
- Wanted 66 door mirror
- Steering Wheel Olds `65 F-85 WANTED
- 1965 F85 Hood
- 70 s sports coupe parts needed
- 68/69 front fender chrome on top rear edge by windshield
- 1971 Delta 88 Royale Convertible Parts
- Wanted>66/67 A/C Parts.
- 1969 olds 98 fender skirt trim
- Help - Need 2nd Generation Hurst T Tops for 75 H/O
- 72 442 Larger Overflow Hose Recovery Tank
- Need Pinch Weld Molding trim
- 72 cutlass Oil Pan 350
- Columbus, Ohio
- 68-69 fan speed switch
- 85 Custom Cruiser hood hinges.
- 64 Cutlass parts needed
- Rear bumper fillers
- Olds Stamped Valve Covers Wanted
- Need 2nd Generation T-top 75 H/O - Have set already but 1 T-top has a crack in glass
- 68 442 top fender molding drivers side and hood hinges ?
- '69 Delta 88 Convertible Trunk Lid
- WTB 64-66 cutlass steering column
- Looking to buy a OAI hood for my 71
- 1956 88 more door
- 1977 Cutlass Supreme red steering wheel
- 57 Oldsmobile parts wanted..
- Wanted 63 64 394 dual exhaust manifold.
- Hub for Four-Spoke Sport steering wheel
- Quarter panels and trunk pan
- Generator
- 67 442 Front License Plate Mtg Bracket
- 1973 Delta 88 rear lenses
- 69 Cutlass front bumper brackets / supports
- 65 Vista Cruiser Interior Wanted
- Vista Cruiser 1965 Fender Trim Wanted
- 1965 4 speed console
- 73 Delta 88 Trunk Lock Cover
- Olds 1957-58 Antenna parts
- 68-72 mirror screws
- 69 OG trans
- Drag Link/Center Link grease seals
- carb. and dist
- Flywheel cover
- 1968 Cutlass bumpers Wanted
- WTB OEM 442 OAI hood 71/72
- '65 Vista Cruiser Interior Pieces
- Tailgate window lift motor
- 1973 442 swivel seats, Front bumper and filler panels
- wanted - deluxe steering wheel 54-86 series
- 1980 Oldsmobile cutlass calais parts wanted
- 71/72 442 rear bumper
- Wanted early 68 protect-o-plate book
- 62 starfire windshield pillar covers
- 70 442 convert rear panels in pearl
- Edlebrock intake SB
- Need accesory mounting brackets
- Vacuum Line Protection Bracket Under Back Seat
- Looking for an antenna
- Need a 68 -69 A/C dash pad
- 66 442 Carburetor
- 1967 98
- 455 flywheel
- Wanted 78-79 98 regency rear bumper & parts
- ISO: Interior Pull Handles Olds 98
- 68 cutlass steering column
- 1969 High Compression 350 Air Cleaner
- radio cover plate
- 50's Oldsmobile/Cadillac air filter housing
- 1970 Cutlass/442 radio
- 68 Cutlass console extension harness
- Power Steering Bracket and AC Pulley
- 1969 Cutlass/442 Core Support
- 1971 supreme body
- 70-72 console lock
- looking for 455 near chicago
- 66 f85 seat buttons
- WTB 1966 Toronado door panels
- Need gas tank
- 69 W-30 passenger red wheel well and origina ram air
- WTB 72 Supreme door/window trim
- 71 Delta 88 Mirror
- Right rear wheel opening molding wanted, 70-72
- WTB>78 Omega rear bumper
- WTB: 1979 Hurst Olds Shifter Cable Bracket @ TH350
- Auto Body Cart or Rotisserie
- WTD - 67 D88 RH Rear FENDER EXT'N
- WTD - 66-67 Cutlass A-post exterior
- 1968 convertible parts needed
- Big block with air.
- Starfire 4 Spoke s/wheel Horn button
- 71-2 sport mirrors
- Need Non stainless headliner bow for 55 Olds 88
- 71 cutlass supreme blue interior
- 01-03 Aurora Parts Needed
- search Shocks mounting clip ?!?
- DESPERATE: Wheel for '84 Olds 88 Royale (not Brougham)
- 71 convertable trunk lid needed NYC area
- Looking for NOS front & rear marker, tail light & front grille clear parking lenses
- Help...Need 75 cutlass black bumper guards front & rear
- 56 Olds trim fasteners wanted
- Need parts for my '75 Delta 88
- WANTED: 68 Cutlass front lower air dam right side
- WTB 66/67 Toronado fuel tank
- 70 442 passenger side sport mirror base
- 1971 1972 cutlass supreme door latch
- 1970 N.O.S Black inner fender wells
- 1969 cutlass/442 parking brake assembly
- 68 442 Hood
- Chrome molding needed
- 1964-1966 Olds full size power brake boosters wanted
- '64-'66 Olds full size power brake boosters wanted
- Wanted olds 12 bolt 2.93 gears
- Wanted # 673 posi unit 12 bolt olds
- Guy seeks 71-72 cutlass parts
- 1992 headlight door motor
- Dealer tags
- Bucket seat lower covers
- 66 cutlass grille emblem
- Good OE Used Inner Tie Rod & Rear End Braces 70 442
- rear upper control arm wanted
- Wtb - 66 Toro gas tank
- Holley Aluminum valve covers
- Equalizer Shaft 68 Cutlass Jetaway Column Shift
- Need Front & Rear Bumpers & Guards For a 1975 Hurst Olds
- for '70 442: Valve from the vacuum hose, mounts to firewall
- 70 Cutlass front short bumper brace and driver side front fender filler needed.
- 1968-69 manual single action vista tailgate
- Turbo 400 brackets 69 Cutlass-floor shift
- bracket and pulley set
- Need trunk letter- 65 98
- 12 Bolt Posi Thrust Washer(s)
