View Full Version : Parts Wanted
- 72 cutlass lower a/c manifold
- WTB 62 Bucket Seat Switch
- 70 mirrors
- Ram air actuator
- 70 442 heater switch button
- wanted sbo intake.
- '69-'72 A Body steering column flr shft tilt
- needing some console parts for a 74 Cutlass
- wanted ash tray door 70 442 black
- 1965 cutlass rear bumper & trim piece!
- Wheels steel
- manual console glove box door and antenna
- Rear chrome trim panel toronado 66
- Dash light Holder or socket.
- Wanted, 1968-72 convertible frame, chassis, not top frame.
- chrome eldobrock 307/350 valve covers and breather to trade
- Thermostat housing
- oil filter housing
- Seat belts needed
- 1970 Convertible parts
- Need seat trim
- formula 1 super stock tires
- 67 Cutlass/442/vista dash bezel wanted
- Need '70 Bumper Jack Hook
- OLDSMOBILE vacuum guage
- 55 heater blower control knob switch
- 1961 super 88 door trim needed
- Ridiculous Last Small Pieces Needed -72 Vert Coat Hook
- 1965 cutlass manual seat parts
- 66 cutlass core support
- 69 cutlass fan shroud
- 70-72 RR wheel opening molding
- Looking for 1962 Starfire Parts.
- Looking for 1966 Delta 88 parts...
- 1972 Console Lid Wanted
- 1970 Cutlass Vista Cruiser
- Driver power window
- Look for an engine for 79 cutlass 350 or bigger
- Looking for some floor pan patches 71 442
- 75-77 chrome rear window trim
- rear panals
- 1964 Jetstar 88 engine mounts
- fender molding clips -- who has three for me?
- please help
- Rh mirror bracket '72 Cutlass
- 69 cutlass fender eyebrow molding and convertible deck lid
- 1935 2 Door Trunk Sedan Rt Door and Hinges
- 1972 Cutlass Head
- WTB 1965 88 Fender Emblems
- WTB: Black rear seat for 71-72 cutlass
- Looking for black front seat belts for 71 cutlass
- WTB black bucket seat for 70 Cutlass S/442
- 1961 Wiper Switch
- Looking for a few parts, 71 cutlass
- wanted
- 1957 front bumper brackets
- 68 Cutlass or F85 flat hood
- 68 442 Heater Control Knob
- 1957 hood chrome,hubcaps,radiator
- TH400 in Southern California
- Seeking windshield heater duct for 65 Delta 88
- 68/69 antenna base
- center console
- 4.11 BOP 8.2 gears needed
- 71-72 rear footwell floor sections needed
- Jack base
- need 69 cutlass engine wiring,
- 67 delmont88 front bumber
- Complete set of good, clean, used control arm bolts wanted for 72 supreme
- 1966 cutlass side molding (approx. 10" pieces)
- 69 dated Muncie
- complete a body rear cheap
- 79-81 T/A or Z/28 front sway bar swap for '65 Cutlass
- Oil Galley Bolts...
- Flywheel Inspection Cover Needed
- Choke heater tube
- Power brake booster
- 1962 F85/cutlass/jetfire parts
- 1968 Cutlass Supreme(4dr) Power Windows Relay
- 83 Hurst Olds Cutlass Side Marker Lamps
- speedometer reducer
- 1964 Jetstar Rear Bumper
- 1972 front bench seat side chrome
- '68 442 - Rear Center Bumper Pad
- Side view mirror
- Body panel between trunk and rear window, 72 cutlass
- 1970 Cutlass grill needed
- Left hand thread lug nuts
- Hurst Dual Gate
- TKO 500, 72 clutch and brake pedal setup
- LOOKING for: 1111979 & 704258
- Parts needed for 1967 Olds Delmont 88 2 Dr Hardtop
- 67 330 Air Cleaner
- looking for used 455 long or short block Chicago area
- Wanted: NOS Door Hinges
- wanted 1968 442 ignition switch connector
- 80-85 delta 88 hardtop trim
- 1970 Convertible Top Corner Trim Pieces
- olds 442 TH400 trans needed
- grill needed.....
- Wheel cover clips
- Carburetor Parts needed.
- 70-72 Cutlass/442 Passenger side 1/4 panel
- 1964 Bench Seat Upholstery
- 66 door panels and lower console boot
- Need hood tooth for 69 442
- Steering Column
- Wtb: '56 88 2dr h/t interior parts
- 81-88 Cutlass Amber Turn Signal
- Seat Belt retractor and parking release
- Hood Release Bell Crank For 72 Cutlass
- Horn contact/hub
- wanted olds 403
- P/N 401609 Bar Hood Rear Grille '68 Cutlass
- Sport Mirrors
- Oldsmobile Custom Cruiser Left side front door moulding GM part 20107269
- 77 Cutlass Opera Window Molding
- 1966 Olds gas pedal
- 72 Cutlass exhaust manifold
- 67 manual trans floor hump
- couple things im looking for that will fit a 74 cutty
- 77 cutlass parts list stuff i need
- 1968 hood hinge needed
- 62 Starfire Seats
- 71 cutlass s steering wheel.
- Low buck rebuild needing parts (70 Cutlass)
- 1988 Custom Cruiser Applique moulding clip
- Vista glass
- 72 Cutlass Center Console
- 1972 Cutlass S Rebuild! NEED PARTS IN LANSING, MI
- 1970 f 85 head light bezels inner and outer..
- 71 Olds Cutlass S
- fly wheel cover 1940's
- 77-79 delta rear window trim
- Wtb nice original '70 fender brace (front lower)
- 1965 442 Shifter Boot Non-Console
- 70 442 open face alternator harness
- Looking for Calais 3 Spoke Sport Wheel Horn Cap
- 70 455 tcs solenoid and bracket
- Console top box
- Need a remote control drivers
- Misc. 1957 parts wanted
- 68-71 Left Hand Drum Spindle/hub/knuckle assy
- 65 b-body tilt column knuckle
- JWO Magazine I need Sept 1997 issue
- Load leveler - '66 full size
- LF '69 Cutlass SUPREME taillights
- back up light lens-64 F-85
- 63-64 394 alternator brackets wanted
- Console parts
- Wanted - Fenders for a 69
- ac compressor mounting brackets 66 toro
- 54 324 engine
- 1968 olds 98 convertible inside door trim
- Wanted, Rear Defogger Part
- 400 dipstick tube
- 1968 Cutlass Parts Wanted
- 442 flywheel
- Functional TH350 for 71 Daily Driver near South Jersey
- Seeking - Rear Bezel for Convertible Top Switch
- Need Hurst Shifter Handle
- Wanted hub caps for 66 67 cutlass wire with spinner centers
- 394 4 Barrel Intake
- 64-F85, Cutlass parking lamp
- Need 68 Cutlass/442 Plastic Defrost box / No AC
- Need Good 2 Barrel Carb for 70 Cutlass
- Wiper arms '71 Cutlass
- window trim
- 72 442 grills
- Trim
- wtb aftermarket rear control arms
- 70 Starter 1108389
- 69 cutlass front grilles
- 69 cutlass quarter panel
- Rocket Emblem
- '70 SS I or SS II wheels needed
- '70 Cutlass A/C kick panels needed
- 72 Cutlass Convertible outer wheelhouses
- 73 or 74 omega parts needed
- NOS 71/72 442 Power Door Lock Switchs
- 68-70 Center Console Box Light Assembly
- 65 Cutlass floor shifter top pivot pin & spacer
- '68 auto shift cable
- Tic toc tac rally PAC
- Looking for several things for a 71 Cutlass S.
- 61, 62 or 63 Oldsmobile F85 steering wheel wanted
- Looking for 1970 sport mirror glass
- 1970 dash
- Rear armrests for a 71 Cutlass
- 66 Cutlass emergency brake hardware
- Speedometer Reducer
- 1973 olds 98
- Need a few parts for 71 Cutlass SX Supreme
- 1975 Rear Bumper Mounts
- 70 Cutlass Supreme Passenger Side Grille
- 1970 442 Am/Fm Stereo
- wanted right door mirror for 1973-1976 ninety eight oldsmobile
- 64 Cutlass Clock
- Looking for 71 interior parts, door panels.
- WTB Rear Passenger Door Panel Blk for 67 Cutlass 442
- Need 66-67 heater ac control
- 1964, 65 frame or rolling Chassis
- non-member seeks 67 Rally Pack, project car?
- Cheap 403
- Looking for 1970 98 pass fender and other misc. Parts
- backing plates for 5x5 brakes
- 1968 Dark red/Garnet interior stuff...
- 72 Supreme roof rail trim
- Hub cap clips
- Looking for,,
- Looking for a Camshaft for 1941 Olds
- Starfire tail light gaskets
- Rear Spoiler/Wing Needed...
- 82-84 Olds 98 or 88 opera lights WTB
- 1964 98 rear bumper
- 75 Cutlass Front Bumper
- WTB... 1969 Fan Shroud
- 1959 olds steering wheel
- 71-72 Cutlass Driver's Side Sport Mirror
- WTB Rally pack 70 to 72
- 71 front bumper brackets
- Need bumpers and moldings for '66 Toro
- WTB: 70 442 power steering pump and brackets
- Vintage Oldsmobile dealer neon sign wanted
- Wanted decent running q jet for a 350 olds
- SS II wheels needed
- (1953 upper front grille bar extensions)
- 72 Cutlass Convertible Quarter Window Access Cover
- 69 442 Center console light assembly?
- Wanted 70-72 auto console
- need reclining passenger seat
- 1977 cutlass supreme braugham dash
- need 1970 tsc solenoid
- 1967 442 tail light lens
- 1971 -1975 shift lever for column shift tilt column
- 65 442 automatic shifter handle
- LOOKING FOR 1974 cutlass parts
- WTB 1968 Cutlass bumper
- WTB Road Draft Tube for 61-62 215 v8
- wanted 70 442 pass sport mirror
- CARB AND RIGHT REar wheel well trim
- WTB: 66 442 parts
- 8.2 posi wanted
- Wanted Driver Side Underdash A/C Duct Bracket
- 63 olds f 85
- WTB: Tilt Column
- Kick down cable bushing
- Post car
- 69 cutlass s hood
