PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Engine and trans wanted
  2. HEADERS for 1971 Cutlass Supreme 350
  3. 1970 442 original radiator
  4. Good 425 HC Pistons?
  5. Wiper arm bolts 72 cutlass
  6. 65 cutlass parts needed
  7. hood light 1970
  8. Blower motor switch
  9. 66 442 trunk trim
  10. 65 starfire parts needed
  11. Need left rear wheel well molding
  12. Window trim
  13. 65 Oldsmobile Starfire headlight assemblies
  14. AC 6620 fuel pump rebuild kit
  15. wanted floor mount bucket seat brakets 62 starfire/88
  16. TH400 kickdown setup
  17. WTB 61-63 master cylinder for F-85
  18. Cutlass seat trim needed
  19. 54 olds rocker panel moulding
  20. 68 cutlass S Rear End
  21. Parking light housing 71
  22. 1971 Rear Door Panel Rails
  23. 700R4 converter
  24. In need of a good core 64 F85/Cutlass rear bumper
  25. Dash Insert for 72 Cutlass
  26. '69 350 Carb needed in CT
  27. Blower Manifold
  28. '68 olds #98 front exh crossover pipe
  29. 1969 442 h/o cut out bumper
  30. 70 442 tail light lens
  31. Underhood Lamp 1970 Cutlass
  32. 67 Cutlass AC
  33. Wanted 71 72 vista tailgate and passenger front door
  34. 8 track parts
  35. 71 or 72 core support
  36. 4bbl intake and carb
  37. 1980 442 wheel
  38. 442 Sport Steering Wheel Wanted
  39. 71 Cutlass RR side marker light
  40. 55 amp Delcotron 1970 jan-may date stamp
  41. kickdown cable needed
  42. 70 442 dash A/C Vent
  43. WTB 3x2 intake or complete
  44. WTB Edelbrock 065 (dual quad)
  45. radio needed..
  46. 1965 Olds Dynamic 88 parts needed - if you have any parts lying around, please look!
  47. olds parts 1974
  48. 1985 Delta 88 SEAT Transmissions Wanted
  49. 71-72 non ram-air hood grilles
  50. WTB 69 power antenna
  51. parts for 84 olds cutlass 2dr
  52. 1966-70 delta88, 98 right upper & lower control arm
  53. 71-72 Blue console,possibly buckets too
  54. Defrost air deflector for 37 Olds
  55. 1969 delta 98 bumper and molding for vinyl top
  56. WTB 1968 SSII 14x6 Trim Rings-original
  57. WTB 1970 Oldsmobile SS1 wheels-complete
  58. 37 olds hood ornament for 8 cyl, and grille guard for same
  59. Looking for a reputable stainless steel repair shop
  60. 1980 cutlass parts
  61. console/shifter
  62. wanted mechanical guages 2 5/8 autometer or simillar
  63. power trunk release button
  64. 69-72 8-Track knobs
  65. 68 cutlass sport or 442 left side tail light
  66. 1971 455 and TH400 trans, carb and distributor
  67. wanted trim rings
  68. Wtb 1966 z bar
  69. Walnut Shifter Knob 1970 AT Cutlass
  70. 67 cutlass parts needed
  71. 68-9 Cutlass/442 Rally Gauges
  72. 72 Cutlass AM FM Radio
  73. 1970-72 Bucket seat pan only
  74. 70 cutlass S vinyl top trim
  75. Wanted 1 pc of power window track and 72 Vista rear window seal
  76. Wanted 1957 Oldsmobile Dash
  77. '68 a-body v8 fan shroud
  78. 47 olds wagon rear bumper
  79. Cutlass Supreme Door Pull Straps
  80. Looking for a running 350 or 455
  81. WTB: #5 head
  82. 75-77 air cleaner assembly- Cutlass
  83. !972 CS Convertible dash assembly
  84. 1970 Cutlass wiper washer pump
  85. Wanted: 1972 Cutlass Ram Air Hood
  86. 70-72 Cutlass Convertible piston covers and seat belts
  87. 69 442 deck lid
  88. 215 75 15's but very narrow. and cheap
  89. Wanted : 1970 350 Exhaust Manifolds
  90. '81-'87 Cutlass Quarter Panel
  91. SS1 wheels
  92. 66 Cutlass bumper jack
  93. Used sport steering wheel
  94. 1968 vista cruiser license plate light assembly
  95. Front Windshield Trim for '65 Delta 88 2-Door
  96. Wheels
  97. HD Cooling Parts Wanted 1970 Cutlass
  98. 65 0lds 88
  99. Looking for X left hand exhaust manifold
  100. 12 Bolt "O" axle
  101. 66 Toronado wheel well trim
  102. 69 cutlass hood hockey stick fasteners only
  103. 68 442 fan shroud
  104. Looking for two 2 bar spinners 1965
  105. door panels
  106. alt, dist, and starter
  107. w and z manifolds
  108. need rocker pannel chrome
  109. 1966 Cutlass /442 4 speed floor hump
  110. need rims
  111. 1959 dash pad
  112. 1965 delta rear window trim
  113. ´57 371 Valve covers.
  114. 66 Starfire Dash Core
  115. Edelbrock Performer 455 Aluminum Intake Wanted!
  116. Dash lighting 1971 442
  117. WANTED - 1966-67 Cutlass Parts
  118. Wanted: 1963 Olds Cutlass/Jetfire 215 v8 parts
  119. 1957 Olds Super 88 Dash
  120. I need 1966 f85 deluxe rocker panel trim "driver's side"
  121. 85 cutlass chrome WANTED
  122. 71-72 inner fenders
  123. 68 442 hood
  124. 70 cutlass center console
  125. 1970 Hood Tooth/Hockey Sticks
  126. Needed Badly 87 Delta Please Help
  127. TH350 trans in San Diego/Southern California
  128. wanted: 70 cutlass radio dash section
  129. wanted: 70-72 cs wheel opening moldings
  130. Power Antenna
  131. 1969 442 passenger rear wheel opening chrome
  132. Parts Wanted
  133. (Wanted) 68 cutlass fender antenna
  134. Buick/Olds
  135. hood hinges and core support.
  136. 90-92 Toronado Trofeo' seat trim wanted
  137. Wanted - Rear Convertible Door Panel
  138. 68 Olds Delta 88 hood needed
  139. 1978 delta88 rear bumper wanted
  140. hood trim
  141. Needed: 59 convertible 98 window frames
  142. Parts needed for 72 Supreme
  143. 1968 Cutlass Rear Sway Bar & Stock 4 Barrel Air Cleaner
  144. 8.2 bop rear gear
  145. 87 Delta Drivers Info Center wanted
  146. Vista Cruiser Windshield
  147. Underdash 8 track
  148. 65 Cutlass core support
  149. WTB 72 Cutlass Rear Tail Lites 10/10 or NOS
  150. Lower Deck Lid Molding 69 442
  151. need 68/69 cutlass 442 trim
  152. Needed
  153. NOS Blue floor mats wanted
  154. 73 Olds Cutlass S
  155. rear sway bar 68 cutlass
  156. 442 style manifolds in seattle area?
  157. 72 442 Front LH Black Wheel Well - Still Looking
  158. Gauges 1970 Cutlass, Oil, Water, Fuel
  159. need 1967 Cutlass gas gauge
  160. Blower control switch
  161. Rally Gauges for '73 S
  162. Wanted - 66 Cutlass/442 Rear Bumper
  163. 200r4 dust cover and dipstick with tube
  164. Ash tray door clips #2
  165. Ashtray door spring clips
  166. 72 supreme windshield chrome
  167. 1949-52 rear axle assembly
  168. 1968-1972 Olds 455 Block wanted
  169. 1959 371-394 downdraft assembly
  170. red 1978-79 delta steering wheel wanted
  171. Air intake hose
  172. 1970 442 conv
  173. 1964 jetstar 88 radiator hoses
  174. 2 15x7 rallys wanted..
  175. 1970 cutlass headlight assy + other trim pieces
  176. I need a fender
  177. wanted 1971 442 grilles and tail light lenses
  178. wanted NOS 70 and 71 442 grills
  179. 83-87 Cutlass console lid
  180. '64 Cutlass dog dish hubcaps wanted
  181. 55 Super 88 hubcaps visor
  182. Quadrajet for parts or top plate
  183. 1966 cutlass tail panel
  184. 1968 olds 98 front disc hub and rotor
  185. 350 headers 68 olds
  186. Parts Needed for 1970 Cutlass
  187. looking for 1968 front disc wheel hub and rotor
  188. 1868 olds 98 front disc hub and rotor
  189. 1961 Olds Full Size Front Bumper Part
  190. valve covers
  191. WTB Passenger 71-2 442 Grille
  192. Need 71 Cutlass Supreme parts
  193. Looking for 455 SEA/PDX or Boise
  194. 62 starfire/dynamic parts needed
  195. wanted 62 olds side trim
  196. WTB NOS 72 Cutlass vert wheelwell moldings
  197. 1965 olds starfire convertible trunk lid
  198. back up light lens
  199. Instrument Cluster
  200. WTB Hub
  201. stock shoulder/lap belt combo for 70-72 Cutlass Convertible
  202. Looking for a few 1955 Oldsmobile parts
  203. adapter
  204. 403 oil filter housing
  205. seatbelt indicater
  206. 1956 Olds Carb
  207. Decent straight core support for my 72 Cutlass
  208. 455 Stick flywheel
  209. 69 442 wtb
  210. 70 Cutlass S Side Molding, RH Quarter Panel
  211. 68 Cutlass glove box liner
  212. 1968 wiper switch nut & nice headlight housings needed
  213. WTB scattersheild olds/pontiac
  214. WTB 59-64 posi third member
  215. 1984 Cutlass Ttop metal
  216. 1968 cutlass grill
  217. Vista Glass Needed: Mirrored front piece
  218. 1966 Olds Starfire
  219. 64 Dynamic 88 Rear Bumper
  220. Raydon
  221. 68 'Cutlass' trunk emblem & sun visors
  222. Wanted: 69-72 Big Block exhaust manifolds (W-Z)
  223. console compartment
  224. 65 Delta Fender Rockets Needed Germany
  225. 394 Olds Aternator bracket wanted
  226. 1965 Dynamic 88 Holiday Coupe Rear Bumper Needed
  227. 1967 442 compressor bracket
  228. 7040253 carb
  229. 1973 455 snap disc switch needed
  230. Need a 71-72 Passenger Fender
  231. need a KH steering pulley
  232. Wanted: gears
  233. Non member looking for '65 442 steering wheel & side scoops
  234. WTB: Wiper Switch
  235. WTB '68 cutlass frame motor mounts
  236. 1966 Horn Relay
  237. Wanted: 1962 Starfire/Dynamic trim. Located in Seattle area
  238. th350 1972 cutlass
  239. 56 88 bumper center piece
  240. Hood pop-up Spring
  241. Looking for Quadrajet for 1969 350
  242. Lug wrench/jack handle --> Last part needed!
  243. 71 Cutlass Bumpers
  244. 1954 Bumper horns
  245. 455 engine and transmission
  246. '70 442 Idle Solenoid Bracket for A/C Car
  247. 80's Cutlass tail lights, turn signal, car radio
  248. Electric trunk lock solenoid - 70-72 Cutlass
  249. fuel tank sending unit
  250. 68-72 350 known good running motor or parts car
