PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. '68 442 parts
  2. 1971 Olds 442 w30
  3. 455 engine bolts and oil filter housing for 72 cutlass
  4. Horn button
  5. Looking for a RH Tailight bezel for my 69 Cutlass S
  6. Sbo parts
  7. 403 Pistons NEEDED
  8. Wanted: 65 Ninety eight (98) rear bumper
  9. omaga parts
  10. I need an actual Bumper
  11. OW Transmission
  12. Olds Distributor Parts
  13. 69 Cutlass drivers side mirror non remote
  14. 70-72 Convert 1/4 pan ext. driver's side trim
  15. tow hitch
  16. 1961 Oldsmobile Fenders
  17. LEFT wheel opening molding for 76-77 2dr
  18. 1965 4speed center console
  19. 68 to 72 F-85 Qtr Glass and Hardware
  20. 1971 Hood Cutlas S
  21. 70-72 PWR window/lock setup for four door
  22. Headlight bezel
  23. 1971 cutlass 350 parts wanted
  24. Eagle H beam rods
  25. Harrison Radiator
  26. 1970 Cutlass S Grille
  27. Wanted nos 71-72 Cutlass drivers side fender
  28. 67 rear 1/4's ?? vert
  29. WTB HVAC Blower Resistor GM 419214
  30. 67 Delmont 88 425 flywheel
  31. For a 70 442...
  32. need parts
  33. Wanted for 70 442.
  34. 70 8 Track face plate wanted
  35. 1970 8 Track Unit
  36. 67 442 Hood Lovers
  37. Wanted> OEM 64-67 OLDS V-8 Standard Flywheel
  38. WTB 1973/74 Olds Cutlass Trans Dual Cross member
  39. 1961 F85 Adjustable Antenna Mast
  40. 403 Crank and rod
  41. '67-'68 88/98 clock delete
  42. Wanted: 1969 442 Gold set of seat belts-must be nice!
  43. Edelbrock intake
  44. Need a Diode Bridge
  45. Head bolt studs
  46. 1965 Oldsmoble 98 convertible - need ext trim
  47. 71 Cutlass Doors
  48. Can anyone help me find one of these rims?
  49. 67 Cutlass speedometer
  50. Need 57 left manifold pipe 371
  51. 1970 442 roof channel
  52. wanted tilt & tele steering column.
  53. 1970 442 roof rail holiday coupe
  54. '66 Toronado header panel molding
  55. In search of Lower A/C vents for 70-72 Cutlass with an 8 track
  56. 70 Cutlass A/C wiring harness
  57. Power Window Wiring Harness 70 Cutlass
  58. New seat belts, hoping for help with 76 Cutlass
  59. 67-69 cutlass center console insert
  60. Wanted 1967 cutlass convertible frame
  61. Wanted:'68 W-34 Toronado Air Intake Part
  62. 1970-72 supreme coupe trunk lid needed
  63. 1970-72 supreme coupe trunk lid needed
  64. Wtb:72 S rear driver wheel well moulding
  65. 70-72 Rally Pack - Only Need The Gauge Cluster
  66. 67 Cutlass/442 HVAC Control
  67. going to Tap Plastic
  68. 1967 Cutlass DS Door
  69. 1970 Original OAI Vacuum Motor
  70. notched valve cover
  71. 68-72 clutch/brake pedals
  72. WTB LH alternator brackets for '68 Cutlass V8
  73. Rallye 350 stripes needed nos
  74. 1969 442 grilles and hood extension
  75. Frame for 1964 Jetstar 88 Convertible Wanted
  76. Wanted: 1982 to 1990 Oldsmobile parts and illustration book
  77. Frame for 1970 Cutlass 442
  78. Steering column lock
  79. Wanted 57-64 Olds 3 series Ring and pinion
  80. 58 Oldsmobile 14 inch rim
  81. WTB Wiper switch
  82. Wanted: (1) 14" factory wheel. For 1961-63 Buick Special or Olds Cutlass
  83. 1969 442 ashtray door wood grain
  84. 1971 Sienna Cutlass S
  85. '70 power steering brackets
  86. Wanted - Strato Bench with passenger recliner
  87. cowl seal
  88. CS emblem for trunk 1968 Cutlass Supreme?
  89. Rear end
  90. 1971 Cutlass supreme script
  91. 1968 442 Hood
  92. 64 cutlass auto floor shifter
  93. 67 Cutlass Seat Belt Boot
  94. Edelbrock Performer 2151 BB Olds
  95. 71-72 tail light housings
  96. parts wanted
  97. Parts Wanted - 1969 RH & LH front fenders
  98. 70 Vista Cruiser rear bumper
  99. Wanted Nos 70-72 quarter panels
  100. 70-72 cutlass main console section
  101. Door latches 1967 Ninety Eight
  102. SS1 Bolt On Center Caps Needed
  103. 71/72 four door LH Rocker Molding
  104. Wanted: Nice 72 Cutlass/442 core support
  105. 1951 Olds Super 88 Four Door Sill Plates
  106. 1967 Posi rear
  107. 67 Cutlass Supreme Moldings
  108. 425 piston
  109. wanted - '68 400 water pump
  110. 1961-62 88 dash pad
  111. Looking for 15x7 Wheels
  112. Flywheel 303 or 324 manual
  113. Black 1970 Cutlass S Interior Parts
  114. Canadian Olds guy looking for shift lever
  115. Fender trim, 1960 Oldsmobile
  116. power steering pump 66 cutlass
  117. WTB: 69 Cutlass glove box lock
  118. 672 or 588 Type O posi
  119. sport mirror
  120. wanted - 1970 cutlass shift indicator clip
  121. 1961 88 fender script
  122. roof glass
  123. 66/67 Jetaway Torque Convertor
  124. 1969 Hurst/Olds Parts Wanted
  125. wanted 68 cutlass hood hinges
  126. 1970 hardtop deck lid
  127. compression ring for 4.165 bore Olds
  128. Wanted nos 72 Olds 442 grills
  129. 72 cutlass sail panels needed (upper quarter panel)
  130. Wanted. 71-71 Cutlass Convertible Rear seat upholstery in BLACK
  131. 69-70 M21 and Bellhousing
  132. Front brake adjusters 66 toro
  133. Wanted: Steel 1970 Cutlass hood
  134. Late 50s-early 60s front backing plates
  135. Dealer emblem
  136. 1970 cutlass front clip
  137. 1960 super 88
  138. Iso driver’s side AC vent duct - 70 Cutlass
  139. 78 olds delta 88 royale 350 rocket need some better heads
  140. K50 Climatic combustion control breather
  141. Looking for cruise control parts for 72 Cutlass
  142. Rear bumper 1962 Olds starfire
  143. Wanted: 1962/63 Cutlass 4 speed car or parts
  144. Wanted 72 nos black inner fender wells
  145. 1964 License plate light and bracket
  146. Wheel hubs for 1966 Dynamic
  147. Need horn button and contact assembly
  148. Heat doesn’t work, need blower motor
  149. WTB 1970 442 Water Pump P/N 404847
  150. 66 98 convert pass. side door glass
  151. Wtb
  152. 64-65-66 Console lens ( A body).
  153. 72 455 Air Cleaner Assembly
  154. Shoulder belt guide clip attachment
  155. Olds 350 Aluminum Dual Plane Intake
  156. 72 cutlass dash
  157. Sbo 350
  158. Touring Sedan/Toronado wheel center #25532570
  159. wtb 65 442 bench seat 4 speed shifter boot
  160. 1957 Olds Nintey Eight 4 door sedan, windshield
  161. Need fender extensions for my 66 Cutlass
  162. 85 cutlass
  163. drum brake backing plate adjuster plugs
  164. Help me now!!!! Please !!!!!!
  165. Wanted 76-77 wheel opening molding
  166. 1970 442 Lower Front Air Dam - WTB
  167. WTB 70-442 4 speed top plate console inserts
  168. WTB: 1980-1985 D88 front fenders
  169. WTB: 1970 442 driver's side "W" exhaust manifold
  170. 1968 Convertible Boot Attachment Clips
  171. Needed 1969 oldsmobile TH400 inspection cover
  172. Stock 4 speed bbo
  173. 1968 W-30 KA Pulley needed
  174. 1972 water pump for AC car
  175. wanted; rebuildable set of ,5, 6 or 7a heads and stock 350 rods
  176. 1970 Cutlass master cylinder
  177. 67 Cutlass F-85 rear bumper
  178. WTB Doors 1970-72
  179. 63 Cutlass or f-85 steering wheel wanted
  180. Trying to get lucky, 70 442 grills
  181. Tall Script Valve Covers
  182. 1956 88 hardtop trunk handle emblem and dash cloclock
  183. need speedometer '71 cutlass
  184. Need rear cross bar from convertible frame '71 Cutlass
  185. SS111 15x7 rims
  186. 71 or 72 4 door
  187. 1967 Olds 98 LS Brake Drums
  188. 1967 Oldsmobil 442 front light bezel
  189. WTB - 20" 7-blade fan
  190. 64-65 manual transmission hump
  191. 1962 Cutlass Clock
  192. Wanted for my 1969 442
  193. 1965 Vista Cruiser power steering cap
  194. 1968 Cutlass Supreme Hood Hinges
  195. Moroso Stamped Aluminum Valve Covers
  196. 66 Cutlass Gas Tank
  197. Console Courtesy Lens 64-66 auto.
  198. 66 convert Pass. side door glass
  199. 1971 Cutlass "S" parts
  200. 74 Cutlass Manual Window Regulators
  201. 1970 442 core support needed
  202. Crosswind EFI intake
  203. wagon interior trim
  204. Wanted: 68/69 A/C kick panels
  205. 63 olds brake pedal spring
  206. Wanted: ventless 69 dash pad
  207. Wanted a set of 4 70-72 bottom fender bolts
  208. 1970 Cutlass S rear bumper
  209. 1979 442 grills
  210. Looking for 70 442 grills, originals
  211. WTB '70 442 Trunk Lid
  212. 1970 Vista tailgate parts
  213. Need Toronado Headers
  214. WTB: 455 Valve covers
  215. looking for 68 cutlass fender front support
  216. Wanted passenger side door panel and both rear panels
  217. 70 Body mount brackets
  218. F-85 Rubber mat
  219. 67 Cutlass/442 Rear Quarter Panel Chrome Trim
  220. 70 Front Bumper
  221. Where can I find NEW door windows for my '71 442 convertible?
  222. FRAME (bare) A Body
  223. 66 Cutlass wheelwell trim
  224. Cutlass 442 , Cutlass calipers
  225. 1964 Vista Cruiser it F85 reverse light deletes
  226. 1972 AC or HD cooling water pump pulley #409807
  227. 1971-1972 350ci w/AC or HD cooling water pump pulley #409740
  228. 64-65 a/c control
  229. SSII's
  230. 55 hardtop headliner bows
  231. Reilly Oldsmobile
  232. Under hood light
  233. 70 hood latch
  234. Transmission Linkage Parts
  235. Passenger side '70 bullet sport mirror
  236. 67 cutlass parts
  237. Wanted: 1962 F-85 Left front fender trim mounlding piece
  238. 1968 water pump ka pulley
  239. crankshaft
  240. trailer hitch bumper hitch 1971 442 Please
  241. 1969 Cutlass Convertible Ash Well Panels
  242. wanted 1967 cutlass power antenna K50 Parts
  243. Wanted, 70-72 Cutlass/442 Dash Pad
  244. 1984 olds custom cruiser wagon
  245. SS1 Super Stock I Center cap
  246. WTB 68 Cutlass Conv Hood
  247. 66/67 Power Antenna Parts
  248. WANTED used 455 piston +.030
  249. 1966,1967 LH vent/wing window handle in excellent condition.
  250. Needed 1972 Cutlass Convertible Frame
