View Full Version : Parts Wanted
- wanted shifter cable standard shifter 1970 cutlass
- 65 olds head light trim/bezel
- 1968 cutlass items needed
- '70 Power Trunk Release Button
- 1973 Olds 98 passenger side door mirror
- 68 442 / cutlass convert header panel
- 70 floor shifter parts or whole
- 1961 Dynamic 88 4 dr sedan
- Spark plug wire bracket and power brake pipe
- '84 Cutlass (G-Body) Upper Radiator Hose Fan Shroud Clamp/Strap
- LH-RH 1970 Cutlass doors
- 72 442 Grille - Stone - Housings
- 15x7 SS-II Rims/Bolt-on Center Caps
- 84 olds custom cruiser wagon
- WTB Trunk Logo
- Looking for non A/C 69 Cutlass passenger kick panel
- 63 cutlass power steering wanted
- 68-72 disk brake kit
- 66 Cutlass hood
- 66 Vista top glass trim
- 1970 olds plate light assembly
- Need some help - 1954 98 Sedan
- 1961 Town Sedan
- 1969 am/fm radio
- 69 conv header bow / top rack, black dash pad
- Wanted>66/67 a-body bucket seat lower side trim
- WTB worked big block heads
- 1968-1972 vista cruiser sunlite
- 1962 1963 Cutlass, F85, Jetfire molding
- Wanted: 1962 394 AC pullys.
- 70-72 floor shifetr and cable and brackets
- 69 Cutlass hardtop/convert passenger door and seat belts
- Couple of items needed
- 4 speed conversion parts for '68 442
- 75 Delta 88 Convertible Sun Visors
- 66 & 67 442 hoods
- 68 Cutlass S/442 Passenger Side Tailight
- Window Regulator
- 1959 - 1962 59-62 oldsmobile ac glass bowl fuel filter
- 63 cutlass parts wanted
- Outside Mirror 230365
- Jetfire Turbo and parts
- 2 rear windows for 65 442 convertible
- TriPower Carburetors
- '69 Cutlass reverse lights
- 71 442 / Cutlass Glove Box Bracket
- 71 Cutlass 442 Power Window Feed Connector to Fuse Block needed
- Alternator/starter/Water pump
- 1967 442 Rally Pack Tach
- Pearl or White Head Rests
- 70-72 350 Oil Fill Tube
- 64 Cutlass battery tray bracket
- "96 Olds Aurora Front Seat Adjuster Rear View Miirror Module with Memory
- Olsmobile rally rims wheels original 14x6 great shape white
- Wanted - 1951 - 1956 Manual Transmissions
- 1955 Olds speedo
- 4 spoke steering wheels
- 1963 oldsmobile trunk panels
- Steering column
- Oldsmobile engine mount frame pads for G body Cutlass
- '68 442 A/C Ducting
- Looking for Carb. Core or Used 1972 Quadrajet, part number 7042250
- 1968 350 choke
- Wanted: 1963 Olds Cutlass/Jetfire 215 v8 parts
- 1973 Cutlass front bumper strip
- 391114 water pump pulley
- 64/98 dash A/C vents
- WTB 1960 Olds 88 Dynamic 4 door exterior trim
- WTB 1971-1972 Cutlass Radiator Core Support
- seeker wants 66 bumpers
- WTB: 455 Intake manifold
- 66/67 Cutlass V8 Engine Cooling parts
- Alternator brackets
- 75 Cutlass rub strip for front bumper
- 1973-1975 delta 88 royal convertible door & sail panels
- 68/69 rear quarters
- '73 Delta 88 Royale convertible
- (fabled?) "Engine Assembly Manual"
- 1955 Oldsmobile help
- 76 Cutlass bumper impact strips
- Wanted: "w" lh exhaust manifold
- Frame rails
- 1970 442 fenders
- Lookin for factory wheel lip molding and the beauty rings 1976 cutlass salon
- L-69 set up
- !967 Cutlass 330 4-Barrel Air Cleaner Housing
- 2-way power seat switch 1959, 1960, 1961 bucket 1966, 1967, 1968 bench
- 72 buckets
- 70-72 cutlass supreme tail panel and door panels
- 68 442 hood needed
- Front Coil Springs
- WTB - Timing Indicator
- New user. First post. 64 dynamic 88 2 dr hard top parts needed
- 1963 Cutlass, F85 parts needed
- 1950 Rocket 88 Tail Light Bezel
- E C rad. tag
- Wanted: 1968 442 Front Center Grill
- 1962 dynamic 88 wiring harness
- 1966 F85 wagon parts needed
- Gas Pedal
- For my 1970 Cutlass S
- 63 Dynamic 88 heater fan switch wiring
- 70 Cutlass Hood like this:
- Gold colored floor mats for a 1970 cutlass s
- SS1 15x7 Wheels n Tires
- Drive shaft
- 71 cutlass grills
- Power Steering Bracket
- I need a flywheel
- Need spindle hex nut for '73 Toro
- 1968 A body ignition switch connector
- Toronado Exhaust Manifolds
- Wanted:Dome light door switch 63 olds
- 1970 Cutlass Trunk Seal channel
- Wanted: 63 oldsmobile 98 passenger taillight
- Wtb
- 69-72 power window 1/4 regulators
- Drivers side upper post trim
- WTB 53 Olds owner's manual
- Windshield
- 63 olds 98 passenger side taillight housing and lens
- 71 w 30 distributor
- Radiator Support Hood Latch Support Assy Wanted
- Drivers door arm rest pad 1970 cutlass
- Seaching for Olds 350 Heads replace #8s, maybe?
- 1965 Olds cornering light
- omega rear seat.
- Wanted code "A" wheel (trade my code "R")
- 1991-92 Custom Cruiser center console
- WTB "X" code water pump
- 1967 Cutlass/442 Trunk Trim
- 71-72 Front and Rear bumper guards
- 1966 Vista Cruiser parts
- 48 olds fenders 60 series
- WTB 70-72 trunk lid
- Head Bone's Connected to the....
- WTB: nice 54/55 88 trunk lid
- White upper door panels, rear seat panels 73-76 delta 88 royal conv.
- Needed: 1978 Omega Left Front Parking Light
- 7025050 Carb for sale
- Wanted: Alero Final 500 Center Cap
- WTB: 4 speed console 1968 - 442
- need 2 1956 15 inch rims
- need rally pack
- electric seat parts
- C heads
- 7044559 carb 74 W30
- Rear Bumper Insert
- 55 Seat trim wanted
- 1966 442 torsion trunk rods
- 15" ssII or ssIII
- WTB driver reamer for kingpin bushings
- 1964 Parts Wanted
- 68' 442 Flywheel Cover
- 1964 Seat Belt & Shifter
- 70-72 latch cover
- Horns seat belts
- Steering coupler (RagJoint)
- Power steering pump pulley
- 72 442 grills
- Radio
- 1975/76 Omega hatchback parts wanted!
- 1957 Ext. rear View Mirrors
- !972 Cutlass windshield washer fluid container
- Interior from 1977-87 2 door delta 88
- Holley Fuel pump 12-836
- 68' 442 SSII Spare stud and nut
- Wanted Aftermarket swaybars 69 Cutlass.
- 1962 Stairfire
- 71 auto console
- 1953 oldsmobile front right corner grill mould
- 72 engine harness needed after small fire
- 1975 Fan Shroud Needed
- Need parts for a 1986 442
- Fender Bolts 55 Holiday
- 1953 grill moulding wanted
- 76 Ninety-Eight Regency interior (console mostly)
- Wtb
- 68/69 cutlass 442 front disk brake setup
- WTB nos oem heater control valve
- 72 notchback black
- Olds/Buick 215 V8 used cam
- 1959 Super 88 Pass Door Molding Needed
- 1969 Olds bumper jack set
- '70 blue rear view mirror cover
- 17083553 carb
- 1966 Starfire Chrome and Trim
- Possible WTB - NOS '70 Cutlass S grills
- Jack set
- Unaltered front springs for 1968 442
- Need fuel injection line for '85 Olds 98 4.3 diesel
- 1970 OG tag on trans.
- Chilton Manuals
- 1965 oldsmobile center ac vent. Help
- steering wheel wanted 76 98
- 67 Cutlass fan shroud
- 72 trunk lid and passenger fender wanted
- B body 330/350 exhaust manifolds
- O type 3:08 posi carrier wanted
- F 41 front and rear Swaybars and boxed lwr arms
- 1108387 starter motor
- 455 Oil Filter Adapter
- Wanting 68-72 455 engine!
- 1970 98 cowl plate needed
- BB Exhaust manifolds needed 1970. At least passenger
- 1966 Cutlass rear bumper wanted
- 71-2 442 nos rear bumper
- 71 Oldsmobile Toronado
- 62 Cutlass Roll Pan wanted
- Looking for some 1/32nd Inch Glass Setting Tape
- 72 rust free or close to it driver side fender
- Trumpets
- wtd: Olds fuel-pump eccentric
- 68' 442 Headlight Surrounds
- Need A/C components 1968 442
- Need oil pan
- 1964 - 1965 Cutlass Vinyl Top / Two-tone Trim
- 1970 Cutlass TH400 dipstick tube.
- Wanted, 1971 air conditioning assembly
- Nos Sport steering wheel ( 4 spoke) for my 71 442
- 57-64 Olds/Pontiac Posi
- Vacuum Tank 58 Olds
- 68 442 4spd console needed.
- 72 cutlass parts wanted
- Wanted 63 F85 parts
- 1950 CHevy Belair 2 door hard top trim clips
- 62 starfire a/c switches
- 58s Olds side mirror(s)
- 1970 Cutlass black seat belts
- Looking for 1962 Starfire interior parts
- 1968 - 69 Cutlass convertible power antenna parts wanted
- WTB 1965 left f85 4 door quarter
- 455
- 1984 Hurst Olds ECM / PROM
- Oil dipstick with tube
- WANTED 1965 olds Tail panel
- Back glass
- WTB 4-Speed Console Adapter
- 1973 Cutlass S White Bench Seat Interior
- 1973 Cutlass S Quarter Panels
- 8-Track Inner Control Knob
- 84 Delta rear bumper
- WTB 71-72 hood louvers
- wanted 67 330 -320Hp engine
- Need Trunk Lid for 70 CUTLASS SUPREME
- 1965 R codeWheels,clean bumper cores
- 1108389 starter
- 67 442 emblems and grill bar
- B Head with AIR Provissions
