1970 Cutlass TH400 dipstick tube.
dip stick tubes for t/400's for consideration
these go over to the bellhousing bolt ...
these were on GTO's t/400 I personally took apart from real original cars..
as we know P.O.B. use the same bellhousing bolt pattern...
and the tranny cases have the dip stick hole in the same spot..
so as for cosmeticaly these are above average condition ...
as for being assembly line correct for the Olds ... maybe some one
can shed light on the issue....
Scott
correct fat wrapped around dip stick ... and the 69 has a flat tube pull handle
the 68 is round........
the 67 one on the left for t/400 is spun 1/2 around ...it bolts to the Pontiac
head and wont work ....for/on Olds with out modification.; bending it all up
Scott
Flye
Aug 10, 2009 06:23 AM
