- Headers
- WTB: 1980-90 Custom Cruiser Vent Shades
- NOS '70-'72 Rally Pac Wanted
- 7040255 carb - W31
- Deluxe Steering Wheel Parts
- Arm rest base clip
- 1992 toronado
- Supreme Bench Seat
- 70-72 drivers side trunk lid trim holiday coupe
- Convertible Switch
- 1973 455 manifolds
- 66 F85 and V8 emblems
- '68 '69 442 cutlass antenna mast
- A/c compressor brackets
- Steelies + hub caps + front park lenses
- Need Delta 88 Roof Trim-1984
- 65(64-67?) standard horn button
- ‘70 - ‘72 Hood Lock Latch Cover
- SBO Oil Pan for My '70 Cutlass
- 1983 hurst olds stereo
- Drivers side lower fender trim for ‘67 Vista
- 1968 to 1970 Toronado chrome disc brake rims
- 1981 Cutlass Crusier Wagon Grill(s)
- Driver Side Seat Belt Retractor
- Fuel sending unit oldsmobile dynamic super holiday 88 1963
- Nineteen eighty three ninety eight 2 door
- 1970 Oldsmobile Cutlass 8Trac Installation Template
- Wanted 1970 w30 carb 7040258
- 66/67 lower rear 1/4 panels
- 1970 442 Starter 1108389
- 72 Supreme drip rail molding
- 72 Cutlass S grilles
- Fuel tank oldsmobile dynamic super holiday 1963
- 65 cutlass dash switch bezels
- 1970-72 Dual Gate Shifter pot metal plate with indicator
- 1970 Cutlass/442 NOS Driver side front wheel well molding
- 1970 Ram Air Hood Locks
- Looking for Dual Gate Shifter Ball
- Looking For A Body
- Pilot bearing and misc parts needed
- 1970-72 dash speaker needed - NOS or refurbished
- 65 Cutlass Ignition switch
- 1969 cutlass 442 dash ashtray
- Window seals for 63
- Part Wanted: NOS LH Qtr Panel Extension Molding - 8700878
- Factory Air Cleaner Lid -350
- Looking for 15 x 8 rally rims
- New 10180878 center cap
- Pair 15x7 Steel wheels with snap-on center cap
- 1968-70 EC Radiator Wanted For Core
- 455 power steering pump pulley needed
- 1964 dynamic 88 fuel tank
- 1965 Cutlass RH&LH Side Trim
- 72 Tic Tock Tachometer
- 65-66 Ninety Eight Rear Reading Lamp Bulb Cover & Radio Antenna
- 1946-1948 Radiator Core Support Inspection Cover Needed.
- 1949 98 series heater core
- 1972 442 Passenger side NOS grille
- 71-72 Cutlass tail light housing and socket and wiring
- 8 track 70-72 support strap
- 64/65 driver quarter panel
- 71olds cutlass lower intermediate steering shaft
- 70 442 Ram Air breather wanted
- Looking for 1968 442 convertible frame
- seat belt anchor bolts
- 1956 super 88 hood hinges
- Windshield for '65 Vista Cruiser
- 1984 Cutlass rear sway bar Insert
- wtb: 1966 442 tripower setup
- 69 cutlass double hump hood
- Oldsmobile 7" Connect Rods. Willing to pay up to $600.
- Center Console 1961 - 1963
- '70 442 Repro Grills - P side piece needed
- 1970 cutlass hood. OEM. Located central California.
- 1966 automatic tunnel hump
- 1965 Full Size AC line needed
- 1960 Oldsmobile 371 Engine parts wanted
- Door parts needed for '72 Cutlass Supreme
- 1969 442 headlight switch bezel
- 1970 442 column shift rods with spring
- need a water pump for a 1959 371 olds engine
- 65 Starfire AC line needed
- 403 Engine Wanted
- 66 toro parts wanted
- 66 F85 Deluxe rocker panel trim
- Wanted: 1994 Cutlass Supreme Center Caps Part No. 10207641
- 1968 Ninety Eight Convertible Fender Skirts and interior
- 1968 Left fender peak molding
- 403 oil filter adapter
- 1972 Cutlass Black Armrest and Chrome Bezel
- Need a pair of these - 15x7 442 wheels
- 1967 Olds Cutlass (RH) Passenger rear upper chrome Molding
- 69 cutlass headlight housings
- 1970 vinyl to trim
- Need parts for new project
- 350 Rocket
- Wanted : 1969 Cutlass/442 Hood Hinge Spring
- WTB: OEM Auxillary Transmission Cooler for 1980-90 Olds Custom Cruiser
- Driver side hood hinge 1968 Cutlass needed
- Antenna Mast
- ISO bumpers for a 1967 Cutlass Supreme
- Coil and bracket (69 442)
- ISO 66/67 Big Car Heater Hose Clip/Clamp
- Wanted 65 olds 442 frame
- 1975 Delta88 side gear actuators
- 68 442 front bumper braces needed
- 1961 Olds 88 wiper cowl and shift lever
- Windshield Wiper Motor
- 1970 Cutlass Supreme Window Trim etc.
- 1977-78 Toronado parts cars?
- Belt Reveal Molding - rubber replacement
- WTB: 1980-1990 Custom Cruiser Tailgate Window Exterior Sweep Seal
- 70-72 bucket seat parts
- 1967 Oldsmobile Cutlass Convertible Reverse Lenses below the tail-lights
- 1970 Horn Button Green
- Running 350 Oldsmobile Rocket
- Wanting 425 connecting rods
- T-3 Headlights
- '71 4-speed back drive rod assembly
- 1967 Vista Cruiser right taillight and interior parts
- 63 super 88 brake parts
- Dual Gate Part needed
- looking for a 69 442 aircleaner
- 1970 442 Black Floor Mats
- 1970 cutlass blue floor mats
- 1970 Cutlass 442 Ignition Cylinder OEM or NOS
- 71 Cutlass Automatic Floor Shifter Handle Wanted
- Wanted: 0.040" undersize main bearings, 67 330
- 68-72 Cutlass Convertible Top Frame Assembly
- Wanted for 72 Vista Cruiser
- 1970 cutlass supreme hood
- Poverty Cap
- 1970 Delta 88 rear bumper & tail lenses
- 70-72 Bucket seat near SA
- AM/FM Radio 72 Cutlass
- Oem 70-72 cutlass windshield washer jug
- Trailer hitch
- 1970 olds 442 tilt steering column wanted
- Black 68-72 bench seat armrest bolt Finishing Covers
- Looking for top corner piece on other side of Vent Window (see pic)
- Late 60's AM/FM radio bulb holder
- 70 Trunk lid
- 70-72 small interior rear glass corner brackets
- carb
- 77-78 Toronado Bug Shield wanted WTB
- 65-70 Full Size Wheel Hub
- 73 Cutlass S front upper bumper filler
- 70 Right side rear quarter panel
- 1985 Toronado
- Throttle dashpot
- 4 Speed Tunnel Cut Out for 4 speed conversion '68 442
- Water pump 400269 core
- .921 lifters (2 needed)
- Center dump sbo exhaust manifold
- 67 Cutlass Interior Piece
- 2001 Olds Intrigue GL
- 1967 dash harness and fuse box
- #6 head
- 1977 olds cutlass
- Random parts needed
- Wanted: 70 Boxed lower
- '72 Supreme door mirror
- Ronnie Hinkley
- Feelers for 1961 Super 88 holiday fuel tank
- Oil Fill Tube
- W31 damper/balancer
- 1963 Station wagon tailgate sash channel
- 69 fender and door molding clips
- ‘70 442 conv. Interior resto
- 69 442 head lamp housings
- AC vents
- 1969 443 headlight housings
- 70-72 Convertible Pillar Post weatherstrip NOS
- 71-72 Taillight Housing with wiring
- 1969 442 headlight housings
- 1968 Cruse control bellows
- WTB Stock 324 piston for 1955 324
- need Durabond 0-6B cam bearings ASAP
- ISO D heads
- QJ Metering Rods
- Under dash fuse box for '64 Cutlass
- WTB SSII wheel bezels
- Engine fan 7 blade 22500652
- 66 cutlass “ Oldsmobile “ hood molding
- hood release cable
- 66 cutlass side chrome
- Wheel
- Wanted water pump 404847
- 442 fender emblem
- 1969 442 Black bucket seat covers
- 1955 Olds Front Bumper Ornament
- 1965-1967 400 Piston & Rod
- 1979 cutlass rear upper sail panels
- 1969 443 Headlight/fender filler
- 1968 442 Headlight housings
- 1969 442 Fromt bumpef
- 1972 Cutlass Supreme Parts Needed
- Single seat track needed
- Window Channel Needed
- 1970-72 Air Conditioning Control Panel
- Wanted - '73-'76 Radio Knobs
- Need 2 inserts for steering column bracket 1968 442
- WTB 1970-72 cutlass convertible taillight panel
- seat belt guide/ 74 coupe
- 1949 Sedanett (fastback) need back side window spring
- 1964 F-85 Poverty Caps
- 84 Delta 88 Rear glass trim
- front marker light for 85 delta 88
- Wanted 84 Delta 88 Gage Package
- In search of hood letters 1964
- 66 cutlass window crank
- Bucket Seat Trim Bracket
- 1970 f85 fender Emblems NOS "F85"
- 1970 f85 front and rear bumper nos
- 76-77 Cutlass Rocker Trim (2 door)
- 455 engine
- rear view mirror 1970
- Mickey Thompson valve covers for my 1970 350 rocket
- ash tray door & springs needed
- Dash pieces
- WTB 72 Cutlass Interior Rear Panels
- 4 spd parts -bellhousing / flywheel/ parts etc
- Good used MSD 6AL ignition box?
- Edelbrock 7111 SBO
- NOS 1970 Cutlass Decklid Emblem
- 71-72 Dual Snorkel NH Air Cleaner
- Need Power Steering upgrade for 66 88
- Looking for 1968 Olds 442 carb 7028254
- WTB small block dual quad intake
- 1965 Cutlass dash ashtray retaining pin
- 1965 98 88 fan shroud
- 1973-1975 Cutlass two door right rear quarter panel
- 394
- Beltline trim
- Doors
- 69 442 door panels
- 66 98 actuator
- Need frame/chassis for 1972 Cutlass convertible.
- 70 Rallye Pac and ssIII center caps
- Need Brian Trick's input on rear axle issues
- 1972 Cutlass Supreme Dash Pad
- 1970 442 gold floor mats wanted
- 70-72 factory coolant overflow tank bracket for tank 41008
- 67 exhaust manifold
- 1969 Sport steering wheel horn cap
- 1970 Toronado Q-Jet wanted
- 62 Starfire rear suspension bushes
- Complete Trunk Floor pan
- 1966 Cutlass Convertible Frame
