View Full Version : Parts Wanted
- 76 Cutlass Supreme seatbelts and condensor harness needed
- Rectangle Reflecters for 75 Cutlass Rear
- G body landau molding clips?
- Anyone near Cabool, Mo. ??
- 350 e-brock aluminum intake
- ARGGH! Lost a SS1 center cap
- WTB 1972 AM/FM radio
- need 67 442 boxed rear trailing links
- 1941 Olds steering wheel
- looking for 72 cutlass s parts
- Down on my shift
- Need #5, #6, or #7 heads
- Dash Pot Needed
- olds 455 forged pistons +.30
- a/c part, 70-72
- Wanted-1968 Olds 98 fender script
- 1968 delta 88 bumpers wanted badly
- 1962-63 cutlass factory AC setup
- Weld Racing Pro Stars
- Wanted floor shifter handle that fits a 1972 Cutlass with an automatic
- Double Groove Pulley w/keyway
- Wanted left quarter skin/patch 1971 Cutlass Supreme
- wtb: rear window defogger switch
- 75-77 Hurst Hatch Weather Strip
- restoration started on 79 hurst Olds T top Car
- 1987 dual exhaust crossmember
- WTB 455 Exhaust Manifolds for 72 Cutlass S
- WTB Air cleaner trim ring
- wanted: 68-69 8 track housing
- Steering wheel needed.
- 68 delmont 88 w/455 Rear Brake Drums Needed
- 64 Cutlass arms
- 64 Starfire Conv't Jack & Spare wheel/rim
- 455 Exhaust manifolds
- 7028250 - '68 350 carb
- WTB 1956 Bumpers
- WTB fender
- 64-65 F-85 Power steering pitman arm
- WTB speedometer drive gear for TH400
- 1959 olds 98 2dr
- 200-4r frame extension
- 1979-1986 Power seat transmission
- '75 Cutlass Parts
- 1956 backup lights
- WTB Z-Bar 68 Cutlass/442
- Klaxon Horn
- Wanted 71 442 4 speed shifter handle
- wanted 1968 olds delta 88 parts
- Wanted: Aluminum A4 intake manifold
- 64-65 frame
- Wtb cutlass wheels
- WANTED: oil filter housing with cooler lines
- Fender
- grill bumper moldings 1969 delta 88
- 1968 Olds 98 fender script
- 66 Cutlass Convertible Top frame Bolts
- '65 Post Car Side Glass
- WTB: Delta 88 Royale taillights
- 1969 glove box/console lock
- WTB 73 Air Cleaner
- 1980 Delta LH grille
- Winshield switch
- 70-72 running 455
- 71-72 cutlass clock
- Exhaust system / 1971 Cutlass 4door
- i search for my 1971 Supreme 4door A/C
- 455 F or Fa Block
- Starfire tach
- Wanted good running 330 engine
- 1972 cutlass conv. side panels
- 72 cutlass parts needed
- Wanted, 455 Crankshaft
- 59 Parts Needed
- Need rearview mirror for '73 Delta 88
- Looking for '52 303 drivers side exhaust manifold
- 62 Starfire/88/98 Turn Signal Cancel Cam
- manifold and carb
- center caps
- wtb 1971 cutlass 442 HD radiator
- WTB 69 drivers side AC vent duct
- WTB: 1973427 OE vacuum advance
- I need 56 Olds Fenders
- Wtb body side moldings 69 cutlass
- WTB: 81-85 Delta 88 grille
- '73 Cutlass Front Turn Signal Housings
- Underdash A/C Vent Hose
- 1970 71/2 Cutlass front fender L/R
- WTB Clean rear bumper 1976 Custom Cruiser
- Head bolts
- wanted 76 98 steering wheel,burgundy/mohogany
- WTB: Pair of #6 or #7 heads with valves, in good condition, in the NE US
- 72 olds 350 exhaust manifolds
- chrome parts.
- tilt wheel column
- WTB: Set of good used 6cc or Flat 350 Pistons
- Parts needed
- 73 toronado tail lights
- 1965/1966 Console Door
- Trunk Lid
- HELP delta 88 lovers
- Olds 88 1967/68 rear quarters/RH fender
- Quarter glass
- Rear Rubber Brake Hose 1970 Toronado
- Posi rear end
- 1966 cutlass 330
- 1992 bravada gillie
- 72 Cutlass Supreme In Need
- wtb 72 cutlass cruise control parts
- 1957-58 2G or 2GC carb. 371
- air cleaner 72 ram air needed
- 82-85 Delta 88 Rear Bumper
- Wanted-Front bumper, 68 Delmont 88
- Sunroof Drive Cable
- Wanted: Any F-41 Suspension Components for '85 Delta 88
- Wanted, 455 Distributor
- Eagle alloys for SSIs
- WANTED: Dust Cover 2004r from 307 Olds
- Dynamic 88 Bumpers
- dual gate light housing wanted
- trans shift lever (@ trans) for 2004r for floor shift
- Hood latch assembly
- delta88 converteble rear bench speaker
- 1956 olds parts wanted
- Bench seat with arm rest
- Oil Filter Adapter
- 69 442 tailpipes
- 3A head
- 1969 Cutlass S AC duct
- AC duct
- 1956 98 kick panels wanted
- NOS Quarter panel
- 1969 442 front bumper
- 1956 power antenna chrome nut and bezel
- console box 71 cutlass..
- One Lonely Part
- g body brake pedal assembly
- 70 cutlass supreme hood
- 1964 olds lenses needed
- Lower coolant hose spring
- 70 w-31 heat tube
- Oldsmobile 1950 deluxe 98 - Front upper grille
- Wanted Tilt Tele Steering column 67-68 Olds 98.
- Tension Rods
- WTT: 425 & 455 for a 324
- 1970 Sport Mirrors
- I need g-body t-top chrome trim
- 67 delta 88 fenders
- 57 Olds 2dr. HT.
- 68 non rally pack fuel level harness
- 68 442 a/c hoses
- 1970 Convertible Top pwr switch
- power window wiring harness
- headlight retainer ring
- Rear View Mirror 62 Starfire Convertible
- Wanted: 1972 dash pad
- 1950 Olds 98 - Front grille
- Steering wheel for 68 Olds 98.
- 70 S trunk lid
- 66' 442 spark plug wire loom & bracket
- air cleaner heat tube
- Transmission coolent lines
- for 1970 olds restoration radiator hose muffler
- steering wheel 1941 Olds
- front bumper 69 cutlass/442
- 66 cutlass hood hinge
- 78 Dash
- Grille & Bar...circa 1955
- Wanted: 1949-50 Instrument cluster
- Looking for an HEI and intake
- Intake manifold hose barb
- 70 Vinyl Top Trim needed
- 15-inch wire wheel covers
- 1957 Olds 371 Passenger Side Exhaust Manifold
- Delta Large Center Caps
- 15' Rally Wheels
- Need speedometer for 68 Olds 98.
- wanted; edelbrock 04b intake
- 1963 cutlass jetfire console,fender trim
- Need 81-84 98 regency/ delta hood insulator panel nos or near new!
- 61 dynamic 394 thermostat housing
- 1974 DELTA 88 vert
- 1971 Cutlass lower inner taillight lens
- 1974 delta 88
- Pulley's wanted
- H heads dated 1970
- throttle cable /kickdown bracket. 1972
- Power Brake Booster Needed
- 200r4
- Offy 360 or Edelbrock performer
- 1970 Cutlass standard or S hood needed plus bumpers
- Oldsmobile Radio 1950-1952
- 1970 W-30 Parts Needed
- 1970 cutlass
- burgundy front seatbelts 73-77 cutlass
- WTB: Cheap original AM radio for 72 Cutlass
- 66 ,67dash filler plate
- t handle set up-65 cutlass auto
- gutter trim 72 cutlass supreme vynil top
- wtb 1959 convertible 98 parts/car
- wanted rear arm rests and rear seat 66 Cutlass Convertible
- Radiator Insulators 407122
- 1970 oldsmobile ninety eight
- 1975 or 1976 oldsmobile ninety eight
- 1969 4 speed console rear light housing
- 1968 442 carb wanted
- font bumper inserts cutlass salon 1975
- 69 Cutlass S
- 402295 LH Exhaust Manifold
- 69 Cutlass Convertible Trunk Lid
- Corteco 55661HG
- emblems 72 cutlass supreme
- Gm 3.91-1 ring n pinion for 672 carrier
- 64 F-85 Wiring Harnesses(es)
- Forged 350 +.030" pistons
- Aluminum A/C service port dust cap
- 324 motor parts needed
- Factory TH400 Dipstick And Tube Needed
- 1966 oldsmobile starfire parts needed
- 1968 delta 88 front pass. fender extension
- Bumper needed
- 1970 colors and fabrics dealer sales book wanted
- 1964 cutlass auto floor shift linkage
- Wanted: Flexplate Bolts
- 71 cutlass conv header bow
- door panels/floor pans
- looking for 231 rwd buick engine
- 2 15x7 ralleys
- 68-69 cutlass sail panels
- 66' cutlass rear quarter moulding
- WTB 1948-1951 Instrument Cluster, Any Condition
- 442 ram air hood
- Wanted: 71 Supreme Wide Body Trim
- 67 442 Headlight Bezels
- Brake drums
- 68 69 cutlass 4 speed Hump
- 64 F-85 Cutlass parts
- Help with console
- 455 aftermarket carb?
- Brake pedal mounting bracket
- 1970 bumper for sale looking for ram air hood
- 68 4 core radiator top plate
- 1966 L69 Intake (WANTED)
- 1964 Jetstar 88 Pitman arm needed
- Olds 350/ 455
- '70-72 Convertible Rear Upper Panel---donor piece needed
- a few items needed
- 70 cutlass woodgrain steering wheel
- 69 Cutlass Convertible trim
- OAI metal air cleaner lid
