PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 1966 and 1967 bumpers
  2. New guy --> Great Guts need parts for 65 Cutlass
  3. 64 cutlass convert. trim
  4. 330 4BBL Carburetor
  5. Olds 455
  6. 67 cutlass center counsel and buckets
  7. 1972 Sector Gear for Tilt Wheel
  8. 83 H/O Air Ducting
  9. hubcaps for a 64 cutlass
  10. Fuel gauge for 56 Oldsmobile
  11. 1970 w31 cam
  12. 1957 371 J2 Kickdown Linkage
  13. Need working headlight actuator for 66' Toronado Please
  14. 1968 Olds chrome dash knobs
  15. 1955 S88 Window Bumpers etc.
  16. 71 Cutlass/442 fuel door/plate holder
  17. I need a Fan shroud
  18. 1974 75 Hursts Owners/Parts wanted
  19. 66 442 Timing Mark
  20. WTB: Big Olds rear sway bar
  21. harmonic balancer
  22. '57 super 88 holiday coup trim
  23. fuel, oil, temp gauge
  24. Looking for this Plastic Nut
  25. 1970 442 Radiator Shroud Wanted
  26. 64 dynamic cove trim
  27. Wanted Drivers side Exhaust Manifold for '66 425
  28. Shift indicator for 1983 w/rally pac
  29. Shoulder Belt Receivers Needed
  30. Looking for a 1966 Toro front grille please.
  31. 1987-88 Euro style Lebra Front cover
  32. Good running V6 Cutlass engine- Buick 231 3.8
  33. 58 Vacuum Wiper Motor
  34. 1965 b-body
  35. Wanted: Moulding for 1976 Cutlass Supreme
  36. Wanted 1951 S-88 1952 S-88 Hardtop Or Conv L&R Doors
  37. 56 headlight switch needed
  38. 66 trim panel chrome needed
  39. 69 Cutlass floor mats
  40. Clock for a '53 Olds...
  41. 1986 olds 442 rims
  42. 73 delta 88 frame mounts for 455 engine
  43. Early 400/425 flex plate
  44. 64 cutlass convert trim
  45. 65 Cutlass Parking lens gasket
  46. Need AC Duct Hose 69 Olds Cutlass
  47. 66 Cutlass steering wheel - Red
  48. 72 cutlass A pillars.
  49. Load leveler control valve
  50. '70 Cutlass 37 Amp Alternator Core wanted
  51. 1957 Super88 rt rear quater panel
  52. WTB - Broken Tachometer for 70 to 72
  53. 1970 442
  54. 1970 Cutlass Hubs
  55. chamshaft and lifters
  56. wanted 69 442 convertible rear fender moldings
  57. '69 442 Exterior Mirror Gasket
  58. rear view mirror w/ map light
  59. Looking for an ED radiator tag
  60. Needed, 1966 425 toronado harmonic ballancer,
  61. 1962 F85 w/215 V8
  62. Want to buy seats or seat covers for my 72 Cutlass
  63. Edelbrock 7111 SB intake
  64. 1984 hurst olds header emblem & dash plaque emblem wanted
  65. 1970 cutlass conv wheelhouses
  66. cutlass parts needed
  67. Onewoman
  68. 64-64 F-85 Post Car pass door window sash channel
  69. '70-'72 Cutlass Frame
  70. Need 5 good 73-74 SS2 wheels, w/BOLT on centers
  71. 371 heads
  72. I need just the body of a 68 cutlass s
  73. 1970 442 parts wanted
  74. 64-69 Cutlass 4spd console glove box door
  75. 66 Cutlass front drum and hub
  76. 66 Cutlass convertible
  77. 330 Intake Needed
  78. WTB 70 Toronado parts
  79. rear upper chrome bumper ends cutlass.
  80. 57 Olds Convert
  81. 7040253 Carb
  82. 68/69/70 oldsmobile hood script emblem
  83. 68 Cutlass S Convertible Hood
  84. Wanted 1961 Full Size Wagon Tailights & Back Up Light Assy's
  85. 1970 442 Misc. Parts Needed
  86. 67 cutlass supreme dip stick broke
  87. WTB 403 SBO fuel pump eccentric
  88. looking for 1970 Olds distributor 350
  89. looking for a factory AMP for a AM-FM Radios
  90. Looking for edelbrock intake for a 350 olds
  91. 55 Olds front end trim
  92. 1969 mirrors
  93. Last Gen Aurora front plate delete
  94. 4-dr Interior Rear Passenger Panel
  95. Electric water pump
  96. 1967 2 door Cutlass Supreme post car chrome trim
  97. 1972 cutlass parts needed
  98. 70-72 A/C dash pad
  99. 13" - 4 x 4.5" rims needed
  100. Looking for a solid running 425 or pre70 455
  101. WTB: 1968-1969 400cu in Intake and Carb (AT)
  102. Needing Pistons
  103. 55 Olds front end trim
  104. trailer hitch for a 59 olds
  105. Passenger side 70 chrome mirror
  106. NOS '77 Cutlass fender
  107. 455 Engine block wanted
  108. want 1966 442 hood
  109. 1969-1972 GM A-Body TILT STEERING WHEEL
  110. looking for a rally wheel with bolt on center cap
  111. Wanted: Rochester 4bbl carburetor
  112. 1948 Olds 78 Hydramatic Transmission
  113. 1970 Oldsmobile, drip rail molding
  114. WTB!!!! 1966 Olds Starfire
  115. Black deluxe seat belts....
  116. Interesting 1983 Olds Hurst parts/collectibles/etc wanted
  117. 1983-87 Toronado Steering Wheel
  118. Wanted 66 442 door trim panels
  119. 65 vista cruiser part needed
  120. oil dipstick tube
  121. seal question
  122. Wanted: Floor shift column, maybe tilt that fits a 1970 4-4-2
  123. 67 442 hood
  124. 4 core radiator
  125. 65 vista cruiser moldings WANTED
  126. 67 two door post vent parts
  127. 84 olds custom cruiser
  128. 70 A body tail light assemblies.
  129. WTB 70 W30 4 SPD Carb and Dizzy
  130. 66-67 Cutlass 442 - Red
  131. Need an Accelerator Cable for 73 Cutlass
  132. Turn signal lens and trunk lock flip cover needed
  133. Chrome
  134. 70-72 cutlass console light switch plunger
  135. Part needed 403 - EGR Control Valve housing
  136. wtb 68' 442 Convt Rear Interior Panel / Armrest
  137. hood hinges
  138. '79 Cutlass steering wheel
  139. 73 delta 88 rear control arms
  140. NOS or super clean 403703 Auto Trans Cover (Plastic Inspection Cover on bellhousing)
  141. 72 Cutlass 2Dr Hardtop Window Molding
  142. C heads
  143. 76-77 rear bumper
  144. Wanted>64-72 cutlass rear backing plates
  145. Ever had a torsion bar snap on you anyone?
  146. 69 steering wheel.... Gold
  147. 1968 Oldsmobile Toronado missing parts
  148. 1981 Olds 98 Regency RH bumper filler
  149. Seeking 63-64 Oldsmobile drivers side exhaust manifold 394 engine
  150. 1967 Cutlass Steering Wheel WANTED
  151. 1969 442 shell - any condition
  152. ISO power bench seat drive cable and gears
  153. serching for 1970 Oldsmobile intake manifold
  154. ISO 1970-72 Cutlass AC/Dash Vents
  155. Help! need parts for my 63 Olds F85 Convertible
  156. 1970 Cutlass Supreme Convertable
  157. Need this small door part...
  158. 1976 delta 88 headlight bezels
  159. '68 under radiator air dam
  160. searching for 64 f-85 passenger quarter panel moulding
  161. Radiator
  162. 71 442 charcoal canister bracket
  163. Need the Power Steering Pump Bracket
  164. help! hood came threw windshield
  165. 72 2dr Holiday Coupe vinyl moldings
  166. NASCAR Block
  167. 75' 88/98 headerpanel & white or blue door panels
  168. Cruise Control
  169. WTB 403 cylinder head bolts
  170. 70 72 cutlass ash tray door needed...black
  171. 68 rear pillar post molding
  172. Need a Pass Side Ex Manifold
  173. Bench Seat
  174. Frame for a 1970 cutlass 4 door
  175. 71 442 Non OAI Dual Snorkel Aircleaner
  176. R Code Steel Wheels
  177. '69 4-4-2 Stock Intake Manifold
  178. '67 Cutlass/4-4-2 Dark Blue Steering Wheel
  179. SBO intake
  180. 324 oil canister
  181. Gold floor mats
  182. 1970 w31 intake
  183. 70-72 convertible top switch BEZEL
  184. 1966 F85 seat buttons
  185. 1964 "Cutlass" fender emblem
  186. toronado tilt column
  187. 1956 Power steering gearbox
  188. 68 cutlass s 442 hood
  189. 1975 hurst
  190. Wanted: 64 cutlass convert. parts
  191. 1971 Cutlass S Grills
  192. Shifter Cable in San Antonio Texas
  193. Exhaust Manifold- 70 Delta 88- 380145 LH D1
  194. 1957
  195. 1966 toronado accelerator
  196. Wanted : Reasonably Price 83 Hurst Olds Hood
  197. WTD,A4 inlet manifold willing to post to New Zealand
  198. 442 w30
  199. Fenders nos
  200. Dash board
  201. 67 hood hinges
  202. 65 cutlass top door plate
  203. Bench Seat side chrome cap
  204. 68-72 rear seat
  205. 1968 442 R Fender Peak Trim and Eye Brow Trim needed
  206. 1967 98 Hood needed... and info! WV, PA, OH, MD
  207. CA man seeks 67 442 RH/pr xst man(s), radiator support
  208. need 64-65 Cutlass channel-front door window.......
  209. 83/84 H/O maple interior parts
  210. Wanted-- 68-72 Cutlass Power Window Regulators
  211. 57Olds
  212. dome light covers
  213. Wanted: 1970 442 OG transmission
  214. Top radiator plate that can fit a 4 core radiator. 72 cutlass
  215. Wanted 1967 Cutlass Rear Bumper Wanted
  216. Wanted 1967 Cutlass F85 Rear Bumper Wanted
  217. 55 manual trans
  218. Need a '68 442 passenger hood hinge
  219. 84 olds custom cruiser
  220. 75' 88 vert parts wanted
  221. 1968 cutlass bucket seat back
  222. 66/67 cutlass hood
  223. 1971 S doors
  224. 65 Olds Cutlass
  225. Wanted....1967 dash. W/o pad
  226. NOS 81-83 Cutlass Tail Lamps
  227. Lansign area man seeks 70-72 SB 4-bbl setup
  228. Door lock Bell Crank Assy 1969 A-Body Needed
  229. 1952 88 Glove Box Latch
  230. Cylinder Head Cores
  231. Trailer Hitch
  232. Wanted B-pillar trim 85 cutlass
  233. 5.00 ring & pinion
  234. SSII wheels for bolt on center caps
  235. Wanted: 64 cutlets driver side door handle assembly
  236. Wanted: 64 cutlass auto floor shifter
  237. WTD: 67 Cutlass power steering pulley
  238. courtesy light switch
  239. 67 442 Convertible turbo 400 crossmember
  240. Quarter panel chrome
  241. Vinyl trim pieces for 1968 Olds Cutlass S
  242. BBO Heads
  243. 62 Olds 88 Bumpers wanted
  244. '64 Dynamic 88 HT trim
  245. 3 speed Yoke
  246. bop 8.2 posi and gears
  247. Looking for a '67 or '68 full size car burgundy dash pad/kick panels
  248. 1973 Oldsmobile 98 Regency Propshaft
  249. 3.73 gear & posi
  250. need power steering brackets and bolts!!
