PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Rear bumper for early 80's delta 88
  2. Looking for a Aluminum intake to trade 4 Original 68 intake/carb/air cleaner
  3. Hey guys I need some help 1969 cutlass parts needed
  4. Wanted ring gear and pinion 70 442
  5. Door mirror installation bolts
  6. 1970 12 bolt ring gear and pinion
  7. Need exhaust manifolds
  8. Need arm rest back cover.
  9. Rochester #7041250 needed
  10. Wanted: 1963 Cutlass F85 rust free trunk lid.
  11. 7040250 nos carb
  12. 7040255 carb
  13. Wanted: 1957 Olds full dash frame & instruments
  14. Need pulley's for 70 cutlass 350 w/ac
  15. 66 442 bumpers
  16. 1968 Cutlass S - water pump pulley & sail panel metal.
  17. 1975 custom cruiser left front turn signal
  18. 7a heads, good running condition
  19. power window wanted
  20. Need a '67 442 motor
  21. rear set of seat belt buckles 71/72 GM
  22. Need 390390 E intake manifold
  23. 70 Toro Dog dish Hubcaps
  24. 68 Cutlass S Convertible
  25. Linkage Bushing 72 cutlass
  26. Chrome reverse wheels wanted
  27. 66 442 Drivers Side Inner Wheel Well Needed
  28. 1972 Cutlass 3 row radiator
  29. 1967 442 Window cranks
  30. #1100890 - 70-442 alternator
  31. Right outside mirror for a 67 vista cruiser
  32. Trailer hitch 69 Cutlass
  33. 1970 olds f85
  34. deluxe seat belts
  35. Steering Column needed 1972
  36. Throttle Cable and Bracket
  37. 69 dated muncie 4 sp wanted
  38. 5.7 diesel
  39. Gauges from Ralley pack for 69 Cutlass
  40. 68-69 cutlass wagon/vista manual tailgate
  41. 1969 Cutlass Supreme Front Clip !
  42. 1969 Cutlass S 2 door Post car
  43. Wanted: 1970-72 Vista Cruiser Tailgate
  44. 1108387 Starter Needed
  45. Rear light lens
  46. junk tires/rims for roller
  47. 4 Spoke steering wheel Saddle
  48. wanted: 69 H/O intake and distributor
  49. Pearl/white head rests 4 bucket seats 68-72?
  50. Drivers side visor mount 70 cutlass supreme vert
  51. 4 core top plate rear upper frame braces and...
  52. 1972 442 grill molding
  53. right side mirror '69, 98
  54. Need Power Antenna '67 Delta!
  55. Convertible Frame (Chassis) boxed sections
  56. 70-72 coupe nos rear 1/4 wanted
  57. Convertible Top Frame Part
  58. 64 330
  59. 70/71 red inners wanted
  60. Wanted running BBolds 400 425 455 or shortblock
  61. '71-'72 Dual Gate Shifter
  62. Wanted: Factory throttle cable
  63. 66 4 door cutlass back glass
  64. Cutlass Convertible Rear Armest
  65. 72 lower tail light lense needed
  66. Black Door Pannels 1971 Cutlass convertible
  67. WTB - '66 98 crossmember support bushings
  68. 1971 secondary choke pull off and A/C Solenoid
  69. 04b
  70. need a 2 groove 6 5/8" dia PS pulley
  71. 67 442 parts
  72. Trim screws for 1962 starfire
  73. 1968 Cutlass Automatic Shifter Console Top Plate
  74. Wanted: 1970 Trunk Lid Sport Coupe
  75. wanted, 65 old's 98 radiator
  76. 68 Cutlass trunk lid needed
  77. 68 442 a/c ducts
  78. 65 cutlass parts wanted
  79. looking for a flywheel and bell housing
  80. Flex plate.
  81. 1962 Bumpers
  82. 73-77 rear brakes
  83. 231 v6 intake manifold
  84. 1962 Dynamic steering column switches
  85. Door
  86. good pair 1970 fenders
  87. 1966 442 washer pump asy for round pump
  88. Need brackets for floor shift cable at the trans
  89. WTB: Stereo for '71 Cutlass Supreme--Does not need to work--
  90. Looking for (5) Stainless Lug Nut Caps
  91. exhaust manifolds
  92. 1966 442 front lower A arms
  93. Door & Sail Panels for 1972 SKYLARK convertible
  94. BBO Holley Street Dominator
  95. Need W/P pulley
  96. 70 radio
  97. 68Cutlass Dashpad
  98. Need alternator brackets 70 455
  99. Looking for set of working lighting rods
  100. 72 hurst dual gate shifter
  101. 1988 Custom Cruiser Drivers Seat Belt
  102. Steering gearbox, 1940s Model 76
  103. 1971 Cutlass Parts Needed
  104. 72 Cutlass Bolt on Center Cap
  105. Hood tooth for '70 442
  106. 67 Cutlass/442 convertible quarter glass needed
  107. Need 71 Delta Royale Rear Wheel Trim and Bench Seat Track Desperately
  108. 1972 Q-jet 7042251
  109. 77 Olds Cruis Control Modulator
  110. 73-76 455 stock intake
  111. 1972 olds 98 4door body parts needed
  112. 66 442 Tri-Carb Breathers (non CA emissions)
  113. 68/69 cutlass/442 manual antenna chrome bezel
  114. 70-72 Cutlass or 4-4-2 trunk lid (Convertible)
  115. 7040258 carburetor wanted
  116. Intake manifold
  117. Intermediate Steering Shaft 72 Cutlass
  118. 1964-65 Vista Cruiser Wagon parts needed!
  119. WTB 1932 Olds waterplate & head 6cyl
  120. 75 cutlass interior parts wanted
  121. Distributor p/n 1111979
  122. 1967 Cutlass Floor Shift Cable
  123. WTB: 1985 - 1990 307 valvetrain parts
  124. wtb 72 cutlass ram air hood
  125. 1968 98 skirts
  126. Battery cable tube
  127. Need a Heat/AC Control Panel '86 G body
  128. Door panel trim, dash restoration
  129. trim rings
  130. Wanted: fan shroud 1965 Cutlass/442
  131. Roto hydramatic slim jim parts needed
  132. Parts for 1962 Dynamic 88, Super 88, Starfire, Ninety Eight
  133. 1964 Cutlass Full Interior
  134. 1964 Cutlass Headliner Bows and Rear Window Trim
  135. Battery Cover 1940-1950
  136. 1969 Cutlass Cigarette lighter
  137. WTB:Starter wiring 67 Cutlass
  138. Looking for the tail panel???
  139. 1971 sienna interior
  140. Need a choke pull off bracket
  141. 1971 442 Grill
  142. Wanted Pass Chrome
  143. Need a Fan Clutch, 72-350 Cutlass
  144. 1970 Cutlass Eyebrow - Driver side
  145. Glass
  146. omega interior parts
  147. tailpipes needed
  148. 200-4R OR 6 speed Tremec Transmission Required
  149. omega
  150. $$HELP!!!!1970 to 72 rally pack tach $$
  151. In Search of 455 or 425 oldsmlbile motor
  152. W31 Pistons
  153. Wanted: 70 olds 442 W30 TH400 trans
  154. Headliner Clips - '68 442/Cutlass
  155. 72 Cutlass S Grilles
  156. 7042250 Carburetor
  157. 1970 Cutlass/442 dark green deluxe steering wheel,ashtray door
  158. need drip rail stainless
  159. 67 cutlass power steering pump pulley
  160. Wanted 1972 Engine Distributor Vacuum Control Switch
  161. 70-72 gauge pod
  162. Wheelhouse Patch Panels
  163. Qjet carb for 1970 olds 442 w-30 a/t
  164. long trunk lock pin for vacuum release
  165. Looking for Carb Dashpot
  166. 69 Cutlass/442 Deluxe steering wheel
  167. lower knee valance 71 Cutlass
  168. intake
  169. Fender - 68/9 Cutlass-442 GREAT CONDITION
  170. Olds small block intake, valve covers and skinny fron tires
  171. NEED: Dipstick and Tube for 66 425 Toronado
  172. Need wheels for 1966 Delta 88, 14x6, 5x5!
  173. NEED a 394 Block
  174. '65 2bbl carb
  175. Ignition Coil
  176. 1969 Cutlass Supreme 2 dr Post car
  177. 1968 442 4 speed shifter
  178. 1967 Oldsmobile Delmont 88 Parts needed
  179. diesel
  180. 455 engine parts wanted
  181. Horns for 72 Cutlass
  182. '70-'72 Vista Cruiser Fender Moldings
  183. I need Hurst/olds cone mirror's
  184. bumper jack for 1970 442
  185. 1962 Olds Dynamic Glove Box Strike
  186. SS I's
  187. looking for ssII 14x7 early 4 clip trim rings nice driver
  188. 1969 cutlass/442 headlight bezel
  189. Looking for 350 valve covers
  190. Wanna swap .040 455 pistons 4 stock 455 manifolds
  191. 67 442 Stuff
  192. 72 Cutlass cruise control part needed
  193. 381921 RH Exhaust manifold WTB
  194. Need working window motors and washer motor for '77 cutlass
  195. Black Door Panels
  196. Seat Belt Buckle for 1967 442
  197. Non Clutch Fan 1967 442
  198. 1967 442 Console Needed
  199. convertible rear panels
  200. 68 4 door/wagon frnt door panels
  201. '67 Delta, Need Courtesy Light Switch!
  202. 69 cutlass S/442 Hood
  203. Does anyone know where I can get a fuel pickup sock for my '73 Delta?
  204. Need 70 cutlass alternator brackets
  205. 1967 442 Red Steering Wheel
  206. Wanted, 1963 cutlass-rear qtr panels, (both).
  207. G Body sway bar
  208. 67 4-speed drive shaft
  209. 67 Vista Cruiser Tailgate Motor needed
  210. door stops WTB
  211. DESPERATELY NEEDED:A Body GM Front & REar Bench Seats
  212. 1957 98 trunk+hood emblem,radiator,hubcaps
  213. 1970 442 rt side marker lens
  214. R code 14x6 wheel
  215. Need More '67 Delta Parts!
  216. Looking to buy a good Fuel Sender Rheostat
  217. Wtd G-body headers/xst
  218. '67 big car vinyl roof mouldings
  219. I need a pair of 350 cyl heads
  220. 69 cutlass conv looking for a set of rear end gears
  221. 71 72 nos pwr door lock switch
  222. 1968 Cutlass interior bits & pieces
  223. Body side molding (all pcs) 71 Convertible
  224. 1949 Olds 98
  225. Sport Steering wheel horn
  226. 72 cutlass s / 442 project.
  227. 68-69 shift cable,cable mount, shift lever
  228. steering wheel for 67 442
  229. '67 Delta Washer Squirters!
  230. '67 Delta Power Antenna Assy!
  231. 61-63 Jetfire, Cutlass, f85 rear end needed
  232. wanted: big spring
  233. Need a small spring
  234. 67 tic toc tach
  235. Holley 080770
  236. 1966 oldsmobile jetstar 88
  237. 455 Toronado Intake
  238. '72 Door needed
  239. Anyone have a steering wheel for 1969/1970 Oldsmobile Ninety Eight?
  240. Am fm radio
  241. 1967 442 inner fender drivers side
  242. Need a 3 v crank pulley
  243. Dash A/C center duct needed
  244. 1966 Cutlass 2 door HT window felts
  245. Steel Rims from the mid 60's, wheel 14x6
  246. WTB 1964 Cutlass rocker panel trim and wheel well moulding
  247. sbo parts needed
  248. 72 Cutlass Supreme Molding
  249. Set of 4 hubcaps
  250. 68 cutlass project
