PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. original rubber trunk mat wanted 68-72 cutlass 442
  2. 72 supreme front fender trim
  3. 64 Dynamic 88 radiator
  4. Tall "Oldsmobile" Script aluminum valve covers
  5. 77-79 Omega Tail Light
  6. cutlass W31
  7. 1970 442 Factory Service Manual/Literature
  8. 303 or 324
  9. Looking for 394 left side exhaust manifold
  10. Buckets and Console Wanted for my 1972 Convertible
  11. 70 W30 Distributor Vacuum Advance - needed
  12. 67-68 Torsion bar adj nut and bolt
  13. wanted 1967 olds cutlass 442 hood dayton ohio
  14. 71' 442 passenger side grille
  15. Newby in need - 1950 Olds 98 Sedan
  16. Olds guy in Netherlands looking for 67 400
  17. need heads sadly
  18. Sail panel for 1970 442
  19. Coolant overflow tank
  20. Junk red inner fender needed, or part of one
  21. door strap
  22. WANTED WTB 70 -72 cutlass doors dayton ohio
  23. Cutlass S quarters
  24. 1991 Olds 98
  25. 1967 mirror
  26. apb on an sbo intake
  27. 350 stock cam wanted please
  28. 70 442 hood tongue
  29. '70 442 pace car flag brackets
  30. 67 center ac vent
  31. 1969 w scoops
  32. Looking for pair 350 heads #3 or #4
  33. 1970 442/cutlass package tray
  34. 1970 W-30 3.91 Iron Rear
  35. 71 NOS 442 and W-30 emblems
  36. 68-69 cutlass dash pad
  37. 66 Cutlass/442 Parking Lamp Lenses
  38. 71 Delta 88 Royale Visors
  39. 64 f85 hood latch
  40. 83 cutlass window switches
  41. 260 2 BBL intake manifold and pump to carb fuel line
  42. Trunk for '68 cutlass convertible or 4 door
  43. 1971 Cultass Grill Script needed . . . HELP
  44. 1971 Delta 88 royale seat belts
  45. 71 Cutlass drivers door and trunk.
  46. 1968 toronado passenger side exhaust manifold needed!!!
  47. Wanted 1966 toronado fenders and trunklid
  48. Pearl White Seat buttons
  49. taillight bezels or other
  50. Reproduction W27 12-Bolt Differential Cover
  51. 72 cs rear bumper
  52. 70 lower windshield mldg tabs
  53. 66 Olds 98 Trim
  54. Is anyone parting out a Oldsmobile cutlass supreme g-body
  55. Lft. Wind Window reg.
  56. WTB: 1952 98 Convertible parts needed
  57. hood lock rod
  58. WTB: 1952 hubcaps
  59. Thermal Fan Clutch : 1967 442 .
  60. 70 Cutlass Supreme trunk light assy
  61. 72 cutlass front bench seat.
  62. BBO blower manifold wanted
  63. WTB: 1966 toronado fenders/ quarters/ misc interior
  64. Need electric power trunk release (Flat type)
  65. NOS 84 H/O Header Emblem and tail lights
  66. WANTED: 1975 Delta 88 side marker bezel
  67. 70 - 71 power top harness
  68. Adjustable push rod 455 C Heads
  69. 66 t-handle and console light housings
  70. 65-66 Steering Wheel or Center Cap Wanted
  71. Lower Console Skirt
  72. front grill
  73. Accessory Brackets A/C, PS, Alternator
  74. WTB 4bbl carburetor
  75. WTB mint or NOS left 70 442 grill. or restored original
  76. WTB 71-71 442 OAI hood
  77. 70 cutlass
  78. Looking for a 72 Cutlass front bumper
  79. Quarter panels
  80. Torsion rods for trunk
  81. 1972 cutlass Supreme door panels
  82. 71 442
  83. Omega taillight bezels
  84. '69 Cutlass fender patches
  85. Fischer Seat Belts - Gold
  86. 1970 cutlass high note horn
  87. 70-72 442/Cutlass S B85 Exterior Belt molding needed
  88. nos oem Cutlass Grills wanted
  89. 68 Cutlass S A/C dash wanted
  90. 1966 Cutlas Convertible Chrome
  91. Thermador water cooler want to buy
  92. 77 Cutlass Dashboard
  93. '71 Trunk Hinge - Torsion Bar Clip
  94. 71 442 sport steering wheel hub
  95. '69 cutlass s parts wanted
  96. Harrison 4 core radiator
  97. 70 NOS, RH hockey stick 230920 +
  98. 66-72 hood latch handle nylon retainer ring
  99. 70 nos hood molding. 1 eyebrow 230930
  100. 1964/65 cutlass part needed
  101. Drivers side door handle 94 Cutlass Convertible
  102. 1966 400 E-Block - Want to Buy
  103. 67 442 gas gauge
  104. Trunk Area Needs Work!
  105. 1970 442 dash pad
  106. SS1 Set Needed
  107. For sale 47
  108. '75 Custom Cruiser Rear Taillight Frame
  109. '75 Custom Cruiser AC Accumulator/Dryer
  110. T-86 3speed std txmn or parts for 63 cutlass
  111. Plastic trim Headliner
  112. Wanted: One AC Delco RapidFire #7 Plug
  113. WTB: 15" Trim Rings
  114. Manuals, Parts lists, & information
  115. 1970 442 Alternator P/N 1100890 needed
  116. 1969 Cutlass 442 Drivers Side Fender NOS or rust free
  117. Sport Steering Wheel
  118. '66 442 Pulleys n Mounting Brackets
  119. 1966 Antenna Parts
  120. any 1970 w30
  121. 1965 wire wheel covers ..2 bar spinner..
  122. Power Steering Bracket 350
  123. "OLDSMOBILE" hood script 71-72 442
  124. # 673 Posi unit olds 12 bolt for 2.56 , 2.79
  125. 1971 442 cutlass need roof rack
  126. Antbody parting a 68-72 Vista cruiser
  127. Metal dash & upper cowl for 70-72
  128. Need a cheap cam & lifters (new or used)
  129. 67 vista cruiser roof window
  130. 67 toronado door panels
  131. Trans shift lever
  132. 65 442 rear panel
  133. NEED pulleys
  134. 69-72 442 air cleaner base
  135. 394 exhaust manifold
  136. 66 Cutlass Dash Insert
  137. Pulleys for a 66-67 330 engine, non air
  138. 1965 Starfire
  139. Intake
  140. 66 67 3 core radiator
  141. 71 Supreme Grills
  142. Need rear hood moldind for a 72 c/s
  143. Grilles for 72 c/s
  144. Stainless door & 1/4 belt moldings 72 Supreme
  145. Nice used 71-72 repop OAI HOOD
  146. Harmonic Balancer for 1960 394-Rocket
  147. In Search of: 1960 394-Rocket Heads
  148. 70 cutlass parts
  149. 1956 98 trim
  150. Pulley set for 67 442
  151. Wanted For: 1964 F-85 H/L Door and Trim
  152. 1972 CS Parts
  153. One Edelbrock Head
  154. 66 98 LH tail light
  155. Wanted: 1965 Olds Dynamic 88 Horn Relay/Junction Block
  156. 71 442 washer bottle, charcoal cannister bracket
  157. need a ring an pinion
  158. O.E. Pre '73 Gauge Temp Sending Unit & '72 Seat Belt Light Assy
  159. 67 Cutlass Brake Warning Light
  160. 73-79 350 block From a Hurst
  161. Float bowel
  162. Wanted: 2x exhaust manifold bolts
  163. 200r4 Speedometer gear housing
  164. 1973 Olds 98 dash lights/assemblies/lens and cruise toggle
  165. need cutlass wheels
  166. blower resistor connector for AC cutlass
  167. 1972 Carb
  168. 1971-72 Cutlass front bumper
  169. 66 442 Air Cleaner W/O Snorkel
  170. Parts needed for my project
  171. WTB Timing Cover
  172. Floor shift trans bracket
  173. '65 2 bar wire wheelcovers..
  174. 71 442 carb wanted - 7041253 ??
  175. Long oil fill tube wanted
  176. 67 water pump pulley
  177. 1967 Toronado Water Pump
  178. Omega SX Paint Masque
  179. 1967 4-4-2 (400 C.I.) Main Bearing Caps
  180. 64 jetstar
  181. 1970 W30 water pump
  182. Front Disc Backing Plates 77-90 Delta/98 etc
  183. 1970 hood tongue
  184. 1970 F heads (211 date)
  185. wanted 1970 OW 400 turbo transmission
  186. Cruise Control Servo for 72 Cutlass
  187. 72 442 RH grille
  188. Wanted: power steering pulley
  189. (70 Supreme Conv) Drivers side door and trunk lid
  190. '65 2 Bar Spinner Wire Wheelcovers..
  191. Radiator Shroud Clips
  192. 71 Cutlass console
  193. Hood hinges 71 442
  194. 66 power bucket
  195. '57 back-up light housing
  196. Jetfire Rocket Fluid tank
  197. 1954 olds rocket 88 headlight bezel
  198. '71-72 Power Brake pedal assembly
  199. WTB: Driver side window regulator
  200. Olds Omega Mini-Camper/Tent
  201. 49 Olds Piston
  202. WTB: Carb fuel line / dipstick tube with dipstick
  203. Horn pad
  204. 1961 dynamic 88 doors
  205. 350 engine wanted
  206. Plastic Fan Shroud '67-'68 Delta/Delmont
  207. olds 350 intake
  208. 14" Wire Covers..
  209. Wanted 3:90 gear for 69 o type
  210. I really need 1 one 425 piston !!!! Bad
  211. throttle rod, 67 442
  212. I may as well ask...
  213. 1955 Hood
  214. 1935 Olds Master Cylinder and Volt Reg
  215. WTB 307 Harmonic Balancer and Pulley Bolts
  216. 1967 442 Sport Coupe Parts Needed
  217. 71 Cutlass convertible door panel set.
  218. Quarter lights
  219. ignition rack and pinion gears
  220. Engine Harness - '71 442
  221. Steering Wheel HELP 66 Starfire
  222. 71 Supreme 4-Core Top Plate
  223. Hood hinge bolts
  224. Windlace needed
  225. 1965 Cutlass -- BIG PARTS NEEDED --
  226. 72 cutlass front brum hub
  227. 1968 SSII 14x6 Trim Rings -OEM
  228. AM/FM faceplate from 67 or similar
  229. 8 track face plate
  230. WTB: 1955 fender skirts
  231. Still Looking!
  232. WTB 68-72 A-body frame
  233. Looing for 70 442 OW transmission
  234. PS bracket
  235. 1970 442 post white vinyl interior pieces
  236. Heater Control Knobs / Fan Switch Knobs
  237. Pass Fender trim 67 Vista Cruiser
  238. Wanted-65 f-85 Plain Jane Base Horn Button
  239. Wanted: olds 350 rocket block
  240. single F head wanted
  241. 69 442 400 BB air filter housing
  242. 4bbl air filter housing to fit HEI
  243. 69 Cutlass/442 right quarter
  244. Dual gate
  245. Vent Window Parts Wanted
  246. Hockey sticks wanted
  247. 1961 super 88 "HOLIDAY EMBLEM"
  248. 1969 442 Sport Steering Wheel center cap
  249. 1989 Ninety Eight emblems
  250. 67 Toronado Parts Needed
