View Full Version : Parts Wanted
- 1940 olds seiers 60 conv
- 72 supreme- Portion of trunk weatherstrip channel from quarter cap to quarter cap.
- Diesel pickup motor mounts
- Wanted Blue Console for 72 Cutlass
- 1968 Delmont 88 outside trim
- 1969 cutlass fender needed - driver side
- 68 cutlass hood hinges needed
- Hood Parts Needed 1970 Cutlass 442
- "OLDSMOBILE" script
- Oldsmobile Numbers Swap Meet Guide book
- 61 Olds 88/98Radio delete plate
- 67 442 Rally Pack Gauge Lens
- looking for good used engine
- Need Help Finding Hood and Pass door for 71 cutlass s in PHOENIX
- need 71 mis parts
- 455 olds
- 1970 A-body front fender
- Need a clean 76 rear bumper
- 76-77 rear speaker harness
- '59 front seat
- 65 cutlass eye brows
- 1956 olds emergency brake light
- 1966 Cutlass lower steering column plastic piece
- 1970 Cutlass AC Distribution Duct
- 1970 Cutlass Lower Dash Knee Valance W/AC
- 1970 Cutlass Center AC Outlet Duct
- '70 442 Horn Mounting Bolt
- 1970 442 Tilt Steering Column (Floor Shift)
- Need 70 cutlass front end near MI
- Wtd: 69 A-body BB HEAT RISER TUBE
- '69-72 AC Kick Panel - Dark Blue '70 color
- NEED a 1968 Column shift tilt..
- 1969 Speedometer
- Junk BB Head
- Need an original-type non-OIA Air cleaner for my '69 Olds 442
- Dash plate..defroster option
- Trunk Decal for 74 Hurst/Olds
- dentless, rotless and warpless
- 82 cutlass supreme 4 door front & rear bumper fillers
- Anybody have an original-type non-OIA Air Cleaner for a '69 442 for sale?
- Carb and tranny
- 67 gold dash pad
- '64 Cutlass r/f front
- 72 vista seat wanted
- '72 a-body seatbelts-buckets
- needed 5,6,7or7a heads
- Looking For 1971-72 Hood and Pass Door in PHX
- Wtb-1969 nos/mint rr ashtrays 9847777
- Rocheter Quadrajet 1970
- 0.040 min bearings
- Radiator needed
- Oldsmobile Script
- 1967 88 chrome molding windshield
- 68 Cutlass reverse light
- SSI rims
- Looking for a SBO Victor intake....
- Olds diesel mounts for Chev/GMC truck
- looking for Parking brake wire for my 53 Olds 98
- 1971/72 grill 422
- 1966 Delta 88 driver's side front fender
- Vacuum Pipe To Spark Plug Cable Bracket
- 70 Rear defogger
- Left rear quarter panel, Chrome, And Bumper
- 69 Cutlass tail light wiring harness
- 1990 Custom Cruiser wheels and Center caps GM part 10137842
- Door panel rocket emblem
- 68 or 69 manual antena for cutlass or 442
- Need fan control switch
- Needing a 71 supreme trunk lid
- 66-67 Cutlass rear window chanel
- 1970 72 turbo 400 442 downshift switch bracket
- 1964 442 Air Cleaner
- Belt reveal molding, top of door 66 Cutlass
- looking for 71-72 headlight housings
- 1955-56 clutch pedal
- 1970 deville front top bow
- 7a heads for a 403
- Holley Street Dominator intake manifold 350 olds
- Still looking for a super nice pair of 72 supreme quarter cap eyebrow moldings
- Transmission Tunnel 69 442
- Lightning Rods
- 1969 Cutlass S Convertible fuel gauge, lower dash pnl
- Trade a red rubber starfire wheel for a black starfire or ralllye one?
- Type-O gears
- Looking for 70-72 4 Barrel Air Cleaner
- Looking for Ignition Switch for 1964 Olds Super 88
- 1970 cutlass bumper jack
- Flywheel, pedals, pilot bearing, 31 spline slip yoke
- Opera lights
- evaporator housing
- Trade a nice pair of 72 cutlass "s" quarter cap trims for nice pair of 72 supreme?
- 61 88 dash pad
- 71-72 Cutlass gas gauge needed!
- 1970 442 Parts needed
- PARTS HELP NEEDED! Hood release cable
- Quadrajet 7040251 or 7040257
- 1956 olds back up chrome ring light
- 1972 turbo 400 good core
- 69 Cutlass deluxe steering wheel
- 1962 cutlass parts needed
- 54 Olds Stainless Rocker Panel Covers
- Steering column lockout backdrive assembly
- Door Panel Parts 71 442
- Hub, horn contact, and center cap for rubber starfire wheel
- 1966-68 cutlass-442 starter jumper
- 70 cutlass radiator support or center
- trim clips
- 1970 cutlass parts
- 57 Olds part wanted
- 1983 olds 98 regenecy brougham WTB interior
- 1970 Parts needed
- Sport steering wheel, complete
- 307 A-4 intake
- 68 Delmont glass
- 1968 Blower motor relay wiring harness
- Kph speedo cutlass -71
- Looking for a Power Window Setup for 72 Cutlass S
- flywheel cover 41 Olds
- WTB hood hinges and complete latch mechanism for 71 Cutlass
- retractable seatbelts
- Valves and non stock springs needed
- 71 or 72 cutlass interior parts
- 70 Cutlass Supreme Headlight housings (plastic)
- 1955 parts wanted
- 67 throttle linkage
- 72 supreme roofrail metro brand weatherstrip wanted
- 1971 Cutlass Supreme Parts NEEDED!
- Wanted, 49-50 Olds 88 grille extension
- 1970 442 hood tongue/tooth
- 1967 Cutlass supreme interior door panels
- 71-72 cutlass hood
- WANTED - 1971-72 Original Ram Air Hood
- front seatbelts 73-77
- +++Deluxe Steering Wheel 1970 Toro+++
- New U shaped molding for 1972 cutlass supreme driver's side grille or nice used pair
- Torsion parts needed
- Interior A/C box plastic for 1957 Olds
- 1970 Cutlass Console Compartment Light Switch
- turn signal lens
- Small parts -Big Car 65 98
- light assembly for clock 72 cutlass
- 1982 Olds 98
- 72 Bendix Prop/combo valve
- Edelbrock intake part#2151
- Standard bore high compression 455 pistons
- Posting pics
- 1970-1972 Cutlass Center console
- Inner fender well hold down plate
- 4 Spoke steering wheel Saddle
- 67 Cutlass Fuse Block wanted
- 72 supreme deck filler panel and complete dark green headliner wanted
- 64 starfire exhaust manifold
- 1954 olds 98 starfire convertible parts wanted
- 1970 bucket seats
- Need a few mis parts for my 68 442 project
- 68 Vert power ant. bracket needed
- Need 68 fenders, specifically drivers side
- Glass, Quarter Window CONVERTIBLE clear
- 14x7 SS1
- 63 olds parts wanted
- 67-69 console top shifter cover
- 62 super 88
- Wanted 71 Delta 88 convertible top switch and bench seat track
- wanted. 1969 intake vacuum tree
- wanted: 400 / 455 intake manifold oil baffle
- 67 Olds convertible the rear left window pane.
- Red Starfire steering wheel
- 68 Cutlass Supreme interior - black
- 65 cutlass quarter
- 70-2 floor shift set-up
- 67 rallye pac
- Powermaster 9510 Starter
- 70 Cutlass DS door mirror
- 71 442 a/c compressor needed.
- 65 Starfire trim
- Wanted! 1962 Olds Spinner Wheel Cover
- 200r4 trans
- 70 Cutlass B85 Moldings
- WTB 67 Cutlass front license plate holder
- Small Part Wanted: Bolt stud to connect TH350/400 shifter cable to lever arm
- positive battery cable wanted
- 71-71 front signal light housings
- 1964 F-85 2-door Coupe
- 1967 Delta 88 Dash Pad
- 1997 Aurora A/C Compressor
- 1969 Rally pac gage and Tach
- Anybody seen or have these?
- Wanted>68-72 a body black a/c kickpanels
- Parts for resto
- WTB Olds 15 x 7 super stock rally wheels
- 1962 Starfire Bucket Seat Track
- tires wanted
- 69 carb - 7029253 wanted
- 1972 cutlass supreme quarter panel extensions
- Need: 75-76 ninety eight rear bumper
- 1972 CS Head (North Carolina)
- 1979 98 Regency wiper switch
- cutlass trim
- 1966 olds 98 feder skirts
- Need Rear Seat Belts for my 1968 Cutlass
- Wisconsin CO'ers- Looking For A Dealer Emblem
- Wanted (1) 15x7 SSII Bolt On Cap
- clock or tic-tok-tach
- window stops 70 442
- 330 motor
- 15x10 steel rims
- Looking for some '72 CS parts or any compatible
- 59 olds parts wanted
- 5.7L diesel pistons WTB 40 over preferred
- 82 Olds 98
- rally wheels or crager SS
- 1970 F-85 steering wheel and door panels
- 76-77 Rear bumper
- 1974 Olds Cutlass Front License Plate/bracket
- 1971 Cutlass S F/S
- Hurst Digital Tach
- Non OAI standard 71 442 hood wanted
- 1967 Cutlass Supreme front clip needed
- 1974 Delta 88 tail lights
- '88 Toronado Trofeo trim
- Looking for 67 Cutlass Supreme dashboard panel
- 1973 rally gauge
- 1965 f-85 -cut- 442
- 69-72 Cutlass Supreme bench seat ASAP
- looking for a 7305 shifter handle
- 1969 Olds Cutlass Convertible Top Lift Cylinder
- 72 cutlass Hood Latch Support Center Mount
- 54 rear speaker grille wanted
- Need Alternator Brackets (394)
- Looking for Power Window Regulators for '75 Cutlass
- #2 & #4 exhaust manifolds
- Need 70' Cutlass/442 front end (near MI)
- Parts wanted
- 1977-1979 Olds Delta 88 Wood Grain Dash & Clock
- mirror
- 70-72 Cutlass/442 holiday coupe qtrs
- Radiator Shroud Clips
- Need a few parts for 72 Cutty
- 70 right rear wheel well trim
- '74 Omega hatchback parts
- 70 Cutlass/442 Parts.
- 72 supreme parts wanted in very nice condition
- wtb: 71-72 cutlass rearend
- Wanted: Berejik Olds trunk emblem
- parts list needs for an sbo
- 74 Front License Plate Bracket/Frame
