- WTB.."64 2 bar spinners..
- Sport mirror control knob clip
- 1953 Olds 88 Hydramatic
- 70 Seat Belts
- 71/72 Lower Air Deflector
- 7040252 wanted: '70 Toro
- Omega Fender Script and Rear Wheel Opening Mldgs
- 1961 88 front bumper
- 1964 F-85 Hood & Fender trim wanted
- Looking for one 1954 olds 88 2 door headlight bezel
- 64 Door Glass
- 1974 Cutlass Salon
- 72 door alignment stricker
- M/T valve cover
- Need 66 Hurst 442 4-speed shifter
- shift kit for 77 th350
- parts needed
- 72 Windshield Trim Drivers Side
- Wanted 72 Speedometer
- wanted:olds rear end
- Need a TCS Solenoid, 1972 350
- 1973 Olds
- posi rear
- 68 cutlass door panels
- '67 Split Bench Seat Parts Wanted
- WTB: 70s-80s spoked steering wheel
- Vista cruiser seat belts
- Iso of 1968-1969 cutlass wheel housing trim
- Need 68-69 Cutlass front fenders
- 66 starfire wiper switch
- 1964 F85/Cutlass wheel opening moldings
- 1954-1955 Oldsmobile 88 Hubcap
- '88 Cutlass Supreme Euro Front Bumper Cover
- 69-70 clutch switch needed
- 1967 442 AC brackets
- 1965 Cutlass Bumpers
- Wanted... Olds 425 Pistons
- 1966 wheels wanted
- 69 cutlass gas gauge
- 1965 vista cruiser rear coil spring help request
- 68 Cutlass transmission tunnel
- Tail light bezels (lower)
- 1971 w30 Viking blue
- Air Pump for 307 VIN Y w/ AC
- Pass side 1970 Sport Mirror Pedestal wanted
- 1957 parts wanted
- Wanted 70-72 bottom ac vents
- 1963 olds 98 ignition switch retaining nut
- 65 vista cruiser part search
- Seeking Cigarette Lighter for 1968 4 4 2
- 330/425 flexplate/flywheel
- Cruise control
- '66 - '67 442 Auto " chrome" snorkel air cleaner
- 257 Straight 8 pistons needed
- Tilt wheel steering column
- 1947 olds model68 straight eight engine standard bellhouse
- 70-72 Rally Gauges
- Wanted: 1970-1972 442 Convertible Trunk Lid
- 64-67 330 fremont valve cover breather
- 70-72 tilt column part
- factory 350 68/70 B body only
- 67 442 Radio Faceplate / Bezel
- 72 cutlass supreme rocker panel moldings
- 12 Bolt Posi Carrier with Gears
- 64 88 Radiator rubber seats
- Wanted>64 98 fuel tank
- 76-77 cutlass reverse lights
- 67 olds 98 speedo cable (hub type)
- 'E' Heads w/ Large Valves
- Any Lansing MI. area dealership plate frames?
- 68/69 a body antenna part
- My 39k mile 87 Olds was rearended need parts
- 1962 super 88 rear bumper
- Edelbrock Rocker Stud
- WANTED - Convertible seat back frame for 72 Delta 88
- Looking for 1970 to 1972 black dashboard
- TH400 Kickdown switch plug needed
- 1973 delta88 drivers side door glass
- 1983 Oldsmobile 98 2 Door grill
- 1955 rochester 4gc autochoke parts wanted
- Wanted>8.2 posi unit
- 69 cutlass radio face plate
- Power steering bracket
- 1973 omega rear bumper
- WTB NOS brake pedal pad for automatic
- 1949-1950 Olds
- Looking for 61/64 394 Stick Flywheel
- 1970 Olds delta 88 rear bumper
- Water Pump Pulley (1953 88)
- Edelbrock Aluminum valve covers
- 1970 manual steering
- 1969 Hurst Olds 15 inch wheel
- wanted 1970 OW 400 turbo transmission
- 1964 Cutlass Bumpers needed
- a few parts needed
- need 65 front bumper for f 85
- Need both outside mirrors 1969 442
- Top radiator plate
- 1966 Cutlass Window sill trim needed!
- kick panel
- steering wheel for olds 98 1969 or close to
- Looking to borrow or rent Rotisserie for '72 Cutlass Hierloom Olds Project
- Upper Windshield Stainless 72 Convert
- Wanted: HOOD for 1966 Cutlass/442
- 70-72 dashpad
- 73 88 350 rocket
- Need a '59 or '60 Olds Steering Wheel
- 66-67 Cutlass front window channel
- Need 59+64 parts.
- 66400
- WANTED: 68 Cutlass power steering gear box bolts
- WTB: Drivers side upper seat cushion from a 67-69 Armrest Benchseat
- sport mirrors for 72
- 86-88 cutlas supreme euro header panel
- need passenger fender for 1984 delta 88
- Anybody have a snap on center cap for rallye wheels they dont want?
- !969 Cutlass Convert
- parts needed for my 69 cutlass
- Snap on center caps, trim rings and bezels
- Looking for misc. 1959 Super 88 trim
- 69 cutlass speedometer and fuel gauge needed asap
- backup light housing 71 cutlass
- Manual trans. parts needed
- 1967 back seat cutlass supreme
- NOS or perfect RH 71-72 Cutlass/442 fender
- 55 headliner bows
- need drivers door panel 69 442 post coupe
- Need some 64 Cutlass rear quater panels
- Rear bumper, script and trunk lid needed for a 66 dynamic 88
- 73 Cutlass Part Wanted
- passenger 70-72 S/442 qtr panel
- notched valve cover
- 70 Delta 88 Front Windshield Molding
- Resbond or Zinc Alloy
- Looking for R/H and L/H ac duct for 69 442
- 1966 Cutlass NEED stainless roof channel
- 70 Cutlass headlight housings
- Wanted: Complete, running, 350 OLDS Goodwrench DX Diesel
- WTB-'67 Delta/Delmont L/Rear Qtr Extension
- 1966/67 Bench Seat Headrests
- Edelbrock Performer Intake Manifold - OLDS 400 - 425 - 455 / USED
- W 35 spoiler needed repro or orig
- WTB: 4 or 5, 15" wheels for '55 Super 88
- 1970 cutlass supreme
- Convertible Chassis Frame 68-72
- lookimg for headers
- 70 Blue headrests wanted
- TH400 Connector For a 70 442 And Plastic Ring Gear Cover
- Wanted - good Rochester 4MV carb body
- 69 wiper motor arm
- WTB-1973 Delta 88 Royale convertableinterior-red
- W & Z manifolds
- 70-72 Cutlass/442 RR wheel well molding
- 70 olds parts wanted
- WTB: Grant GT or similar steering wheel for 73 Omega
- 66 F-85 L/S 1/4 Panel Trim
- 68 442 convertable window up stop bracket
- Wanted: 1972 Cutlass Stone shield Emblem
- Wanted>68 cutlass 350 hot air pipe
- NOS GM V-Belts Wanted
- WTB P/W regs
- OAI hood pin wanted
- 1970-71 cutlass supreme body side molding
- need a mexhanics lein
- NEED plastic chrome A/C vent balls for dash board
- 64 F-85 post car-window parts needed
- 69 H/O mirror
- 70 Original Ram Air Hood
- 70 Olds intermediaate harness and tail panel
- 64 Cutlass parts
- 1972 Supreme trim
- Looking for 1970 442 Low Note Horn
- Looking for Front Bumper 69 Cutlass/442
- Looking for Radiator Core Support 69 Cutlass/442
- Looking for Driver Fender 69 Cutlass/442
- Looking for a Carb
- 75 Cutlass salon parts needed
- Wanted: 1959 Olds Brake Booster
- Black front seat belts for '70 split bench
- Moulding 79 cutlass 2 dr
- Tilt Column
- 455 olds steel crankshaft
- 65 Olds 98 rear bumper
- Need headers for a 455
- wanted: 1964 Dyanamic 88 Convertible Passenger Window
- WTB 70-77 4 spoke steering wheel hardware
- 69-70 88 98 two door ht or convertible
- 1967 bucket seat metal back
- '73 Olds S/442 Parts Needed
- 1950 differential center section
- WANTED: 1970 w30 motor
- 95 Cutlass convertible boot
- want to buy some books
- Cutlass 1966 2dr HT Bumpers
- wTb : 87 cutlass dash pad
- 69 cutlass chrome hood hinges
- WTB: Convertible motor for my '71 Delta 88
- Need double pulley for 70-442
- Radiator
- Edelbrock Valve Covers
- Looking for chrome trim (exterior) for 69 delta 88 2 door
- 66 442 hard top rt rear quarter window
- Nice 71-72 cutlass back seat
- hood latch support panel
- accel multi port fuel injection system
- 72 Cutlass Coolant Overflow Tank
- 66 Cutlass/4452 Glove Box Light Lens
- 1972 split bench stuff
- WANTED...68-69 cutlass stick shift floor hump
- Door jamb vents
- '66 442 A/C Control Unit
- Another MIA part..pic
- wanted:70 alternator brackets for A/C car
- 1970 cutlass distributors cores needed 2
- '67 Delta/Delmont Rear Bumper Rubber
- CHEAP edelbrock 1406 needed for parts
- Power steering brackets
- Automatic floor shifter for 64/65
- Wanted ---69 70 71 72 Column shift TILT Steering Column
- 1937 Grill
- Need Grill
- 1975 Hurst Olds W-30**NEED T-Top Weather Stripping
- Exhaust manifold
- 455 Headers
- 71 Cutlass radio knob
- 1971 gutlass
- chrome molding 87 cutlass
- Factory 70-72 Cutlass AM Radio
- intake manifold
- 1966-67 442 parts
- HELP**73-77**Cutlass floor shifter console & 75 lower door panels NEEDED
- need grill and hood for 64 Dynamic 88
- trying again looking for an hei dizzy for cheap
- 1961 Olds 88 upper balljoints K5050 GM 380295
- Need parts for 70 442 w30 convert
- hood hose hold down
- 70 442 W 30 Convert parts needed
- Wanted: 70 Cutlass convertible rear seat upper and lower
- 64/98 wheelwell skirt trim
- passenger bullet mirror base.. or whole
- power steering pump pulley
- Dual Gate Shifter
- 1971 442/Cutlass horn relay OEM
- Wanted: 69 alternator brkts for AC car
- 77 regency 98 2 door coupe soft top trim
- 69 F85 nos Trunk emblem
- ball joint boot
- 70 harnesses wanted
- 67 cutlass throttle linkage
- frame for my 72 cutlass
