PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 1984 oldsmobile delta 88
  2. W27 Rear Axle Wanted - SV or SX Code for 1970 442 W30
  3. 1969 Toronado dust sheild
  4. Looking 68-72 a/c parts around the DFW Texas
  5. passenger sun visor mirror - 71 CS convertible
  6. 68 Cutlass headlamp surrounds
  7. Window crank Handle
  8. 1958 brake drums
  9. 69 Cutlass rear bumper
  10. 1975 cutlass radio dash plastic already cut
  11. Looking for Tilt Steering Column for 70 Cutlass
  12. Wanted 1970 Alternator 1100879
  13. Seat belts black
  14. Part needed trunk S emblem for 1968 Cutlass part number 7752547.
  15. 73 Delta 88 gas tank
  16. Need Seats For A '49 Convertible
  17. 1968 442 wheel coverings needed
  18. Wanted drivers side OEM full quarter panel 70 - 72
  19. 64 cutlass radiator support
  20. looking for 1973 delta 88 royale conv parts
  21. seat belt, 1970 Cutlass
  22. Complete 455
  23. 1968 Cutlass
  24. Looking for 1970 Oldsmobile 350 Engine
  25. 1968 442 31 spline axle needed
  26. 1970 '98 Parts
  27. 72 cutlass distributor in good shape
  28. 67 Manual throttle linkage
  29. working 64 98 clock
  30. 1971 W-30 distributor 1112034
  31. '70 - '72 Cutlass Black Plastic Kick Panel
  32. 1967 alternator bracket W/AC
  33. 1976 Cutlass A/C, Radio Bezel
  34. Water pump pulley
  35. 1970 4 speed reverse lockout
  36. 1977 2 dr delta 88 exterior trim
  37. 3.63 ring & pinion for a 48~mid 50s
  38. 62 Starfire mats
  39. 1/2" head bolts
  40. 1965 vista cruiser rear bumper fillers
  41. 1968 442 doors needed
  42. Doors wanted!!!
  43. 1970 nos 8 track face plate
  44. 3 series carrier
  45. 1974 Oldsmobile Salon-Style Bucket Seats
  46. Wtb 350 olds aluminum intake
  47. 1964-65 C Pillar trim
  48. Wanted: Lower Alt bracket 70 442 with ac
  49. 455 headers need for 72 drop top cutlass
  50. Wanted: 68 vent pull cable
  51. 70-72 right side "Z" exhaust manifold ,455 notched valve covers
  52. 72 supreme wheel moulding passenger rear
  53. 1963 F85 Clutch
  54. Wanted 68 gold horn cap center
  55. 64 Cutlass dash vent
  56. A/C Ambient Switch for 1972
  57. Blue 4 spoke steering wheel
  58. Rear License Plate lamp
  59. Gas tank
  60. Wanted: 70 442 four speed shifter in good condition to fit console car.
  61. Wanted: Olds Bell Housing 4 speed
  62. 66 cutlass convertible steering column
  63. need back drive linkage '71 Cutlass console shift
  64. Trim piece for '97 Oldsmobile 88
  65. Park brake cable frame J hook
  66. manual trans brake pedal 69 cutlass
  67. 1964 f-85 bottom trim
  68. Parts wanted 63 cutlass/jerfire coupe
  69. 1958 Super 88 2dr ht fuel tank
  70. Need "FE" radiator for 70 survivor
  71. 1974/75 Cutlass Front Bumper
  72. 1965 Starfire convertible project
  73. WTB: 1970 front bumper support bars + centers
  74. 1970 OAI Hood Ram Air
  75. Need a 63 Super 88 lower control arm bushing retainer bolt
  76. 1970-1972 Cruise control Switch
  77. 1967 442 air cleaner
  78. 1964 cutlass hood letters
  79. NASCAR block
  80. Wanted '70 Cutlass lower dash vents
  81. 1974 Cutlass parts (Tail Lights, Header Panel, etc)
  82. Wanted 67 Cutlass Front License Plate Bracket Needed
  83. 64-69 4 Speed console parts wanted
  84. 1959 Olds 371
  85. Hurst shifter handle
  86. 1972 Cutlass 350 Battery Tray and Hardware
  87. 1972 Cutlass Supreme Core Support
  88. 350 block/ heads needed
  89. 68-71 TH400 OG Transmission Core
  90. 65 Vista Cruiser parts
  91. Wanted Steering wheel/horn pad '79 H/O
  92. 70 olds cutlass 442 or cutlass
  93. Wanted 70 Fan shroud
  94. Looking for 64 jetstar 88 steering wheel
  95. Looking for 66 442 Stick Drive Shaft
  96. Rochester Q-Jet #7040255 49
  97. Auto trans dust/inspection cover
  98. Posi rear ended for 66 442 3:42-3:55
  99. Hood for 66 cutlass/442
  100. Wanted 68/69 AM/FM radio
  101. 68-72 Interior Lower Air Deflector Duct
  102. Factory Seat Covers - 63 Super 88
  103. 330 piston
  104. WTB - '68 Cutlass Hood Hinge
  105. after 63 fulsize parts
  106. 67 Cutlass Conv. Rear View Mirror Mount
  107. wanted parts for 1966 w30 resto
  108. 71-72 A body,front license plate bracket 1 to 4pcs
  109. 1970 -77 442 sport steering wheel horn cap center
  110. 69 442 rear side marker lens
  111. 5941665 back up lenses
  112. 1964 F-85/Cutlass top radiator plate and radiator
  113. 1972 Cutlass Supreme Shoulder belt holder
  114. ISO 1 bucket seat base
  115. 64-69 4speed console and/or parts
  116. cross member
  117. Auto shift lever knob
  118. Wanted..1 15 inch wire cap ..see pic
  119. 65 vista cruiser tail gate lettering
  120. 1965 cutlass 442 convertible
  121. pearl white bucket seat adjustment knob 1970 442
  122. 1970 442 Rear Drums-Bell Style Needed
  123. WTB: 1970 bare 455 block
  124. WTB: 1970 black dashboard
  125. 7040255 W Carb
  126. Kickdown Cable
  127. Replacement mercury tilt switch 64 Starfire
  128. Wanted, 69 98 convertible/coupe passenger side rear quarter panel
  129. ' 61 Cutlass F85 front & rear windshield garnish
  130. 1961 f85 gas tank
  131. WTB Wiper Motor Crank Arm for 1966
  132. 1967 cutlass post
  133. WTB 72 Cutlass S driver side grille
  134. WTB 1971 Cutlass "S" Grilles
  135. 1965 Cutlass/442 3 groove pulley & A/C Bracket
  136. toronado/GMC motorhome 455 intake manifold
  137. toronado/GMC motorhome oil pan
  138. Polished/finned valve covers
  139. 1957 2 drhdtp passenger door glass needed
  140. 1970 442 Rear Axle (W30 - Air/Auto - SF/ SV) Wanted
  141. WTB 72 tail light assembly( part with sockets and wiring)
  142. WTB 1968-69 Auto console in nice shape
  143. Need 1967-70 full size rear brake parts
  144. Radio power and speaker male wiring connector
  145. 1964 jack base wanted
  146. 66-67 Toro Heater Control Cable
  147. 67 442 Turn Signal Cancel Cam
  148. 71-72 Ram Air Hood
  149. Looking for 66 442 Remote Outside Mirror
  150. Need Parts for a 1942 Oldsmobile Convertible
  151. PS Fender 72 Cutlass
  152. NOS 81-88 Cutlass Hood Pad
  153. 1970 Cutlass Deck/Trunk lid wanted
  154. 1970 supreme wheel well trim
  155. 1970 442 rear bumper core
  156. 70 442 parts
  157. power steering
  158. cheap wheel for spare tire (71 CS)
  159. Bench seat 60-40
  160. B pillar chrome piece for '70 Cutlass S
  161. WTB 9729024 RH Reclining Bucket Seat Hinge Cover '76 Cutlass
  162. 70-72 Vista Cruiser tailgate
  163. 12502739 left front door trim deluxe
  164. Nos 455 water pump casting 404584
  165. 71-72 Ram Air Hood, Convertible Back Seats, Reasonable Price
  166. SSI Type 1 (14 x 7) wheel w/trim ring
  167. 1973 Delta88 Tail Lights
  168. SS1 All Chrome Wheels 810
  169. 62 F85 Standard Rear Brake Drum
  170. 73-77 Rallye Gauge
  171. 66' F85 Dlx Rocker Chrome molding?
  172. Window Frame Molding - 1970 Rallye 350 (F-85 Sport Coupe)
  173. 69 HO mirrows,air cleaner,70 mirrors and shifter
  174. opera lamp covers
  175. Disc brakes conversion kit
  176. Nice 8 track player housing
  177. 1968 cutlass Auto Console Black, very nice and complete
  178. Trunk rubber grommet (4)
  179. 1964 cutlass convertible
  180. Assembly /Repair Manual 71 Cutlass
  181. WTB: LATE 70s 15" X 6" STOCK STEEL WHEELS
  182. 73-77 Cutlass steering wheel
  183. 1965 Cutlass F-85 frame
  184. 1979 442 Grill
  185. Search power steering pump Olds 88 1955
  186. 70-72 Console or Console Parts
  187. Looking for Toronado Voice Alert Module GM Part #22520749
  188. Looking for good running SBO
  189. looking for tach for 1971 cutlass supreme
  190. 1968-72 Vista/Wagon plastics
  191. 1971 bumper guards
  192. OEM 1/2" head bolts
  193. Auto transmission for '75 Cutlass 350 cu in V8?
  194. R Code Wheel
  195. WTB 1966 olds 98 steering wheel emblem
  196. Need a 4 speed hump section
  197. Need starter for 52 98
  198. W30 exhaust manifolds W and Z
  199. Aftermarket W-30 Aluminum intake manifold
  200. 1957 2 drhdtp RH vent window frame
  201. 1972 Factory Cutlass, Vista Cruiser, 442 Air Cleaner Housing
  202. WTB, ISO,Looking for SS-IV wheels
  203. Need a under dash Valance for 70-72 cutlass
  204. Wtb 1941 Olds 98 fender skirt trim
  205. '72 Core Support Needed!
  206. '72 core support needed!
  207. 1964 cutlass side trim
  208. 1966 Seat Belt
  209. 70-72 OAI Topper
  210. 61 Parts needed
  211. 67 cutlass rear bumper needed
  212. 70-72 Supreme Passenger Door
  213. looking for a rochester quadrajet out of a 455 V8
  214. WTB rockshield "S" emblem 1971 Cutlass S
  215. WTB M/T Valve covers
  216. WTB: remote mirror for 69 Delta 88 2DR
  217. WTB a 1970 442 fuel pump. NOS or rebuilt
  218. Need 1966 Cutlass rear bumper brackets and lower radiator support.
  219. 1963 Oldsmobile F-85 parts needed for project
  220. 1969 alternator
  221. More parts needed for my Rallye 350
  222. 71 - 442 Carburetor
  223. 1996 cutlass coupe sl
  224. 64 cutlass door panel
  225. 407567 455 Intake
  226. 69-72 Floor Shift Steering Column Collar
  227. '71 "ZK" Radiator tag
  228. '71 Vista Cruiser Front & Rear coil springs
  229. 404521 “L” iron 455 intake
  230. 1108387 starter
  231. 403 forged pistons
  232. 1968 Cutlass/442 A/C blower resistor.
  233. ISO 71-72 console parts
  234. '71 cutlass supreme convertible
  235. Wanted: 1963 Cutlass rear bumper only need a NOS or mint bumper
  236. need exhaust manifolds for 72 350
  237. Air Deflector 68-72 Olds Vista Cruiser
  238. 1957 Olds Ignition Switch Bezel
  239. Looking for original rear outer felts/fuzzies in very good condition
  240. Parts wanted for 70 Rallye 350
  241. 70 convertible parts needed
  242. Floor Mats
  243. 66 cutlass ignition lock cylinder
  244. Need Quadrajet Throttle Plate / Base / Throttle Shaft
  245. Looking for 455
  246. Back up lenses
  247. AM/FM radio
  248. 63 f85 parts I need
  249. 1967 Red Seat Belts
  250. 55 Olds power seat part
