PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Looking To Buy Aan Edelbrock #2711
  2. 1969 olds 88 conv,coupe drivers side trim
  3. 1967 cutlass suprem front fender molding
  4. 1985 delta 88 Royale brougham LS chrome rocker panel PIC INCLUDED
  5. 1968 442 auto shifter
  6. 1967 442 exterior molding clips
  7. stamped valve covers
  8. trans inspection cover
  9. pulley, valve cover bolts
  10. Need a pair of 72 Cutlass door pulls
  11. Need a Front Bumper - 72 Cutlass
  12. olds sport steering wheel 69-72?
  13. dual gate shifter
  14. need driver side qtr 71 Cutlass
  15. 69 Cutlass heater knob
  16. I am looking for any photos of a 1962 or 1963 Olds Jetfire racing at any drag strip
  17. 68 or 69 Hurst Dual Gate bracket?
  18. WTB Shift Cable
  19. Valve covers
  20. 455 Exhaust Manifolds wanted
  21. WTB convertible top boot for 70 Cutlass
  22. fan shroud 72 cutlass
  23. console autoshifter 68-69 cutlass
  24. 1967 w30 air ceaner
  25. 70-72 NOS door skin
  26. 1970 Cutlass Taillight lens
  27. Torque converter..
  28. 70 cutlass convertible
  29. horn buttons
  30. 1962 oldsmobile Starfire
  31. WTB - 70 Starter - part No. 1108389
  32. 1965 olds 98 fender skirts and plastic window washer bottle
  33. WTB: Factory Dash Speaker for 72 Cutlass
  34. bumpers
  35. Fabricated Aluminum Valve Covers
  36. looking for bench seat
  37. looking for ss1 rims
  38. 1970 radiator
  39. looking for bumpers 72 Cutlass
  40. Dual Gate Shifter Mounting Brackets
  41. Wtb kick panels
  42. 350 sbo piston
  43. 85 Toronado Glove Box Door
  44. Front license plate for 83 Hurst Olds
  45. need a 1970 black dash
  46. Th350 or TH400
  47. WTB: Running board brackets..1939 or '40 ser. 60 or 70
  48. WTB Enclosed Trailer
  49. Teepo needs a part
  50. alternator bracket no A/C 455
  51. Convertible top switch for 72 supreme
  52. headers for a 455 68 cutlass
  53. 68 cutlass parts
  54. Big Block intake manifold
  55. Rubber caskets underneath roof rail strips
  56. 70-72 Cutlass/442 Driver's Side Fender Lower Brace
  57. Need blower switch asap for 1971 98
  58. 1967 442 Wiring Harness
  59. Lots of parts needed
  60. Instrument cluster for 1968 Ninety Eight
  61. Probe pistons
  62. 1970 Cutlass 455 manifolds
  63. Center console
  64. 72 delta 88 4 door
  65. 442 Grills
  66. Running 350 olds
  67. 72 Firewall & Gas Tank Stamping Applicators?
  68. 66/67 cutlass a/c firewall
  69. Wanted: 59 floormats
  70. Original Style Alternator 71 350
  71. speedometer column shift 1970-72 near Chicago
  72. Looking for 1966 442 radiator
  73. 307 Manifold Parts- choke tube, vacuum port
  74. Wanted:1965 Ninety-Eight Bumper
  75. 80 cutlass 307 mounts
  76. Wanted: 70 71 72 Cutlass 442 Power Door Lock Harness- Complete
  77. Wanted: Pair of LH Bucket Seat Tracks 69 70 71 72
  78. Wanted: One 14 x 7 SS-1 Chrome Rally Wheel
  79. Need LH Front And Rear Wheel Well Moldings
  80. 69 Olds Window Regulator
  81. WTB: 394 Finned aluminum vave covers
  82. 1950 Oldsmobile
  83. 69 442 pulleys
  84. 69 442 Conv rear quarter windows
  85. 1962 power steering pump
  86. Center console
  87. Need 70 442 starter 1108389
  88. 70 vista
  89. need L and R 71-2 fenders
  90. 72 cutlass supreme
  91. 68 convert map light
  92. 1969 442 kick panels
  93. Here's A Strange One
  94. 70 Cutlass S parts
  95. 68-69 Cutlass Red Inner fenders
  96. Drivers side amber side marker lense
  97. I need Couple little parts for my 1968 Cutlass
  98. 1970 442 Black Seatbelt set / horn cap / gauges
  99. door hinge
  100. Notched Valve Covers
  101. 69 Cutlass Hurst shift stick
  102. 1969 cutlass parts needed
  103. need f heads, mine were stolen
  104. 65 442 moulding wanted
  105. Cadet Sun Visor Parts
  106. 69 Cutlass/442 Hurst shift stick
  107. 71-72 Cutlass S emblems
  108. WTB..Kickdown cable.
  109. 1941 Oldsmobile parts
  110. 455 Crank & Rods Wanted - Detroit Area
  111. 71 Cutlass S parts wanted..
  112. WTB- 215 4-speed Bellhousing, flywheel and clutch parts, Minnesota
  113. Wanted: '77 Inspector's Guide
  114. WTB 1966 Solid 4 speed driveshaft
  115. 1958 wheels
  116. 1967 Cutlass/442 bumper brackets
  117. 1967 hood
  118. need 69 cutlass parts
  119. 1956 98 interior trim wanted
  120. 69 Cutlass backdrive part
  121. 307 carb to fuel pump line
  122. 68 Olds Cutlass S 350 Rocket 2sp Jetaway 2bbl
  123. Wheel Well Molding
  124. 65 2 Speed WIPER MOTOR
  125. wanted: 69 cutlass rear window defogger
  126. 66 Cutlass Supreme 4DR HT parts needed
  127. WTB Water Pump And Power Steering Pulleys
  128. Wanted Aftermarket Intake Manifold
  129. 1- 14x7 Superstock Rim
  130. 71-72 Air Cleaner Base
  131. 307 Alternator Bracket
  132. WTB 1955-56 fan shroud
  133. Set of Front Lower Control Arms
  134. Sbo 355 build
  135. 1972 Cutlass 350ci manifold heat riser bracket
  136. 69 Cutlass speedo parts
  137. 71 442 Radiator tanks
  138. unwanted distributor
  139. Any leads on parts for a 1940 Oldsmobile
  140. Seeking switch to activate console lamp
  141. 72 Cutlass Vert Front Door Glasses, Front Wheel Well Trim & TH350 Driveshaft Yoke
  142. dash fascia '77-84 full sized Olds
  143. turn signal/cruise control lever
  144. 69 Cutlass fenders
  145. 70 glove box lock cylinder
  146. Lansing 66-67 Toro Man needs UHV pcs, etc.
  147. TCS Solinoid, TVS for 1970 Cutlass
  148. 1966 F-85/Cutlass/4-4-2 Rear Bumper
  149. Toro oil pan
  150. wanted: 1970 w30 intake "Oldsmobile"
  151. 69 Cutlass Clock
  152. A/C Muffler Bracket
  153. 72 oldsmobile cutlass seatbelts
  154. 1966 Olds 98
  155. 68 supreme w/o moulding
  156. WTB Inner Fender Nuts
  157. WTB - One SS1 wheel to be rebuilt
  158. Brake drum needed for a Delta 88 , 1969 !!!!!
  159. Wanted low compression 425 .040 Pistons
  160. Wanted 1957/58 371 v8
  161. looking for distributer 455
  162. looking for distributer 455
  163. Wanted: 67 Cutlass Trunk Trim Molding
  164. WTB 1966 Starfire body molding
  165. 1966 Toronado Steering Wheel Wanted
  166. VC roof
  167. 1970 Centre Console NON Dual Gate
  168. 69 Cutlass S.. 2 things muffler and shroud cover
  169. Wanted 1967 442 Hood (with Louvers)
  170. NEEDED SS Capped lug nuts
  171. 1970 442 hood tooth
  172. Looking for...
  173. WTB : Olds 1956 horns
  174. 1966 trunk trim
  175. 67 Rally Pack Harness
  176. 1968 Drivers Side Mirror
  177. 64 fuse block wanted
  178. 70 Cutlass green
  179. 1970 Cutlass Center Console and shifter (non dual Gate)
  180. 71 delta 88 headlight bezel
  181. Need 71 Cutlass Power Trunk Release...
  182. Looking for 1970 cutlass parts
  183. Working AC Compressor for 71 Cutlass
  184. 68 Cutlass TH350 Gas Pedal and Kickdown cable
  185. WTB 1968 Delmont 88 front blinker lenses, rear bumper, right-side fender emblem
  186. 1965 cutlass non A/C heater case
  187. 1970 442 Wheels needed - Steering Wheel too
  188. 1964 Heater/AC Blower Switch
  189. Wanted: 72 Cutlass fender patch panel
  190. radiator top hold down plate, '69 442 4-core rad
  191. 70 455 tcs bracket
  192. 66/67 cutlass cowel piece
  193. Looking for cragar 50 spoke wire wheel
  194. 69 442 4 speed back drive and left grill
  195. '68 350 4bb fuel pump to carb line
  196. w-31 parts
  197. '72 T3 Headlamp Set
  198. 70 442 parts needed.....
  199. 1970 350 cutlass q-jet
  200. WTB 4 bbl throttle cable for 70 Cutlass
  201. wanted:olds 350/403
  202. Dualgate spring
  203. 69 Cutlass S wheel well moulding !!!!!
  204. 1968 F-85 Black Bench Interior
  205. 69 radiator parts
  206. Looking for parts to a 85 olds delta 88 royale
  207. 67 Cutlass wheel well trim, What's it Worth?
  208. 1966 442 trunk trin
  209. Wanted-delco starter 1108333
  210. Gas tank for 1968 Ninety Eight
  211. 72 air filter cover
  212. 57 olds stock wheels
  213. Starfire eering wheel wanted
  214. cs bucket seats wtb
  215. WANTED: '70-'72 Rust Free Body
  216. 70-77 Cutlass Sport Wheel accessories
  217. 72 oldsmobile stock valve covers
  218. 70-72 Cutlass Radiator Overflow Tank
  219. M/T Holley Edelbrock valve covers
  220. Oldsmobile Marker Lights
  221. Wanted 68 98 skirt trim
  222. WTB Vista roof glass
  223. 69 hood tongue
  224. 1967 Olds 442 Hood (with louvers)
  225. Deck Lid Lip Trim for A 72 442 Convertible
  226. WTB radiator lower deflector 67 A-Body
  227. 71 Olds Cutlass Fan Shroud
  228. Tires/wheels
  229. 1971 Cutlass Deluxe steering wheel parts
  230. Sport wheel hub, horn button and horn pieces.
  231. Considering 200R4, Pricing DC area
  232. Need a Saddle Steering Wheel for '72 Supreme
  233. 1959 rocker trim,hood ornament, seat skirt
  234. Wanted: 69 Toronado Output Shaft (Jack Shaft)
  235. 455 Dual Exhaust
  236. WTB '66/'67 Toronado rear bumper
  237. WTB '66 Toronado hubcaps
  238. Tail lights 75 delta 88
  239. WTB..Fan Shroud
  240. Lower Kick Panel Vent Grill 72 Cutlass
  241. WTB 65 plastic centers from spinner caps
  242. 13" rims for 1962 f-85
  243. Driver's Side A/C Underdash Vent
  244. WTB: Misc. 66 Toronado parts
  245. 72 supreme stone shield
  246. Posi Unit and Gear Set
  247. Wanted 1968 Delmont Convertible Deck Lid,Rear Bumper.
  248. Wanted: Toronado Fan Blade
  249. shifter cable
  250. 69 Cutlass S Wheel well mouldings
